Air92744 antenna
I could use a longer antenna. Is there a way to do this?
can I use this? http://www.airtronics.net/index.php/...-t01-5503.html what are these for? http://www.airtronics.net/index.php/...0mm-green.html thanks |
RE: Air92744 antenna
490027 can be used (it's noted in the description)
490043 is for 27mhz receivers, it's totally different |
thank you.
Is it hard to do? Also, how long is this new one? thanks again. |
That antenna is ~8.5 inches long and yes, it's easy to change. No soldering required. It's a mechanical snap connector.
Best regards, Todd |
