DOT and FAA Finalize Rules for Small Unmanned Aircraft Systems
OK
Bob Mc
Each rule and reg stands on it's own. If you are looking for another press release from the FAA regarding the need to register in light of Rule 107, you won't find it, as they don't need to cover that ground again. The registration is a separate rule and function. We all have access to the same info via press releases and AMA updates.
336 was drafted years before the registration process, as such the language contained in 336 would be silent on registration.
I'm not asking if you make the rules. The FAA released their Final Rules for sUAS, in it they stated Part 107 does not apply to model airplanes used for hobby/recreational purposes. They went on to state Sec 336 does apply to model airplanes and that section says nothing about registration. Both Part 107 and Sec 336 are the most current versions or they would not have been released. I simply asked you to state your source for the "Yes" answer. I registered way back in Dec, I just don't see where they still have the requirement to register, so I'm asking what your source is. You seem to have information some of us don't. I'm not looking for a squabble, I'm looking for an Official, ie FAA, reference in light of today's press release.
Bob Mc
Bob Mc
On side note I've been against this since day one but it is what it is.
Mike
Like others on this thread had mentioned, I also do NOT fly at an AMA sanctioned RC field. I usually go fly at any one of a few vacant 20-50 acre fields that are not posted. (and are very isolated with nobody around) I also plan on flying my 40"- 50"electric park-flier high wings trainers at the local public park during the week when the soccer and baseball fields are vacant with not a soul around except an ocassional jogger or dog walker.
I read section 336 of Public Law 112-95. That legal section was written February 12, 2014. So for most of us RC pilots who continue to mind our own business and not do anything more stupid or irrational then what we had not been doing since 2-12,-14 then NOTHING SHOULD HAVE CHANGED with this new law. I personally will continue to put my registration numbers on my planes. I simply enlarge the font size on my printer to about 3" long, and clear-tape it to the underside of my planes.. That should satisfy those of authority, even if the registration is not required. This way if a passing cop, or the park maintainence worker, or the hot-dog vendor, have nothing else better to do, I can politely present my official FAA registration card to them on request. ( I keep the ID card stored under the foam pad in my JR carry case). I've met people of authority who sometimes don't know jack-cr*p about things but act like they do. Usually, if you show them respect and be polite, they are happy with the 2 minutes of your cooperation you provide them, which usually satisfies their ego, and they leave you alone. But again.....nobody has ever stopped me, and I don't expect it now.
#31
Bob Mc
Bob Mc
As noted by the prior poster.
FYI that page was updated as of 6-20-16.
#32
#34
https://registermyuas.faa.gov/
Right on the front page is this question.
[h=2]Do I need to register my Unmanned Aircraft?[/h] You need to register your aircraft if it weighs between 0.55 lbs. (250 grams) and up to 55 lbs. (25 kg)
So, if your Tower trainer or P-51 is over .55pounds, I believe your question is answered.
#35
Isn't this pretty much finalizing rules for the commercial use of drones and not hobbyist? The no night flying is the reason I ask. We night fly here a lot during the summer due to the heat.
"Daylight-only operations, or civil twilight (30 minutes before official sunrise to 30 minutes after} official sunset, local time)with appropriate anti-collision lighting. "
I've asked for clarification on the AMA government relations blog and am awaiting a response.
Mike
Mike
#36
Thank you for this recent update which relates to hobbiests; http://www.faa.gov/uas/getting_started/fly_for_fun/
The bottom line is that for 2016 you need to register your toys. If you continue to fly at the local park, open field, or at an RC club and use common sense without bothering anybody (just as you have previously been doing), nothing should be different..
#37
Mike
Mike
#38
Mike
#40
My Feedback: (55)
Not sure if you are joking, or serious, or just don't understand what's been going on since last year. Hope this will help clarify the issue for you;
#42
I can see that as much of what they discuss does center on that issue. I've said all along that the commercial usage of these aircraft and the safety of the Nas was the main reason for their involvement. We got caught up in the issue through no fault of our own. I'm optimistic that the registration is as difficult as it will get for us.
#43
My Feedback: (55)
#44
My Feedback: (51)
Bob Mc
Bob Mc
http://www.ecfr.gov/cgi-bin/text-idx...=20151216y1.36
If the link doesn't work just google "faa 14 cfr part 48"
#45
My Feedback: (51)
To answer your question about what regulation requires registration of sUAS used for hobby purposes, it's 14 CFR Part 48 here is the link:
Similar to what is published in AC 91-57A, link:
https://www.faa.gov/documentLibrary/.../AC_91-57A.pdf
#46
"... if someone wants to pay you money for photos etc., you're automatically legal."
Franklin, you are but your aircraft is not. Registering an aircraft for commercial use is much more onerous than what we went through earlier this year. I looked into it for my Company's marketing department who had been using a quad for photo work. I left it with them and said "good luck."
Keep it fun,
Bedford
Keep it fun,
Bedford
#47
I don't recall ever seeing anything to indicate an AMA card was an acceptable form of identification for LEO. Additionally, the AMA does support commercial operations.
#48
I'm not saying for ID...do you really think I'm that stupid? I'm saying that when discussing qualifications etc. Having a formal FAA license that says sUAS carries quite a bit of credibility, as it's a government issued credential vice something issued by a private dues collecting organization.
#49
#50
My point exactly. It conveys nothing. When I was asked recently by LEO and responded I was following the AMA safety code, the response was "Who are they?" When I showed my FAA registration card, my FAA pilot's license, and told them who I talked to at the local class D tower, they said "Ok, you know what you're doing....have fun."
