Fear mongering? AMA members with airman certificates?
#51
But that is basically what they did in the Pirker case. No he did not have a ticket to pull, but they did fine him. Sure what he did was dangerous to people around him, but it did not endanger a full scale aircraft so what business was that to the FAA?
There is also an inherent danger to fellow modelers doing rolls 5 feet off the ground. The wings could hit the ground and break off, or the engine could come flying off or a prop blade break. These parts could hit someone and hurt them. The FAA said they could apply Part 91 at will so they could apply the part about doing aerobatics close to people. What was that distance? 500 feet I believe.
#52
in a privilege based society your privilege is highly dependent on what you can afford.
My concern are all the new laws and regulations the Feds and state, local and muni authorities are enacting. Once they're in place, they'll be very difficult, nigh impossible, to retract. That's why we need to have our voices heard at every level, and keep the authorities in place. They are OUR servants, and are trying to make it just the opposite.
#53
#54
CA
AMA final comments on the FAA interpretation if it matters to anyone participating in this discussion thread.
As for OP's question, of course it is fear mongering, something that is basic to AMA's bread and butter and so they are good at it. You don't sell insurance without fostering and exploiting fear, and AMA could not sustain itself without selling insurance. This instance is a little different as to the fear du jour they are selling but the bottom line, literally, is the same objective.
#55
On the other hand there are some that are looking to make a name for themselves. Like where I live in the country, there are a fair supply of copperhead snakes. I am outside frequently, I have to clip trees, burn brush, etc. and keep the snakes off the porch areas and away from my big barn where they try to get into. Some folks that come by are afraid of the 9 shot .22 revolver hanging on my belt. You would probably call me paranoid. However none of my kids and grand-kids or such or company ever gets bothered with my ways, None have been bitten or even close to a snake. Several have seen me clip a head at 50 feet away, when the head pops out of tall grass or bushes.
So, MR JohnShe, watching all kinds of persons around you, and your staying aware of their actions can make for a happier tomorrow. Keep your airplanes flying, and not in someone else's car as "evidence". Maybe rub some of that paranoia on yourself.
#56
That is a perfectly valid point. Local law enforcement should have acted, but they didn't. I should have been there to dial 911, but I am not ubiquitous. The FAA tried to make a federal case out of it and the poor results just demonstrated their limitations.
#57
JohnShe, you do bring in (1)some good, (2)some funny, and (3) some items rather less than knowledgeable of the real world that we live and work in. One of these items (3) is IMO, the FAA Air Carrier Inspector . There are all kinds of personalities working for and with FAA. I have survived all kinds. Most are very much as you state in post #50.
#59
Of course I do. They have to be understood to be defeated.
I doubt that you could remember it any other way.
#60
Originally Posted by FAA
Recreational use of airspace by model aircraft is covered by FAA Advisory Circular 91-57 (PDF), which generally limits operations for hobby and recreation to below 400 feet, away from airports and air traffic, and within sight of the operator. In June 2014, the FAA published a Federal Register notice (PDF) on its interpretation of the statutory special rules for model aircraft in the FAA Modernization and Reform Act of 2012. The law is clear that the FAA may take enforcement action against model aircraft operators who operate their aircraft in a manner that endangers the safety of the national airspace system. In the notice, the FAA explains that this enforcement authority is designed to protect users of the airspace as well as people and property on the ground. Read the full press release. Read more about Model Aircraft Operations.
http://www.faa.gov/uas/
Frank
#61
Whether you agree with their statement or not does not matter, that is their stated policy.
Frank
Frank
#62
Aww come on Sport, put it in a little common sense format. Why do you think home-built airplanes have a 50-hour fly off period out over remote areas? Why is the minim altitude over populated areas higher than over un-populated areas? Why are there restricted airspace around a nuclear facilities? Why can't a part 103 ultralight fly over congested areas? All designed to protect people on the ground. It's got nothing to do with 'authority on the ground', it has to do with keeping the death toll down.
#63
From US Code 40103
(b) Use of Airspace.
— (1) The Administrator of the Federal Aviation Administration shall develop plans and policy for the use of the navigable airspace and assign by regulation or order the use of the airspace necessary to ensure the safety of aircraft and the efficient use of airspace. The Administrator may modify or revoke an assignment when required in the public interest.
Dangerous activity is better handled by the local police in any event as the Pirker case proved.
#64
I have no issue with what you wrote. I have issue with the FAA regulating models and other sUAV flying under FAA minimum altitudes (IE non navigable airspace). They are staking claims on airspace that they were never given a mandate to regulate.
[FONT=tahoma]From US Code 40103
In otherwords they were never given the authority for airspace below FAA minimums. Also there is a considerable difference in a jetliner crashing likely killing hundreds of people and a model crashing likely killing only one, but more likely to cause injury requiring a few bandaids.
Secondly, I am in agreement that almost all sUAS incidents involving people and property should be acted on by local law enforcement. The problem is, they don't always get involved. So I think the FAA has an obligation to make a federal case of it. And, to do that, they need regulations on the books as they have learned from the Pirker case.
#65
#66
First, your issue with altitude is ridiculous. We know that ATC controls fixed wing on the ground at airports, airfields and cow pasture runways. We know that that they control all aircraft both fixed and rotary wing from the moment they leave the ground (which usually is under 400 ft) up to any altitude that they are capable of flying.
And I don't want the FAA to make federal cases out of mole hills! I don't care how much bad press the FAA gets, it's a waste of taxpayers money to fight losing battles and bluff its way through.
#67
Ahh and there's the rub. To what standard do you want the LEO's working to? How do you create an equitable local law for things that fly that are fairly uniform across the country?
The whole reason the CAA/FAA was created was s that there'd be a single standard of design safety for all airplanes across the US. Otherwise you'd have 48 state versions of what is or is not an airplane.
So we turn to the Federal government to standardize things but if they do it poorly we get what we're suffering with in these threads.
Did anyone else read the AMA's corporate responses to the FAA interpretive document. It actually made sense.
#68
Why would you even consider letting the FAA tell us what is safe or not, except of course when it is interering with the flight path of a full scale aircraft?
#69
We are not talking about airliners flying coast to coast here. We are talking about model airplanes flying from point A back to point A. You are talking about different communities with different notions about saftey and responsibility. So you don't want uniformity. That is why we are a nation of states and not one totalitarian federal government.
#70
Sport Flyer, come to Oklahoma City where there's a pathetic little law on the city books prohibiting flying models of any kind in any city park at any time UNLESS it is in a city designated model airplane flying field. And there are TWO of them for a city of half a million.
A councils knee jerk reaction to renegade jerks who couldn't understand repeatedly flying combat on a soccer field in a crowed park was unsafe.
§ 38-99. - Model aircraft.
Model aircraft flying shall not be allowed in any park except in those areas designated for such activities.
(Ord. No. 20098, § 2, 1-18-94)
#71
#72
#73
Well presently that would be covered by either criminal or civil law in every state. So your supposition is completely invalid.
#74
