have a AMT 180 / mercury? need help turbine
a 180 need help. Im not sure if its a 180 or a mercury but it does not have the purple front. however i have 1/2 a owners manual and this is my first turbine. I have a few questions.
1) I know it can run on jet a or keroseen but if i go to jet a do i still mix it with aeroshell turbine oil 500?
2) is aeroshell turbine oil 500 the same as BP turbo oil 2380? i have the bp stuff here in town at the local airport.
3) I have bits and pieces of a manual but would like the whole thing. Ideas where i can get a complete one?
4) The aplication I plan on useing will not be RC. So I dont need a remote. but would like to controll the throtle via a riostat. but dont know what voltages i need to operate or what wires. i figured out what harness but theres 3 wires.
5) The engine came with a AMT ASU it states in the instructons that i need a 3 way switch on the ECU to operate. there is a connector but no female conector. so all i need is to know what wire goes where in the 3 way switch.
6) I am interested in a smoke effect. if i understand this correctly all i need is to pump fuel at the tail of the motor and it will vaporize it.
Be advised I have a extensive 12volt past so I understand most electronic talk.
I thank you for any assistance you may be able to offer.
Randy
Randy
RE: have a AMT 180 / mercury? need help turbine
Hi Randy,
Please find here the answers:
Yes, jet or keroseen needs oil. Please mix as stated in the manual.
Yes, both have the same MIL. specification.
Hereby the link to our manual: http://www.amtjets.com/pdf/AMT%20Mercury%20HP%20manual%20scan.pdf
-The ECU is design to use RC-pulses. These pulse are 1...2ms long with a repeat time of 20ms. Please use a RC-pulse generator which can be bought on the net or schematics can also be found on the net.
As described in point 4 the ECU uses two inputs for control. One channel is for the operating switch which has three positions. Another channel is used for throttle control. Please see manual.
-Hereby a possible solution for smoke. http://www.amtjets.com/pdf/1%20valve%20smoke%20system%20using%20P2.pdf
Please beware if the nozzle is too near the exhaust the vaporized fuel will ignite. PLEASE BE CAREFUL !!!!!
the manual was a big help. i guess there is no way to install a throtle or 3 way switch with out a remote huh?
