AMT Netherlands Get support for AMT Netherlands products here.
AMT Mercury start up
Reply
Old 12-26-2008, 10:25 PM
frankie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AMT Mercury start up
Hello guys, I've noticed lately that my Mercury HPES will take a little more time for the first start up of each session. That is, if the turbine hasn't been started for around a month,
the very first start attempt will use a lot of gas, and it will probably start on the second pulsation of gas. When it does start there will be a pop to indicate that a large amount of
gas has just ignigted. I havn't tried to remedy the issue as yet, just wanted to get some opinions first. I thonk it may be the plug.
Cheers, Frank.
frankie is offline
Old 01-17-2009, 08:50 PM
Mark Taylor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AMT Mercury start up
Yes, you are right. Try replacing the plug first.
Mark Taylor is offline
Old 01-25-2009, 05:25 AM
Cleofox3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, what I had with a Pegasus Turbine, is that after some 2 years of use, it had more and more problems to ignite on gaz, especially the first start of the day.
It happened to be that some, in the combustion chamber, gaz diffusors were stucked from combustion deposits... Thus the gaz wouldn't spread regularly and ignition was hard to achieve.
The solution was given from the Swiss AMT Representant, Mr Franz Wälti from Jet-Tech, you should inject compressed air at 150 to 200 bars through the gaz inlet for about 30 seconds.
This will clean the diffusors. After that, my turbine started again on the first attempt.
The problem is to get a little tube to connect the air bottle and the turbine at 150bars....
Might be good to try... Good luck.
Cleofox3 is offline
Old 01-28-2009, 10:06 PM
frankie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you gentlemen for your replies.
I've been on holidays so I havn't tried either remedy yet. The heat here is unbearable at the moment. I will keep you posted as soon
as I try either.
Thank you for your time, best regards, Frank.
frankie is offline
Contact Us Archive Advertising Cookie Policy
