what 2.4 article
#76
Banned
RE: what 2.4 article
ORIGINAL: Dave
I TOTALLY AGREE WITH OBERST
Thank you sir! It's funny Dave, but after reading the article in Model Aviation and I quote, " One option for a 2.4 GHz RC user is to change operating frequency to the 72Mhz band."
That's fine and dandy if you are using a 72mhz radio with a 2.4 converter! Even then, you'ld have to rip out the 2.4 reciever and replace it with a 72mhz receiver and put in the TX and RX crystals to make it work. But what about all those who gave up their 72mhz radios for the straight 2.4 radio? I know the answer, they are S^%t out of luck!
This is what happens when the market refuses to give us choice and forces us to move to a new product that has issues. Talking about a monopoly! For those who remember, Spectrum and Futaba Fast both had a trade in deal when the 2.4 was first released. For those who traded in their 72 mhz for the new 2.4 for the additional discount? All I can say is bad move. Now if you see your radio acting up, you can't switch back to 72mhz unless you buy a used radio, or have a extra radio and reciever on hand.
But I'm one of those people who don't just run out and buy something just because it's new. I did it the smart way and when I started seeing and reading about the 2.4 having issues, I bought a few more 72mhz radios just to hold me over until the 2.4 is finally replaced. It's about time the AMA admits there's a problem! That's a good start and only the beginning I hope.
Someone wrote that eventually the 2.4 will be replaced like the 72mhz replaced 32mhz etc. That is very true, however I found a few places still selling the left over 72mhz and I know of many like me who refuse to operate on a 2.4 system and are still using the older equipment. The 2.4GHz however, will be replaced much sooner than it normally would if there was no issue with them to begin with. That's what I was told.
Someone wrote that Spectrum issues are now resolved? That's not a true statement. Both Futaba, Spectrum, Aurora, Airtronics and Hitec has been recorded to have had issues this year.
They are many issues with all of the 2.4 systems that we know about. How many have crashed because of the 2.4GHz that we don't know about? Slowly more and more are focusing on possible issues with their 2.4 radios. Matter in fact, while I write this another person just started a thread that he lawn darted his 50cc airplane in the Crash/Rebuild. He stated his 2.4 Aurora 9 blacked out and gave him nothing but headaches. Another $2,000 gone!
http://www.rcuniverse.com/forum/m_10...m.htm#10780831
Of course we have people already trying to tell andizzle that everything else went wrong other than his radio. Let's give him credit- he may be new but he isn't stupid and knows that his 2.4 acted up.
A new technology introduced into the market automaticly makes the older technology it's replacing obsolete. To me that's a big misnomer.
Pete
#77
ORIGINAL: cheezer1222
Is this actually true, or is it one of those, "I heard from a friend who, had a brother, who knew a guy who lost his plane because of..."?
ORIGINAL: Sport_Pilot
All it takes is for some large person to walk between the transmitter and your plane.
That the plane lost control for three seconds, why it did is conjecture.
#79
No, we ARE the primary users. They have made broadcast systems tune their stations for this before. It is not a high priority because we are not comercial and they are but we are the primary users. On 2.4 there is no primary user.
This is wrong on both accounts and brings the rest of the article into question. On 72 we were absolutely secondary users and had to accept all interference that may have happened from primary users. Hence some folks had channels that could not be used around certain TV stations or pager stations.
47CFR95.207
(d) Your R/C station must stop transmitting if it interferes with: (1) Authorized radio operations in the 72–76 MHz band; or (2) Television reception on TV Channels 4 or 5.
(g) Stations in the 72–76 MHz range are subject to the condition that inteference will not be caused to the remote control of industrial equipment operating on the same or adjacent frequencies or to the reception of television transmissions on Channels 4 and 5.
These frequencies are not afforded any protection from interference due to the operation of fixed and mobile stations in other services assigned to the same or adjacent frequencies.
#80
Really? You didn't read about how the author doesn't have the technical knowledge to evaluate the technology?
#81
Still, why anyone big enough the block your signal standing in front of a TX, you would not be able to see the plane.
#82
47CFR95.207 (d) Your R/C station must stop transmitting if it interferes with: (1) Authorized radio operations in the 72–76 MHz band; or (2) Television reception on TV Channels 4 or 5. (g) Stations in the 72–76 MHz range are subject to the condition that inteference will not be caused to the remote control of industrial equipment operating on the same or adjacent frequencies or to the reception of television transmissions on Channels 4 and 5.
#83
Totally off topic. Please, go read the entire section. It says exactly what I am saying. Only a PRIMARY user is afforded protection from adjacent channel or other in-band user interference. We are not and thus we are NOT primary. On 2.4 (ISM band) nobody is primary in that section of the band.
To review:
WE are the ones who must stop transmitting if we interfere with other authorized users.
WE are NOT afforded any protection for other authorized users in the band.
I just do not know how much more clear you need to see it.
http://ecfr.gpoaccess.gov/cgi/t/text...95_main_02.tpl
To review:
#84
Banned
ORIGINAL: HighPlains
Glad I still have a 27 MC tube transmitter and regenerative receiver in case that newfangled superheterodyne doesn't work.
However, if you tweek the regenerative with a tweeker, the flux capacitor you should observe about 50 ohm's out of the 27 MC tube improving it to the superheterodyne apparatus. That's of coarse if you buy the thinywatchamacallit regenerative receiver then the olfangletoot rays should hold long as it's grounded to the 27 MC tube transmitter. All the superheterodyne is or a better word for it is a microflux resistor, that capacitates the nuron acids hitting the regenerative receiver that amplifies the regenerative to work as a Raster Superheterodyne.
Pete
#85
I'm just putting this out here: Car guys don't have problems with 2.4ghz. It's unequivocally better than FM and AM for us. We don't have any latency issues, we don't have interference issues, we don't have any bind/link issues, we don't have any range issues, and it means those of us who like stick radios don't have pesky FCC regulations in the way. We also don't have ROAR and IFMAR spazzing out about it, matter of fact they actually recommend using 2.4ghz in competition.
Idunno what the AMA is on but I think they got it from the Crips. I love 2.4ghz, hell I'm even on the dreaded Spektrum. My NTC3 is perfectly fine on Spektrum, DX5e Tx and AR6110e Rx if you're curious, and I've never had any lockouts, glitches or latency issues. I have no qualms about trusting my aircraft to it.
#87
Hrm.....Next time it rains heavily I'll take my NTC3 out and find out what's what. The Rx is maybe an inch off the ground, in a plastic box that's bolted to a piece of aluminum, the underside of which gets quite wet operating in the rain. If there's anything to that I'll find out.
Most likely though, I'll just be able to powerslide around happily as I do in the dry
#88
Banned
ORIGINAL: 378
Car guys and indoor flying the 2.4 works well. Why? That's because car guys and indoor pilots don't operate hundreds of feet away.
Pete
#89
ORIGINAL: Oberst
Pete
ORIGINAL: 378
Pete
I've run my touring car out far enough to lose track of which end is pointed at me and I still had perfect control over it. I managed to re-orientate myself by softly blipping the throttle while turning full lock and noting which way it moved.
I can still keep track of that out to about 100 yards or so. It was quite a ways out, farther than my old AM set would reliably work.
Edit: It's also worth mentioning the FPV car guys that are driving, quite literally, a mile away from the transmitter. They have to turn back because the camera signal gets weak, they still have a solid 2.4 link with the servos. FM and AM need crazy powerful boosters to do that, 2.4ghz radios do not.
#90
Banned
ORIGINAL: Silent-AV8R
According to all the ''theories'' 2.4 works very badly on, or near, water. And yet most all boat racers are now on 2.4 and loving it. Go figure.
No, 2.4 doesn't work submerged. The Thunder Tiger Neptune Sub is a 72mhz.
Pete
#91
Banned
ORIGINAL: 378
ORIGINAL: Oberst
Pete
ORIGINAL: 378
Pete
Sure, but it's not the same distance that we fly our glow/gas planes. We fly at a very, very far distance sometimes. Especially if there are a lot of other pilots flying at the same time and one is trying to land, or if a man walks out in the field, we have to keep our planes at a safe distance. At times I've had my planes only a small spec in the sky.
Pete
#92
ORIGINAL: Oberst
Pete
ORIGINAL: 378
ORIGINAL: Oberst
Pete
ORIGINAL: 378
Pete
Pete
check my edit. There's FPV car guys using unmodded 2.4 radios out to a mile.
#94
Banned
ORIGINAL: 378
ORIGINAL: Oberst
Pete
ORIGINAL: 378
ORIGINAL: Oberst
Pete
ORIGINAL: 378
Pete
Pete
I'm a bit sceptical until I become a witness. Also it should be mentioned that the operator stands higher than the car, the opposite can be said about operating rc aircraft. Big difference.
It's obvious that most posters on this subject have no RF background.
Pete
#96
ORIGINAL: Oberst
Pete
Pete
#97
ORIGINAL: Dave
#98
ORIGINAL: Oberst
Pete
Pete
#99
Banned
ORIGINAL: 378
Go onto youtube then. There's plenty of FPV car videos posted where they drive insane distances away with no issue whatsoever.
They go behind obstacles at a mile distance, all I saw on youtube wasn't a mile but a few hundred feet and no obstacles other than rocks , and all the others did mostly stunts. If you send me the link I'll check it out.
But so far to me comparing RC Cars to RC Airplanes is like comparing apples to oranges.
Pete
#100
To review:
To review:
It is not off topic. Can you point to the part of the regulation that explains primary or secondary users? Typically broadcast and other commercial users are not asked to turn off their equipment because they will lose money if they do. Not the case with our RC equipment.
