AMT Netherlands Get support for AMT Netherlands products here.
which bearing could be fit to JetCentral SuperBee
Reply
Old 08-16-2009, 01:22 PM
jassli
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default which bearing could be fit to JetCentral SuperBee
Anybody knows which bearing could be fit to JetCentral SuperBee.
bearing specification, bearing maker, bearing type... any info will be helpful.
Thanks a lot.
jassli is offline
Old 08-22-2009, 01:01 PM
yf222000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: which bearing could be fit to JetCentral SuperBee
Take a look at Boca bearing site. They have a list of turbine manufacturers. here's the link.
http://www.bocabearings.com/main1.as...crossref&pg=10
From what i understood. Most brand of turbine uses the same size diameter bearings for specific
turbine thrust class. Either D608/602C or D688/602C
The smaller the turbine, the bearing size will be D688/602C. Typically ranging from 7lbs to 15lbs thrust
D608/602C for turbines 16lbs and up.
yf222000 is offline
Contact Us Archive Advertising Cookie Policy
