Never before have I ever seen anything like this
#126
NJ
Not sure that's a good idea ? FAA says to safe guard your number. Your only required to show registration to FAA personal. I'm thinking that's the reason why they say placed inside battery compartment, or inside of ACFT so long as no tools are required to access it. If someone takes your number for there own use and your number ends up on the white house lawn, let me know how that works out for you?
#127
NJ
You can make up any number you want. There currently isn't a available data base to check! The Reg/Law requires only to show proof to agents of the FAA when asked. Reason why you are to safe guard the number. By placing inside the ACFT. So long as no tools are nessarsary to read the number![QUOTE=JohnB96041;12171544]
#128
[QUOTE=stinky;12181187]You can make up any number you want. There currently isn't a available data base to check!
It will be available on-line in due time.
A local club here is on private property and property owner requires it. No problem if you don't want to provide it to the owner, you just need to find another place to fly.
