have a AMT 180 / mercury? need help turbine
a 180 need help. Im not sure if its a 180 or a mercury but it does not have the purple front. however i have 1/2 a owners manual and this is my first turbine. I have a few questions.
1) I know it can run on jet a or keroseen but if i go to jet a do i still mix it with aeroshell turbine oil 500?
2) is aeroshell turbine oil 500 the same as BP turbo oil 2380? i have the bp stuff here in town at the local airport.
3) I have bits and pieces of a manual but would like the whole thing. Ideas where i can get a complete one?
4) The aplication I plan on useing will not be RC. So I dont need a remote. but would like to controll the throtle via a riostat. but dont know what voltages i need to operate or what wires. i figured out what harness but theres 3 wires.
5) The engine came with a AMT ASU it states in the instructons that i need a 3 way switch on the ECU to operate. there is a connector but no female conector. so all i need is to know what wire goes where in the 3 way switch.
6) I am interested in a smoke effect. if i understand this correctly all i need is to pump fuel at the tail of the motor and it will vaporize it.
Be advised I have a extensive 12volt past so I understand most electronic talk.
I thank you for any assistance you may be able to offer.
Randy
Randy
oh and what is my turbine oil to fuel ratio? anyone?
Hi Randy,
Please find here the answers:
Yes, jet or keroseen needs oil. Please mix as stated in the manual.
Yes, both have the same MIL. specification.
Hereby the link to our manual: http://www.amtjets.com/pdf/AMT%20Mercury%20HP%20manual%20scan.pdf
-The ECU is design to use RC-pulses. These pulse are 1...2ms long with a repeat time of 20ms. Please use a RC-pulse generator which can be bought on the net or schematics can also be found on the net.
As described in point 4 the ECU uses two inputs for control. One channel is for the operating switch which has three positions. Another channel is used for throttle control. Please see manual.
-Hereby a possible solution for smoke. http://www.amtjets.com/pdf/1%20valve%20smoke%20system%20using%20P2.pdf
Please beware if the nozzle is too near the exhaust the vaporized fuel will ignite. PLEASE BE CAREFUL !!!!!
the manual was a big help. i guess there is no way to install a throtle or 3 way switch with out a remote huh?
all electronics found
Previous Thread
Next Thread
