FAA fine against drone photographer dismissed.
#101
SP, the guy used a model airplane as a drone for commercial purposes. The FAA was going after the drone use, not the model airplane. It seems to me that you are conflating the two separate issues. Because, if he had obtained a real military drone the FAA would still have gone after him. It was the judge who confused the model airplane vs drone issue.
If he was not flying in a unsafe manner the FAA should have advised him that they plan to put into place new rules that prohibit flying models for any type of compensation.
and let it go.
#102
It remains to be seen if the CBO will have the full exemptions that the AMA wants or what within the programming of a CBO means.
#103
It should not make a difference if the guy was flying commercial are not. What should matter was he flying in a unsafe manner or endangering people or property.
and let it go.
and let it go.
11. By reason of the above, you operated an aircraft in a careless or reckless manner so as to endanger the life or property of another. By reason of the foregoing, you violated the following section(s) of the Federal Aviation Regulations: Section 91.13(a), which states that no person may operate an aircraft in a careless or reckless manner so as to endanger the life or property of another.
http://www.suasnews.com/2013/10/2547...gainst-trappy/
#104
How many people were really killed? Why don't you go drag up the articles, and post them here, please. How about intentionally? How many jets were taken out of the sky by an RC foam toy? Apparently, not enough to form a grass roots effort to have the RC hobby either shut down, or somehow regulated like they do with firearms, which are a fundamental Constitutional right.
Hey, I got an idea. Why don't you call Shannon Watts, and have her add RC planes to her list of assault weapons?
Section 338 of 112-95 is an act of regulating model aviation. Fortunately it allows us to self regulate with FAA oversight.
Who is Shannon Watts?
I think you are missing the point. No one has accused anyone of using a model plane or a drone as a weapon, yet. We are only discussing the acts of a few psychotically deranged individuals who are ignoring reasonable safety practices. And, by ignoring the rules, they are turning perfectly good toys into dangerous weapons.
#105
IMO the FAA should stay with regulating drones that are flown in airspace along with other full scale craft or in the size range of full scale craft and
leave alone smaller hobby size craft. I do understand that models flown in a unsafe manner needs to be dealt with but I am not sure the FAA needs
to be the one to do it.
#106
#107
The problem with sUAS is that sociopaths are buying toys and thinking they can operate them as a sUAS. I think that, in the UVA case local law allowed, or was forced to allow, the FAA to run with the ball. Maybe local law can now follow-up on it. Should be interesting to see what happens.
As far as the general case goes, I think local law and the FAA should work together to nail the sociopaths.
#108
The issue is that a great number of drones that are used for commercial purposes are indistinguishable from "hobby" drones/RC models. THis is going to be an avenue of attack for that segment when FAA does impose rules (as I think they should) on commercial operations. I've already heard it talked about. How can FAA regulate a guy flying a Phantom II taking pictures of crops but NOT regulate a guy flying a Phantom II taking pictures of his neighborhood for his own amusement, i.e., as a hobby.
If the flyer is following CBO guidelines, then he is a hobbyiest. If the flyer is not going by the official CBO guidelines, then he is no longer a hobbyist but a sociopath, and can be regulated by the FAA. If he is a businessman, then he will be following the FAA regulations. It shouldn't be too hard to tell them apart.
#109
CA
Interesting idea, but both flyers are failing to follow reasonable safety guidelines and can be charged with reckless endangerment. But, that is more like local law.
2/7/14 Press release from AMA Government Relations Blog:
“We are carefully reviewing the decision and the judge’s findings. Though the ruling deals primarily with administrative procedures, the safe operation of unmanned aircraft, be it for commercial or recreational purposes, is the primary concern. The members of the Academy of Model Aeronautics have operated unmanned aircraft (model aircraft) in the national airspace for decades and have set the example for operating small unmanned aircraft systems (sUAS) in a safe and harmonious fashion.”
“This current situation underscores the immediate need for programing to support and govern this activity. The Academy stands ready to lend its expertise and to assist the FAA in developing a safety structure that will enable and allow all sUAS to operate safely and responsibly in the national airspace.”
Recalling a comment by LCS above, this looks like their application for the FAA lap dog job.
cj
#110
Your fascination with sociopathic behavior has no bearing on how they are writing the rules or how they will eventually be enforced.
#111
There have been 2 deaths in the last 5 or 6 years (I am pretty sure one was last year) from models and at a few more than that previously. The previous incidents drive the manner in which racing is handled now and changed the Safety Code to prohibit flight over gatherings of people (that was after a death in CandleStick Park some years ago). There are others, but if you are too much of a lazy bum to do the research I am not going to waste my valuable time and effort educating you. Stupid people cannot be fixed and I am not even going to try.
Other than that sir, you are welcome to go pound sand and find out all about Cumulo Ganitus through personal experience.
#112
Lets get real here boy. If YOU want Shannon Watts involved because you are too lazy to determine the FACTS for yourself by simply doing a little research, I am sure you are perfectly capable of calling her yourself. Aren't you? Or are you so wound up with being perfect that it is impossible for you to be educated? I know...you have write only memory!
#113
#114
#115
Well, the FAA has been charged with integrating sUAS and large scale UAS into the NAS. They have decided to start with sUAS, but have not produced a set of regulations. And That's were the judge got them.
#117
Well, it's the sociopaths who make the rules and laws necessary.
#118
The judge said it was not supposed to happen, at least not yet, And according to you people who fly from vacant lots are sociopath's, which includes at least two AMA hall of famers.
#119
BTW: Nobody in this thread has sounded like an AMA hall of famer, whatever that is?
#121
No way that they just let it go. That guy was nutz. And, they did send him a cease and desist letter.
#124
I tell you what. I have other hobbies and interests that are very important to me. So, I do indeed stay within the confines of the law. I will assure you of that. None of my planes have ever hurt anybody, but then again I also am careful to not fly around people. But like I said earlier, I do not care if the model airplane hobby collapses under the weight of its own bureaucracy. I will add, that the AMA is more than welcome to pull my membership by refusing to renew. Heck, I'll even give my AMA number to them, so they can do as they please. It still will not stop me from flying in an unpopulated area, with a property owner's permission. THAT can only be prevented by the FAA licensing people who fly model airplanes, like they do full-scale pilots. It is still legal for me to fly my model planes, because there is no requirement for a license or medical certificate.
You can continue to drink the stupid Kool Aide about lap dogs, or back off and try to figure out what is and what is not important about what IS HAPPENING rather than what you want to have happen. They are two very different subjects. I don't care what the AMA says nor does it have any impact on THIS CASE. Did you understand that or does it have to be carved in something and dropped on your foot for you to grasp it?
As for your suggestion that now the FAA should be licensing hobbyists, it stinks but I am sure that is what you are really pushing for in your effort to be exclusive and elitist.
The FAA's position has not changed substantially over the years. Hobby flying is hobby flying and generally simply watched, but any flight involving compensation is strictly regulated both in equipment and personal training standards and conduct rules as there a lot of innocent bystanders who are constantly being put at risk by unsafe operators (as defined by the FAA). Tell us Mr. Perfect why that same metric should not be applied to ANY aircraft/pilot combination that is capable of compensated flight?
In case you missed it the subject of this discussion is the FAA and a fine rather than the AMA and your obvious psychopathic hatred for it.
Originally Posted by littlecrankshaf
how about flying downtown right in front of the court house??
If you can make that happen - DO IT! By the way, how did it go? Yes, I remembered.
Sport_Pilot, I don't think so.
#125
This is a big country. Very diverse. People are so different one form another. And forums like these really show us how far off the cliff some people really are. Some seem to live in their own country created in their own mind, in a non-existing bubble.
Gerry
PS: come to reality, we have cookies...
Gerry
