Another Drone Pilot does it Again
#2951
My Feedback: (49)
There are already portable ADS-B's and a club would only need one on a pole to keep full scale air craft away from any Designated Flying field. It could be made to look like a hovering Helio and deter full Scale aircraft to keep at least 1/4 mile away maybe even 2000' horizontally or 1000' above the highest object with in the 2000'
Ref. FAR 91.119(b)
[TABLE="width: 90%"]
[TR]
[TD="width: 582"]
Code of Federal Regulations
Sec. 91.119
[TABLE="width: 100%"]
[TR]
[TD="width: 100%, colspan: 2"]
Part 91 GENERAL OPERATING AND FLIGHT RULES
[/TD][/TR]
[TR]
[TD="width: 50%"]Subpart B--Flight Rules[/TD]
[TD="width: 50%"]
General
[/TD][/TR]
[/TABLE]
Sec. 91.119
Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.[/TD]
[/TR]
[/TABLE]
#2952
My Feedback: (49)
Not likely. ATC is basically the ones that keep planes away from each other. When you think about it, small planes probably aren't going to have most of the hi-tech stuff, they will need to have someone "assisting" them. What worries me is that the FAA may require us to have two way communications with ATC to prevent accidents as well
#2953
My Feedback: (49)
#2954
Hydro as U probably already Know the only separation of air craft the ATC is required to keep separation are those on an Instrument Flight Plan and only when in IMC. Not with standing they do try (On a workLoad Basics) try to keep other s advised of other aircraft but it is not their Job. It is still the pilots responsibility under the "Seen & Be seen concept) that the ATC system works. At least until after 1 Jan 2020 when all aircraft in controlled air space is mandated to have ADS-B Automatic Dependent Surveillance-Broadcast.
#2955
#2956
Sporty what u fail to realize that Privatizations of the ATC system will be the end of General Aviation and Any "DRONE" R/C model flying. User Fees will be the death knell of all but military and commercial air travel.
Ref. FAR 91.119(b)
[TR]
[TD="width: 582"]
Sec. 91.119
[TR]
[/TR]
[TR]
[/TD]
[TD="width: 50%"]
[/TR]
[/TABLE]
Sec. 91.119
[/TR]
[/TABLE]
Ref. FAR 91.119(b)
[TR]
[TD="width: 582"]
Sec. 91.119
[TR]
[/TD][/TR]
[TR]
[/TD]
[TD="width: 50%"]
General
[/TD][/TR]
[/TABLE]
Sec. 91.119
[/TR]
[/TABLE]
#2957
ADS-B is just one part of NextGen. Most airports do not have their equipment yet. Also not enough ADB-S ground transceivers out there yet. Also the Data Com is not implemented or fully implemented. I think most of the equipment we are waiting on is the NextGen Weather data reporting. When that is done then all data to include weather will be sent to the pilot. No need to talk to the controller.
#2958
My Feedback: (49)
Agreed but, with a quad, THE OPERATOR ISN'T FLYING EITHER VFR OR IFR. If some one is flying LOS they wont be high enough to be and issue to aircraft so there won't be a need for ATC to be involved. That being said, if the operator has no instrumentation to fly by they can't be flying IFR. FPV isn't VFR compliant either so, that being said, ATC is powerless to do anything other than warn others the quad is there. I see this requiring quad operators to be required to have two way communication with ATC to prevent collisions in the not too distant future
#2959
Latest FAA UAS sighting data released
http://www.faa.gov/news/updates/?newsId=85229
For giggles, I did a preliminary analysis:
Overall rate decreased toward end of the year, but appears to be creeping back up again
50% of them take place in just four states: California, Florida, New York, and Texas
25% of all of them take place in just 9 cities: New York, Los Angeles, Miami, San Diego, Chicago, Orlando, Seattle Boston, & Atlanta
NMAC mentions got better for a bit, then appear to be ramping up
Still working a more detailed analysis, trying to reliably sort for fixed wing sightings vs. quads, evasive action required, etc. All have to come from free text field which makes it a bit tougher.
#2960
My Feedback: (49)
[TR]
[TD][h=3]Drones in the Zone[/h]Can UAVs safely share commercial airspace?
FULL ARTICLE
[/TD]
[/TR]
[/TABLE]
[TR]
FULL ARTICLE
[/TD]
[/TR]
[/TABLE]
#2961
Banned
My Feedback: (8)
[TR]
[TD]Drones in the Zone
FULL ARTICLE[/TD]
[/TR]
[/TABLE]
[TR]
FULL ARTICLE[/TD]
[/TR]
[/TABLE]
We've already seen technology and automation reduce the need for more people in the cockpit, the discussions now surrounding drones pertains to commercial use for product deliveries, agricultural, and even filming purposes. Eventually we'll see one pilot in a plane, and then...no pilot. I don't know if it will happen in my lifetime, but that's coming. There are already a couple of mock ups out there.
#2962
Maybe for big professional/commercial Drones But all is needed is an ADS-B transmitter and all full scale aircraft will/can avoid any interaction with Hobby Drones. All a person needs is one that is transferable between aircraft (Drones). Like I stated before if a club had one on say a 20 foot pole they could broad cast their position and full scale would avoid the area. Problem solved. Besides if U check some of my posts about FAR 91.119(b), Then it's the full scale plane is required to circumnavigate any place there is an open air assembly of people by a minimum of 2000' horizontally or a thousand + feet. It worked when I referenced 91.119(b) to the local flight school head instructor low over flight have seized by almost 99%. Planes have been above 1640' 500 meters.
#2965
My Feedback: (49)
It's little different than Drinking and Driving, Every one knows it Illegal but still we have thousands of arrests, Deaths & maimed people and property every year. Then U have drug use in this country ... Go after these problems and stop making a problem where non exists. But then again I'm preaching to the Choir.
#2966
Banned
My Feedback: (8)
HD already hit the nail on the head, it's right after the holidays when that # was arrived at. I can't recall exactly where I read it, but it was this week, and the article noted "sightings" were actually down overall. If I can find the link I'll add it. As with any online article, it's value/data is fair game.
#2967
January is just 7 days after christmas U think maybe that might just have something to do with it. Be sides I haven't seen any big campaign from the feds News media Hobby Shops HK or anyone who sells Drones to educate the populace that flying in the vicinity of airports at altitudes that will interfere with man carrying aircraft on landing or take off.
#2968
Here's data for all three CY by month - 2015 higher than 2014 in same month, 2016 higher than 2015 in same month.
Nov '15 vs Nov '14 - sightings up by 338%
Dec '15 vs. Dec '14 - sightings up by 250%
Jan '16 vs. Jan '15 - sightings up 257%
#2970
My Feedback: (49)
I'd to know what time frame most UFO's are reported by airline Pilots.
Midnight is just so far off the scale to be believable. Besides if the Drone did have it's lights on it would be unrecognizable in the lights of a city. I'd also like to know what airports and what approaches these sightings were. If they were long over water approches well then maybe. Not being argumentative. Just Curious.
#2971
#2972
I have a hard time with as many drone sightings at 11 PM as 10 AM. Like HD I believe they are confusing UFO's with drones. Or they are afraid to report a UFO so they call it a drone instead.
In other words the whole thing is a crock! It is political not factual.
#2973
Banned
My Feedback: (8)
I just added a way to sort by report. Over the period of the first report (280 days), there were 764 reports sightings. Over the period of the second report (163 days), there were 582 reports. So, the average has gone from 2.7 per day to 3.6 per day, an increase of 30%.
Any data
#2974
Bard Center for Analysis of the Drone has already done a preliminary analysis of the latest batch of FAA sighting reports. It can't help make the case that this latest batch includes 24 reports of drones coming within 50 feet of a manned aircraft, and 11 reports of pilots taking evasive actions to avoid a collision.
http://dronecenter.bard.edu/analysis...faa-incidents/
#2975
My Feedback: (49)
