AMT Netherlands Get support for AMT Netherlands products here.
2.0b ECU PARAMETERS ADJUST
Reply
Old 10-26-2011, 11:33 AM
jsouza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 2.0b ECU PARAMETERS ADJUST
Hi, all!
I've got an Electric Start Pegasus that came with 10S 12v NiCad battery pack. When the battery needed to be replaced, I installed a 4s LiFe pack.
For my surprise, the glow plug voltage changed to 3,8 volts and it is turned on (and melted) by the ecu at the time the switch is turned on.
Even with the melted glow plug there is no burned glow plug warning at the EDT.
As I don't have the cable to connect the ECU to the PC, is there any other way to recalibrate, adjust or even reset the ECU?
How can I adjust the ECU?
Jones
jsouza is offline
Old 11-17-2011, 07:19 AM
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 2.0b ECU PARAMETERS ADJUST
Make a cable, and D/L the software from AMT.
Dr Honda is offline
Old 11-22-2011, 03:44 AM
jsouza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Dr Honda!
I've already downloaded the software from AMT's web site, but I'm not sure how the cable should be.
Do you know if the usb adapter cable sold by Xicoy will work?
Otherwise could you post the connectors scheme so I can make a cable by myself?
Jones
jsouza is offline
Old 11-22-2011, 05:49 AM
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not exactly sure what's in the Xicoy cable, so I wouldn't try to use it. The cable pin out on the ECU should be in your manual... but if it's not, I'm posting it below. If you don't have an serial port... you can get a USB serial adapter.
I made a cable when I first got my engine, and it worked fine. (about $8 worth of parts at an electronics shop)
Dr Honda is offline
Old 11-25-2011, 10:24 AM
jsouza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dr Honda,
I will make the cable and adjust the ECU parameters!
Once again, thank you!
Jones
jsouza is offline
Old 02-02-2012, 12:09 PM
jsouza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dr Honda,
I've got the software and cable to adjust the parameters of the ECU. After following the instructions, I changed the glow plug parameters to lower values, saved the new values in the ECU, checked with the "handshake" buton if the new values were recorded with a positive result. I mean, the computer is properly connecting with the ECU, and the software funcions seems to be working fine.
BUT, the current to the glow plug doesnt change at all!
Every glow plug I install is burned at the first start atempt. It is happenning with my TWO AMT Mercury engines with 2.0 ECU.
I am using 4S LiFe battey and JR 12X radio.
These are the only changes that were made: new battery (LiFe 4s instead of Nicad 10s) and radio JR 12X that replaced the 10X.
The insteresting point is that I tried the old 10S NiCad pack and problem still occurs.
What can be wrong?
Jones
jsouza is offline
Reply
Display Modes
