New Great Planes Escapade 61.
Reply
Old 04-23-2011, 01:17 PM
  #226
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Great Planes Escapade 61.
My Escapade is coming along , Have the DLE20 mounted and servos in.
Waiting on carbon fiber gear to give better prop clearence for 17" prop.
here are some pics as of right now.
jcb9901 is offline
Old 04-27-2011, 06:33 AM
  #227
blue77
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JCB I'm getting ready to do the same thing...any updates? Thanks WC
blue77 is offline
Old 04-27-2011, 01:59 PM
  #228
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: blue77
Still waiting on my landing gear,going to use these http://www.graphtechrcshop.com/produ...&categoryId=21
Here are some pics of my setup using 1500 NIMH 4.8v ignition and 2300 A123 6.6v on reciever with rcexl opto killl
balance at 4" right now with no added weight,but that may change with the carbon gear.
hoping to get gear friday so I can maiden it this weekend. Ran 2 tanks of fuel through motor and turning 17x6 vess 8250 rpm can't wait to see what hte motor can do once broke in.
jcb9901 is offline
Old 04-30-2011, 08:41 PM
  #229
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maidened my plane today and flyes like a dream.
Motor is running great and plane has no bad habits 10ft take offs
jcb9901 is offline
Old 05-08-2011, 06:29 PM
  #230
WindGap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you believe that the muffler with fit within the cowl?  Please be sure to post a pic ounce you have it on.
WindGap is offline
Old 05-09-2011, 06:19 AM
  #231
***FAZ***
***FAZ***'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi to all,
What do you think of a Saito 1.00 engine on the Escapade .60?
Yannis
***FAZ*** is offline
Old 05-09-2011, 06:57 AM
  #232
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Saito 100 will do a very nice job of flying it.
MinnFlyer is offline
Old 05-09-2011, 08:56 AM
  #233
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: WindGap
The DLE20 won't fit in cowl with stock muffler, You may be able get a JTEC wrap around pitts to fit.
jcb9901 is offline
Old 05-09-2011, 02:58 PM
  #234
WindGap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I checked the dimensions from troybuiltmodels.  It clearly shows the dimensions.  Can you do a quick check to see whether it will fit, before I splurge?
WindGap is offline
Old 05-09-2011, 03:50 PM
  #235
padlock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried to put a bison pitts with a supertigre G90 inverted on mine and destroyed the cowl. The cowl narrows up real quick on both left and right and bottom. Basically the tube stuck out both sides and cut the bottom of the cowl away.
sbdwag
padlock is offline
Old 05-10-2011, 04:24 PM
  #236
welder101
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just purchased this plane today and plan on putting a Enya 120 four stroke in it. Is anybody else running an engine this size?
welder101 is offline
Old 05-10-2011, 05:57 PM
  #237
crash1ace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Escapade is almost done! Cant wait to try it out.But I'm trying to decide on a proper prop to use. I've decided to use a Thunder tiger Pro-61 for my engine choice, but I am
now trying to decide on either using a 11x6 prop(APC) as recommended in the engine instructions ior Ive been told to try a 12x7 prop. I need some help here. So who is using a
60 size motor like me, and what prop have you had sucess with? Thanks!
crash1ace is offline
Old 05-15-2011, 11:13 AM
  #238
garyferguson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is my Escapade 61 , Has three flights on it with a Satio 125 added perry pump to help with fuel delivery to carb, 15x8 prop, more than enough power.
garyferguson is offline
Old 05-15-2011, 07:23 PM
  #239
fast_eddie70
fast_eddie70's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello JCB9901
How did your plane balance out?? Was it nose heavy with the DLE? Did you add any weights to the Tail?
fast_eddie70 is offline
Old 05-15-2011, 07:43 PM
  #240
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: fast_eddie70
Hello JCB9901
My balanced out perfect at 4" with no weight added, you can see where I put everything in pics.
My plane weighs 8lbs 9oz
jcb9901 is offline
Old 05-16-2011, 01:55 AM
  #241
***FAZ***
***FAZ***'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi to all,
It seems of being camouflaged with blue-white colors. Would be the colors of the blue-white sheme like non so visible in the air?
Old 05-24-2011, 11:35 AM
  #242
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, today I maidened my Escapade 61. The engine is a new Fox .74 Eagle IV. Both the plane and engine performed perfectly. The takeoff was smooth and straight with about a 7 mph crosswind. I started slow with up elevator. Once it started to pick up speed I let off the elevator and the tail came up at half throttle. I held it on the gound until full throttle was reached and then fed in a small amount of up elevator for a classic takeoff. The only trim required was 1 click of left aileron. I flew around for about 5 minutes. The plane flew like my Pulse XT 60 but with more spirit. This was only the third tank through the engine so it will be a few more tanks before I attempt to wring out the plane. On landing the plane came right down the center of the grass runway with a nice natural glide slope and with a slight flair it touched down for a clean wheels landing. The roll out was about 100 feet.
I used the fiberglass cowling and it gives the plane IHMO a sleek look. The changes I made from the kit are:
1. Fiberglassed the landing gear mount.
2. Used Robart Super Ball Horns on the rudder and elevator. This eliminated the sloppy fit of the clevises in the original control horns.
3. Used DuBro Ball Clevises on the ailerons to eliminate binding and the sloppy fit.
Bruce
landeck is offline
Old 05-25-2011, 04:40 PM
  #243
RealViking
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What a day, brought out the Escapade, Way fast with the Jett .76.
Here is a couple of pictures in the air.
25 clicks of down trimmed the flapperons perfectly. A charm to land with or without flaps.
ID:	1614563   Click image for larger version
RealViking is offline
Old 06-18-2011, 09:44 AM
  #244
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been flying my Escapade 61 for a few weeks now and it flys great except that it does not want to slow down on landing. I have it balanced where the book calls for and that is 4 inches from the wing leading edge. I am going to move the CD back in 1/8th inch increments but I was wondering what you all ended up with as the CG?
Bruce
landeck is offline
Old 06-18-2011, 10:04 AM
  #245
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mine is at 4" and mine slows down just fine
jcb9901 is offline
Old 06-21-2011, 01:35 PM
  #246
sgrady
sgrady's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you guys think a Saito125 is too much for this plane ?
sgrady is offline
Old 06-21-2011, 02:34 PM
  #247
jcb9901
jcb9901's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sgrady
I think you'll be happy with a Saito125
you will need to change landing gear if running 17" prop
jcb9901 is offline
Old 06-22-2011, 04:39 AM
  #248
garyferguson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I Have a Saito 125 on mine with a 15x8 prop fly's very well, However i had to put a perry pump on it because of the carb being to high in relation to centerline of tank , it would not run right untill I installed the pump. Also Had to get a true turn spinner and trim to fit bigger prop.
Old 06-22-2011, 04:43 AM
  #249
garyferguson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is some more pictures of mine. With Saito 125
ID:	1626259   Click image for larger version
ID:	1626260   Click image for larger version
ID:	1626261   Click image for larger version
ID:	1626262   Click image for larger version
ID:	1626263   Click image for larger version
ID:	1626264   Click image for larger version
Old 06-22-2011, 07:12 AM
  #250
sgrady
sgrady's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice
sgrady is offline
Reply
Display Modes
