Black Horse Pitts
RE: Black Horse Pitts
Just that the kit recommended cg is way forward of the lower wing leading edge. I plan on trying mine where it is which is just about 1" in front of the lower wing. I have a DLE30 in mine and it is just 12 pounds.
Cheers
Cheers
My Feedback: (21)
ORIGINAL: bps
Just that the kit recommended cg is way forward of the lower wing leading edge. I plan on trying mine where it is which is just about 1'' in front of the lower wing. I have a DLE30 in mine and it is just 12 pounds.
Cheers
Cheers
Here are a couple of my DLE30cc posted on another forum. Looks like this plane needs nose weight to ballance if the specs are correct. I am still working on verifying that. Prop is 18x8 and plane tips the scales at a tick under 12 pounds. Receiver battery is 2a 6 cell NiMI and the ignition battery is 2A 4 cell. NiMI.
#36
ORIGINAL: ado9518
HI kerwin, here are some pictures of my setup. I'm going to pull out that big chunk of lead up front to move CG back.
Have nice fligths!
Have nice fligths!
Thanks for posting.
#38
Flew her last sunday with CG about 110mm (4.5") from l.e. of upper wing. It feels a litte "lighter" on sticks and I like it more than my original set up.
I feel it could be safely moved furter back, but for the moment I prefer leaving it as is and experiment with it.
Inverted flight is still a bit difficult, maybe due to the semi symmetrical wing section. Iwill increase control throws on both elevator and rudder.
When are you going to maiden yours?
#39
Congratulations on a successful flight. Can I ask what prop your using and how many rpm's? I think this flight shows us just how far forward the recommended cg is. What do you mean by inverted flight is a bit difficult? Also how were the landing speeds? Some that have flown with the recommended cg say it lands hot, which could be an indication of a nose heavy plane.
I just need to get a receiver and my plane is ready. As good looking as this plane is I am growing tired of looking at the plane on the work bench ready to fly! I have been working hard trying to get a 1/42 scale space shuttle ready for an American Diabetes fund raiser our club hosts each year.
Also do you transport yours assembled? Mine will fit in our van but just barely!
#40
Prop is 18x6, but I didn't actually measure rpms. My home made muffler reduces rpms if compared to the one that comes with motor, but is definitely quiter. Full power is not a concern: can loop and do big split S at less than 1/2 throttle and climb out of sight at full. Didn't try hovering (pilot's fault ...) but Ifeel it could.
Inverted flight requires a lot of down elevator. It's not able to fly an outside loop, but now elelvator has a throw of 15mm only; I will increase throw to 25 mm and see what happens.
Landing speed is similar to a low wing sport plane and I wouldn't say it's hot.
Yes, Itransport mine assembled. It's quite a tight fit in the trunk, but mounting at he field would require too much time
#41
OK
Fellas,
I just found this thread and this is my first post, so "Howdy" and...I have the BH Models Pitts, bought it Feb 2011 at Hobby People in Camarillo, Ca. I travel to Ca frequently on business(iman Oklahoma boy). Mine is CG'dutilizing the mean aerodynamic chord dueto the top fwd wing beinga swept back design. I dont have theexact measurements, but IIRC its roughly 1" back from the LE of thebottom wing.This dosnt apply much to static CGBUT,be advised, for an ARF(engineering should be already done) my wing incidences were totally incorrect and for that matter, were backwards. RC airplanes can be setup to whatever the userwishes for that matter, positive stability, point click,0*0*but IMO if you want to reap/enjoy the benefits of a truebipe then wing incidences are"crucial".My wing incidences outta the box were:
Top RH 1.0*+
Top LH 1.1*+
Bttm RH 2.5*+
Bttm LH 2.5*+
IMO these are totally backwards. If you were to fly in this config,whileslowing for approach your bottom(or aft wing in the Pitts) would stall first,(now your flying on the top FWDwingonly)causingCG to moveAFT which "could" cause the model to violently pitch nose high. Combine that with low altitude, on a slowapproach speed and alawn dart it becomes. IMO youd want the TOP(orFWD wing in a Pitts) to have the higher wing incidence forcing it tostallFIRST(now your flying on the bottom AFTwing only)whichmoves the CG FWD, causing the model to gently nose over on approach as your speed decreases. Mine is nowhere near perfect, but flies inverted with minimal elev, inside/outside loops, rolls, knife, knife loops...This model will do it all, just needed some tweeking....Curently mine is flying "ok" with:
TopRH wing: 2.5*+
TopLH wing: 2.6*+
BttmRH wing: 1.5*+
BttmLH wing: 1.5*+
Running 6*DT with roughly 4* RT...currently running aST G2300 17x6 prop
Sorry for the long rant as a first post, but grab your incidence meter and at least verify em before you chase CG and badflight charateristicsall day. Im still dialing mine in, but for the most part Im happy with it. Im just a picky setup kinda guy...Again fellas, these are just my opinions, aerodynamics isnt rocket science and models fly just life the thefull scale realones do. In flight its all a balance about the center point of lift, a flying teeter totter!
I have pics and a flight vid Ill post when I get home this afternoon..
Id like to hear what incidences you guys are in fact running too.......
Top RH 1.0*+
Top LH 1.1*+
Bttm RH 2.5*+
Bttm LH 2.5*+
TopRH wing: 2.5*+
TopLH wing: 2.6*+
BttmRH wing: 1.5*+
BttmLH wing: 1.5*+
#42
MO
Most of the biplanes I've flown have a positive decalage. That is the top wing is positive to the lower wing.
The postive gives the plane more lift.
#43
OK
ORIGINAL: kerwin50
True....Decalage is the angular diference in incidence between the upper and lower wings, obviously relative to the h-stab, but generally speakingdecalage is normallypositive. I wouldnt say having a higher decalage number provides "more" overalllift, but it would offer a higher AOA. Would also increase the drag beyond a certain point. Youd still have to offset it all with the proper DT if you wanted...
#44
MN
#49
MO
Now bps That DLE 30 will pull that plane around like a rag doll.
Mine with a 18/6W has 19.6 pounds of static thrust.
I have it in a 10 lb 3 oz plane and it has no problem hovering it at 1/4 throttle.
She is going to have an INSANE amount of power
