Airtronics Support Forum Ask any questions you may have about Airtronics radios and product here and get answers direct from the Airtronics Team.
SD-10G charging
Reply
Old 08-25-2010, 03:09 PM
nozzler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default SD-10G charging
Can I use a different charger (other than the one which comes with the radio) to charge my TX?
I have a Hobbico Accu-cycle that I have used with other transmitters in the past, and I was hoping that I could set it up for an overnight charge at 1/10C and use it on my SD-10G.
nozzler is offline
Old 08-25-2010, 05:25 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SD-10G charging
nozzler,
I used my Hobbico Accu-cycle when I first got my SD-10G to cycle the battery 5 times. Now I just use the wall wart unless I need a quick charge at the field.
Zippi is offline
Old 08-25-2010, 06:18 PM
ToddNicholson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That should be fine, as long as you keep the charge rate to 1/10C. If you want to use a higher charge rate the battery should be removed. Using a high charge rate has the potential to damage the circuitry in the transmitter. Also, if you want to peak charge and/or cycle the battery, the battery should be removed to do that.
I hope this helps.
Regards,
Todd N
Airtronics Support
ToddNicholson is offline
Old 08-31-2010, 11:51 AM
JWilliams
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ToddNicholson
I hope this helps.
Regards,
Todd N
Airtronics Support
I remove my battery if I am charging it with anything but the included wall charger. However, I just went to a 2100mah 2S 7.4V lipo and I hardly ever charge, but when I do I remove it. The way they got the battery cover hinged it is just so easy, great design.
Jeff Williams
JWilliams is offline
Old 09-08-2010, 11:29 PM
ira d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have noticed that the charger indicator does not turn green after a 24hr charge and the battery is fully charged, Have the chargers in the later units been changed
so they no longer indicate green?
ira d is offline
Old 09-09-2010, 03:41 PM
ChrisVerano
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the new charger, the light no longer changes color, it stays red. The new charger is faster and you should not charge for more than 12 hours.
ChrisVerano is offline
Contact Us Archive Advertising Cookie Policy
