Go Back  RCU Forums > RC Airplanes > AMA Discussions
Reload this Page >
Take a look!
AMA Discussions Discuss AMA policies, decisions & any other AMA related topics here.
Take a look!
Old 09-06-2010, 12:25 AM
Hossfly
Hossfly's Avatar
Default Take a look!
The AMA District VIII DVP is a busy boy!
Take a look at: http://www.modelaircraft.org/members...ecmotions.aspx
Old 09-06-2010, 03:02 AM
PLANE JIM
My Feedback: (109)
Default RE: Take a look!
alot of stuff happening Hoss-by the way I am full agreement with your U-Tube link on your signature line
Old 09-06-2010, 08:29 AM
dbcisco
Banned
I'm betting this will have to change again when the FAA/ARC finalizes the new regulations.
" change "AMA Experimental Aircraft program" to "Large Model Aircraft program".
"increase Large Model Aircraft program (formerly Experimental Aircraft program) maximum weight from 55.1 lbs.-100 lbs. to 55.1 lbs. -125 lbs. for propeller-driven aircraft, and, 55.1 lbs. to 100 lbs. for turbine-powered aircraft."
Old 09-06-2010, 08:40 AM
littlecrankshaf
My Feedback: (58)
littlecrankshaf's Avatar
It looks like Mr Rice is moving things in a positive direction. I hope this movement continues and will counter the stagnation that has become the norm.
Old 09-07-2010, 08:56 AM
KidEpoxy
KidEpoxy's Avatar
A couple of my pet peeves were hit in that meeting-
Metal Blades and 'Experimental' waiver
I mean,
if you use conventional techniques with conventional materials to build a conventional design,
if it comes out 54lb its a standard craft, but if you come out at 56 its an Experimental craft.
But a No-Wings lifing body with thrust vectoring by cam'ed torque reaction... well, its a 2lb .15 craft so that aint experimental
And I think we all know how I feel about any activity to correct the
Blades will be of no metal, no how - no where, never ever
overreaching rule.
Cant wait to see that PDF,
and see what precedents we can use to set proper requirements for other applications of metal.
Dunno know yet, havent see the Metal pdf yet
