AMT Netherlands Get support for AMT Netherlands products here.
ANT Netherlands SOftware and Windows 7
Reply
Old 12-12-2009, 08:33 AM
pfact
My Feedback: (91)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ANT Netherlands SOftware and Windows 7
Anyone out there running AMT Netherlands Software in Windows 7?
I can get the program to run but when I attempt to connect to the ECU for an Olympus I get a lost signal error message (presumably due to loss of signal from the USB-serial port connector that runs through Com3).
I am not very PC savy and don't know how to work through this problem.
Phil
pfact is offline
Old 12-12-2009, 11:50 AM
Didier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ANT Netherlands SOftware and Windows 7
Hello.
I had a simulair problem with windows XP but after downloading new drivers for my usb-serial port connector, all was ok.
Hope it helps.
Didier is offline
Old 12-13-2009, 09:11 AM
pfact
My Feedback: (91)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Didier,
The drivers were the problem - there was a conflict amongst USB-serial adaptor drivers that was easily fixed.
The software works with Windows 7
Phil
pfact is offline
Old 12-17-2009, 08:00 PM
ogm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have this problem also. Can you please let me know where I find the newer USB-serial adaptor drivers for XP?
ogm is offline
Old 12-17-2009, 08:58 PM
pfact
My Feedback: (91)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ogm,
You need to use drivers for the chipset in your particular adaptor, doing so requires that you go to the web site of the manufacturer of your adaptor (in my case it was commfront.com). I first used a Belkin adaptor but it turned out not be compatible with Windows 7.
Too bad Bennie doesn't make software that works on a Mac - this would be easy.
Good luck,
Phil
pfact is offline
Old 12-17-2009, 10:26 PM
ogm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Phil
I connected the 3 Futaba cables to the wrong pins on the serial port. It is working now. Manual do not provide any help on how to setup initial parameters , etc, etc. When I go to the Trust Management tab and change to Pegasus, software do not keep my settings. How you use this software?
ogm is offline
Old 11-18-2011, 07:17 PM
Springbok Flyer
Springbok Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
Perhaps one of you can tell me what the speed setting is for the comport?
JanR
Springbok Flyer is offline
Old 11-18-2011, 09:43 PM
Skycat66
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Baudrate is 2400.
Skycat66 is offline
Old 02-07-2012, 11:16 AM
jsouza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ray,
I've sent an email for you regarding problems I  am having with an 2.0 ECU.
I would appreciate a lot if you could help me
Jones
jsouza is offline
Old 02-09-2012, 10:26 PM
Skycat66
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Everybody,
New version of TMC application will be available on AMT website next week. It special build for smaller notebooks (10")
Regards,
Ray Struik
AMT Netherlands
Skycat66 is offline
Old 02-10-2012, 10:27 AM
jsouza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ray,
Did you receive my e-mail? If not, I can send It as a PM.
Jones
jsouza is offline
Contact Us Archive Advertising Cookie Policy
