AMT 450 woun't go out the starting mode
Hello
I have problems with my AMT 450at. It does start but very slowly and it does not get in to the running mode.
To me that should not be any flames out that tail?
[youtube]http://www.youtube.com/watch?v=20arCQO-U2c&feature=youtu.be[/youtube]
http://www.youtube.com/watch?v=20arC...ature=youtu.be
PA
RE: AMT 450 woun't go out the starting mode
Is this an air-start?
Once it ignites... try to put a little more propane on it. I know my 180 needs a small amount of propane to light... and then I have to turn it up to get it to spool, and start.
I switched off the propane when i saw that the fuelpump started and the egt was rising. The engine slowly goes up to 600C and stay there and the ecu woun't let me throttle the enging.
Yes the fuel goes in to the F and L port on the engine. The propane is on the G port.
Do anyone know how i get the stainlesssteel boddy of the engine. I have removed all the screwes and it does not move at all?
Everything is good now. The first problem was me turning of the gas to early and the seconde one was a to smal feed line from the tank to the pump.
