FAA Registration Website Terminology
My Feedback: (198)
I'll admit to some confusion regarding registration requirements. EVERYTHING I read on the FAA website about Drones, and about Drone Registration, makes NO mention of model aircraft.
On the registration form itself, you're supposed to select the model, manufacturer, and type of DRONE from preselected data checkboxes. Again, NO choices about any brand, breed, type, or kind of MODEL AIRCRAFT.
I'm inclined to believe that since I do not have a drone to register, and nothing on the FAA website mentions what I *do* have, that there really is no need for all the hullabaloo about this issue, if I simply comply with the Law (we talk about it as "336")
Anyone care to share with me where the FAA references are about MODEL AIRCRAFT with regard to registration of same?
My Feedback: (198)
This is the only reference I have been able to find....from the FAA FAQs:
"Q19. Updated: I would like to fly my Radio/Remote Controlled (RC) aircraft outdoors, do I have to register it?A. Yes, RC aircraft are unmanned aircraft and must be registered online if they weigh more than 0.55 lbs. and less than 55 pounds."
That makes little sense to me, as clearly it contradicts contents of 336. I know it doesn't have to make any sense; I was just hoping that someone reading this AMA forum might have authoritative knowledge with credible references.
It does go against 336, That is why the ama should be suing the faa ,,,,,,again over this, Instead we have a modeler taking them to court trying to do what the ama seems not to be doing.
http://arstechnica.com/tech-policy/2...stration-rule/
My Feedback: (198)
Thanks for the link. Good info.
Banned
My Feedback: (8)
Banned
My Feedback: (8)
The irony here is that his case mirrors that which the AMA filed back in 2014. Were you aware of this litigation? Also, the plaintiff is a multi-rotor enthusiast, which might be different than "drone driver". Not much was able to be done on that case until the FAA took the action they did at the end of last year.
Banned
My Feedback: (8)
You're complaining that another guy filed suit and was doing something the AMA "seems not to be doing", despite the fact that they are doing something, and the suits are almost identical in nature. What exactly should the AMA be doing in their lawsuit that this guy isn't doing? Have you read each of the suits?
http://motherboard.vice.com/read/faa...ew-drone-rules
To be clear, as I noted in my first response, the foundational element of both suits is the FAA's categorization of models as aircraft and the FAA violation of 336. Filing a second suit over the same point would be a meaningless and redundant waste of money and effort. And since the first suit also challenges other key points of the FAA's view of model aircraft it is the more important one.
My Feedback: (198)
Banned
My Feedback: (8)
Step away from the term "drone".
If you are flying something over .55 pounds and under 55 pounds it's now considered a UAS (unmanned aircraft system). Quad, heli, fixed wing, it doesn't matter what we call it, the feds call it a UAS and it now needs to be registered. See the numerous e-mails from the AMA on the matter, as well as the FAA, and most importantly their directions.
http://www.faa.gov/uas/registration/
1) FAA is acting contrary to Section 336. That stands for both their Interpretation and the recent registration actions.
2) FAA is incorrect in categorizing model airplanes as "aircraft" for the sake of regulation. Again, this applies to both the "Interpretation" and the registration.
336 allows FAA to take action for reckless and careless actions on the part of modelers, but AMA says that the FAA cannot define us as aircraft and then decide to apply any and all existing FARs to models.
FAA only uses "drone" in a colloquial sense but to them there is no difference between a sUAS and what is commonly called a "drone".
My Feedback: (198)
The FAA registration is for small unmanned aircraft systems (sUAS) operators. Drones is not a term that applies to anything in an official sense on the part of the FAA. FAA says our models are a type of sUAS, and therefore subject to registration.
