Go Back  RCU Forums > RC Airplanes > AMA Discussions
Reload this Page >
"Heart of Ohio" frequency conflicts, BPL, and other stuff
AMA Discussions Discuss AMA policies, decisions & any other AMA related topics here.
Old 10-13-2004, 11:31 PM
J_R
Default "Heart of Ohio" frequency conflicts, BPL, and other stuff
http://www.modelaircraft.org/comp/Fr...20Dan-ver3.htm
Old 10-14-2004, 07:43 AM
P-51B
P-51B's Avatar
Default RE: "Heart of Ohio" frequency conflicts, BPL, and other stuff
Interesting read.
It looks like BPL will be not far from me....http://www.forcvec.com/bplcoop/
Old 10-14-2004, 11:16 AM
Hossfly
Hossfly's Avatar
Well, Mr. RathAr perhaps we should not be too quick to ATTEMPT to blame this incident on Broadband.
Old 10-14-2004, 03:42 PM
BillS
Gentlemen, the frequency conflicts have no need to exist and it is discussed as ‘Safety’ in the following thread.
http://www.rcuniverse.com/forum/Obso...2237504/tm.htm
Bill
Old 10-15-2004, 07:34 PM
Hal deBolt
Hi ya'll,
You should know that there is a R/C system which is virtually interference
free. Fly it anywhere, any time. How about that?
? Info and details auav.net
Hal [email protected]
Old 10-16-2004, 09:33 AM
SoCal GliderGuider
Hal, The AMA has had it's collective heads up it's behind for at least the last ten years. Don't expect a round of applause from the AMA wankers that infest this board.
I bet this incident was intentional shoot downs. Something near impossible to do with spread spectrum.
Old 10-16-2004, 10:05 PM
50+AirYears
Just been to the post. Sounds to me like the supposedly interference proof radio is still in the early developmental stage. It also sounds like there may be some technical issues to be addressed yet. It apparently is not yet available to general use. I will frankly only be interested in it if the price will be in the range of some of today's midrange 6 or 7 channel radios.
The discussions remind me of a guy at our field who was claiming that you could fly AM or FM radios on the same frequency along with a PCM at the same time, Went to demonstrate on another members ch21. Proved that the ch 21 fm wasn't affected by the maven's ch 21 PCM. However, it was a good thing I hadn't launched my Electra on ch 42 AM. Turns out the 21 PCM was ch 42 PCM. The Maven was wrong.
As far as SS, only time will tell. Price after it's commercially available for a couple years will be the determinate.
Saw a lot of interferrence in the early 60s on the CB channels, could even be proven by plugging in a cheap crystal earphone into the reciever output. Since we went to the 72 mhz band, it seems that unless someone on the field turned on on an in-use channel, most of the 'interference' I've seen has looked more like PE or equipment problems. Seems to me that interference from broadband would show up over a wide range of frequencies rather than a couple of frequencies over the band.
Old 10-17-2004, 12:29 AM
mongo
My Feedback: (15)
mongo's Avatar
"Since we went to the 72 mhz band, it seems that unless someone on the field turned on on an in-use channel, most of the 'interference' I've seen has looked more like PE or equipment problems. Seems to me that interference from broadband would show up over a wide range of frequencies rather than a couple of frequencies over the band."
amen 50.
i have "seen" a coupla "purposefull" interferance issues, but that is another story.
