Kyosho Sukhoi
Kyosho Sukhoi
Has anyone had experience with the Kyosho Sukhoi Breitling 40 ARF. I really think that this is one of the best looking ARF's that I have ever seen and I was interested in buying one with I get to that level. If you know of any problems that the plane has such as the quality or the flying characteristics. Just so I don't waste 230 dollars on an airplane that will fall apart on the first flight.
MO
Kyosho Sukhoi
A guy I fly with has one. The only negative if you can call it that, is you need to land it a little hot or it will stall. If you are a smooth flyer, this plane really shows it in the air. Everyone watches this one fly when it goes up. Looks great.
MO
sukhoi
I have this plane also and a little speed is needed when landing. Other then that mine flies great. I have a saito 91 hangin off the nose. I know the spec's say 53 four stroke but dont waste your money. I started with a 72 saito and that wasn't stellar performace. It flew it arround well but thats about all it did. The 91 is much better, less take off roll, 400 ft loops are a piece of cake, and unlimited vertical. Hardly any wieght difference, a few dollars in price, and good power increase. If you go with a 2 stroke a 61 would be the smallest (I) would use. As far as quality you wont be dissapointed and the only way it's commin apart is if you cause it. Stick to the elev throws, built it straight and you will be impressed. Dont let the landing speed talk scare you away (M.A.N. mag) it's not that bad..........Dave
Re: sukhoi
Adrian
MO
Kyosho Sukhoi
I don't know about this one, but if the firewall is predrilled for blind nuts and you don't like the mounting position, just epoxy in a dowel of the correct size, the re-drill the firewall to your specs-I have done this several times. HTH
MO
Kyosho Sukhoi
The firewall is not predrilled so you can mount your engine any which way you like. Depending on the size of your 2-stroke, you may or may not have to cut out the clearence for the head....Dave
Kyosho Sukhoi
Adrian
My Feedback: (7)
NY
Kyosho Sukhoi
Originally posted by x86guru
Any idea if a .61 FX would fit at 90 degres with a Pitts muffler (Would the head clear the cowl?)
Adrian
Adrian
I have this setup in my Kyosho Cap and it fits completely in the cowl so I wouldnt think it would be a problem in the Sukhoi.
Tim
MO
Kyosho Sukhoi
Tough call there, I do know that my saito 72 stuck out arround 3/8 in or so. If you could get the distance from the crank centerline to the top of the head for your 61, I can measure the inside diameter of my cowl. Or I can dig out the manual for my 72 and give you that measurement. Let me know........Dave
