Airtronics RDS 8000 Receiver Binding
Hi
I have a Receiver that has been previously PAIRED to a MODE 1 Airtronics Radio, and I wish to Bind to my Mode 2 but having difficulties, do I have to position switched in any particular sequence? I have F 2 facing away throttle LOW turn on Radio Led Lights Up then I Hold down Bind Button on receiver turn it on Flashes slowly then press Radio nothing happens, now starting to loose my Hair so may have to buy a toupee, any suggestions but not on the Toupee? Maybe I am missing something Thanks Ray |
I am not sure if this will help, but this is right out of the RDS8000 manual!
Prior to programming your RDS8000 transmitter, you should Bind your receiver to your transmitter so your receiver will only receive commands from your transmitter. To bind your receiver to your transmitter, move your throttle stick to the low position and turn on your transmitter power switch. The Blue BIND LED on the left side of the panel will illuminate. Connect your onboard battery with a switch harness to connect the power to your receiver. While holding down the little BIND key on the receiver, turn on the receiver power switch. The BIND LED will flash slowly. When it flashes slowly let go of the receiver BIND key. While the BIND LED on the receiver is flashing slowly, momentarily press the BIND key on the transmitter and release it. The BIND LED on the receiver will start to flash rapidly and then will light solidly indicating that the binding was successful. Note that unless the BIND key on the transmitter is pressed within 10 seconds while the BIND LED on the receiver is flashing, the BIND LED on the receiver will automatically time out and stop flashing. If this occurs, repeat the above steps. Once you have performed the binding process you are ready to program your transmitter Hope this helps! Craig. |
