AMT Netherlands Get support for AMT Netherlands products here.
MercurySP and Pegasus MK3
Old 03-20-2010, 07:37 PM
Plautos's Avatar
My Gallery
My Models
My Feedback
Default MercurySP and Pegasus MK3
Hello people!
I need help! Some of my engines need maintenance.
I'm from Brazil and I have two AMT 180sp and two AMT 280.
I'm getting no answer from UsMicroJet or Netherlands. Do you know someone with I can talk?
Here are my problems:
The ECU from one 180sp only works with 11volt batteries. If I try the 7,2v I will get an error message. Supply Low error.
This same ECU fluctuate the EGT. It suddenly read the temperature to -50 Celsius and goes back to normal. It is not the thermocouple.
I couldn’t test it with the working order ECU but the engine fluctuate the thrust in middle range and when I move back the throttle. It sounds like a hi-pressure air hose with no one holding it.
The ECU from one 280 make the engine stall if I throttle up too fast and only goes to 110K rpm probably ECU software version.
One 280 engine have a serious mechanical problem. It is overheating badly. It is passing 1000Celsius. I know it is the engine, because I test it with the other one components.
If someone could help I will be glad.
Plautos is offline
Display Modes
Contact Us Archive Advertising Cookie Policy
