Are there any Nationwide CBO's other then the AMA?
I asked Rich Hanson about this recently. Here is his response:
Beyond that, I guess I am lost in understanding why people would want to take advantage of using the AMA rules in order to comply with Section 336, but do not feel it is worth supporting the organization that got them the ability to fly using the rules the AMA writes??
CA
After Section 336: FAA advises people flying model airplanes to follow the voluntary guidelines published in AC 91-57 and also advises voluntary compliance with a community-based set of safety guidelines
Makes me wonder how much it is worth to Joe Average modeler to take advantage of using the AMA rules in order to comply with Section 336 which AMA wrote and lobbied for to get into Federal Law. I'm thinking very little, except for those that were too stupid to be capable of flying safely with only the AC for guidance and yet smart enough to feel that 336 will make their flying safer.
I think we all know when the AMA came up with section 336 they had membership increase in mind, That being said it will really be the FAA who can treat all modelers
the same or have a different set of rules for CBO members that in effect would force flyers to become AMA members.
Before Section 336: FAA advised people flying model airplanes to follow the voluntary guidelines published in AC 91-57
AC 91-57 will almost certainly be rescinded once the sUAS Rule is final.
Subpart E – Special Rule for Model Aircraft§ 101.41
Applicability.This subpart prescribes the rules governing the operation of a model aircraft that meets all of the following conditions as set forth in section 336 of Public Law 112-95a) The aircraft is flown strictly for hobby or recreational use;(b) The aircraft is operated in accordance with a community-based set of safety guidelines and within the programming of a nationwide community-based organization;(c) The aircraft is limited to not more than 55 pounds unless otherwise certified through a design, construction, inspection, flight test, and operational safety program administered by a community-based organization;(d) The aircraft is operated in a manner that does not interfere with and gives way to any manned aircraft; and(e) When flown within 5 miles of an airport, the operator of the aircraft provides the airport operator and the airport air traffic control tower (when an air traffic facility is located at the airport) with prior notice of the operation.
And once again you guys are arguing over semantics and other such garbage. The plain and simple fact is the FAA has recogninzed that there are organizations who have established some safety RULES and have exempted those who follow those RULES. There is that nasty word - RULES. All semantics aside that is what they are. And some of you just don't want to follow them so you will use any perveted logic you can to attempt to get around the. Well the FAA has made if perfectly clear - YOU LOSE.
#31
My Feedback: (58)
#32
CA
Not really. FAA advises people flying for hobby/recreational reasons to follow Section 336. Neither their interpretation or the newly proposed Part 101 mention AC 91-57. And by putting Section 336 in the FARs compliance is no longer voluntary.
After Section 336: FAA requires people flying model airplanes to comply with the new FARs written by AMA
And I thought AMA's claimed objective was to preclude new regulation from being placed on model aircraft operation.
FAA regulation is bad, AMA regulation is good, and we call it non-regulation. Are we straight on that yet?
#33
#34
We are free and in the clear, all we have to do is stay under the RADAR. We do this by following the intent of the safety guidelines. We don't have to join the AMA if we don't want to. We don't have to follow the safety guidelines or section 336 to the letter. Just stay out of the NAS and avoid endangering full scale aviation. We can soar to thousands of feet if we stay clear of full scale aviation. We can fly jets, extra large giant scale, or anything we want. Just do not endanger the NAS. How easy is that?
#35
CA
Yep.
Nope. FAA requires people to follow section 336 which requires following a CBO's rules. The AMA rules are NOT Federal Aviation Regulations (FAR). Nor will the rules of any other CBO that may come around. What the FARs do say is you have to follow the rules of a CBO. Seems like the same thing but it is an important distinction.
..... (b) The aircraft is operated in accordance with a community-based set of safety guidelines and within the programming of a nationwide community-based organization;(c) The aircraft is limited to not more than 55 pounds unless otherwise certified through a design, construction, inspection, flight test, and operational safety program administered by a community-based organization;(d) The aircraft is operated in a manner that does not interfere with and gives way to any manned aircraft; and(e) When flown within 5 miles of an airport, the operator of the aircraft provides the airport operator and the airport air traffic control tower (when an air traffic facility is located at the airport) with prior notice of the operation.
What new regulation has been placed on models?? All the FAA has done is officially recognize the exisitng law and provide authorization for model aircraft operations in the FARs. No new or additional rules placed on models.
FAA regulation not needed. Modelers can police themselves as has been proven by AMA members for several decades.
#36
FL
Well after 32 posts it seems the answer to the question:
is NO
As for the question is membership in the CBO required to be "within the programming", IMHO the use of the word "within" puts the the AMA a good position to assert that it does. Now before some here have a fit, that DOES NOT mean you must join the AMA it does mean you must be a member of a valid CBO. That is the Catch22......
is NO
#37
CA
is NO
is NO
#39
CA
I don't want to wear out that welcome, but you're on roll here with digging out information we modelers should be aware of, so....
Among the last several posts to this thread "the newly proposed Part 101" came into the discussion. I haven't a clue as what that is, but as it was mentioned in a reply to me it seems to be something I was presumed to know and/or I/we should know. Do you?
cj
cj
#40
http://www.faa.gov/regulations_polic..._signature.pdf
In addition, I quoted the entire text of proposed Part 101.41 Special Rule for Model Aircraft in my post #35 above.
#41
FL
cj
cj
#42
"We are free and in the clear, all we have to do is stay under the RADAR. We do this by following the intent of the safety guidelines. We don't have to join the AMA if we don't want to. We don't have to follow the safety guidelines or section 336 to the letter. Just stay out of the NAS and avoid endangering full scale aviation. We can soar to thousands of feet if we stay clear of full scale aviation. We can fly jets, extra large giant scale, or anything we want. Just do not endanger the NAS. How easy is that?"
The problem is what exactly is the current definition of the NAS. The FAA thinks that it extends to the ground. Property owners have justification to believe that it does not.
#43
CA
It is part of the proposed rule for Small Unmanned Aircraft Systems that the FAA put out on Feb. 15. Starts at page 172
#44
#45
CA
Community-Based Organization Law & Legal Definition
According to 20 USCS § 7801(6), the term “community-based organization” means “a public or private nonprofit organization of demonstrated effectiveness that--
(A) is representative of a community or significant segments of a community; and
(B) provides educational or related services to individuals in the community.”
(snip)
(snip)
At the DHS summit in January, an FAA lawyer said you do not need to be a member of AMA nor do they intend to define what a CBO actually is. Of course, this wasn't in writing and it was in response to an audience question I believe. (So apparently the notion that you are operating under a CBO's programming per Section 336 is a defense to enforcement but you'll have to test it...?) I'm not expressing any opinion on this point, it's just what I heard on the webinar.
#46
FL
Your OP asked a question handily answered in this thread, but the following note that I was referred to via PM and attributed to bmschulman (yes, that lawyer representing AMA in an action against FAA) is related and interesting.
As a practical matter the question that remains is Are there any Nationwide CBO's? That, and how much is it going to cost us to get an authoritative answer, as from a court?
The interesting case would be if the FAA took enforcement action against a modeler that was not an AMA member and the modeler tries to use the Public Law as a defense. That would set a precedent for the membership question.
#47
(b) Statutory Construction.--Nothing in this section shall be construed to limit the authority ofthe Administrator to pursue enforcement action against persons operating model aircraft whoendanger the safety of the national airspace system.
http://www.faa.gov/documentLibrary/m....3B_Chg_6_.pdf
#48
My Feedback: (49)
OK the AMA has been referred to as meeting the regulatory definition in: FFA Interpretationhttp://www.faa.gov/uas/media/model_a..._spec_rule.pdf
footnote 7 bottom of page 12
But the FAA assigns no exclusivity to the AMA.
Are there any other "Nationwide Community Based Organivations" that meet the definition? I believe that RCU is not a nonprofit so that would preclude them.
Ideas?
Ideas?
#49
FL
I’m sorry, but after reading all the comments here it just proves to me that something an old NTSB investigator friend of mine once said is very true, “If the FAA can sow enough confusion with legal mambo jumbo to get the aviation community fighting and arguing amongst itself, it (the FAA) can then go about changing or making rules and laws as it (the FAA) wishes before the aviation community knows what hit them.”
This also reminds me of a poster that used to hang in the United Airlines pilot’s lounge at Pittsburgh Intl Airport:
FAA mission statement: We’re not happy until you’re not happy!
