Stylus - throttle channel issue
When setting up a model, I have noticed that the throttle servo arm will move only in response to about one half of the stick movement (ie. the lower half).
also when trying to set EPA on throttle, when I set the low end point and move the stick from low to high and to set the high end point, it will not return to the low EPA screen even though the stick is moved to low. any ideas what could be the problem? TIA |
RE: Stylus - throttle channel issue
Sounds like you have a bad stick pot. Did this suddenly go bad? Does it work this way on every model, or just one? If it across multiple model memories then you're going to need to send it in I think.
In regard to your Throttle stick problem, you might consider performing the control stick NEUTRAL TRAVEL mechanical setup. See the bottom of page 18 and top of page 19 in your Stylus Operating Manual. If that does not correct the problem then we recommend you send your transmitter in for service.
AIRTRONICS TECHNICAL SUPPORT 800-262-1178 |
Hey, the neutral/travel reset worked like a charm ! All is well.
Many thanks |
