Reload this Page >
Seagull 1.20 PT-19
Seagull 1.20 PT-19
Old 11-15-2012, 06:24 AM
  #126
NoFlaps
My Feedback: (131)
Default RE: Seagull 1.20 PT-19
Okay, I've started the recovering process and I now remember why I was so hesitant to strip her down.
Coverite (fabric covering) isn't as easy to work with as the plastic Oracover type films... It's very easy to press too hard, damage the balsa and leave mars where the Iron had dragged across (not supposed to drag it across the fabric whereas it's okay to do that on the plastics)...So maybe I'm a lil' rusty - but hopefully it'll end up being close to looking like a factory job. [Man, those guys in vietnam sure did a clean job of covering the plane- I guess after doing a few hundred, mine might look that good too].
The tail is almost completed and with some luck, I'll have the wings or fuse come by this weekend.
Old 11-15-2012, 02:07 PM
  #127
BlackPhantomDragon
Hope you post some pics NoFlaps.
Should look good when your finished.
Regards Greg
Old 11-20-2012, 05:07 AM
  #128
BlackPhantomDragon
Did some more work. Finished the firewall mods and coated in epoxy resin that went a bit funny. May have been the heat and humidity?
Looks ok and sealed so that's the main thing
Old 11-20-2012, 05:11 AM
  #129
BlackPhantomDragon
Got a new Fuel dot and vent line exit from DA today. Hanger 9 product. Best fitting dot I have had. Look good as well.
Old 11-20-2012, 05:19 AM
  #130
BlackPhantomDragon
Also Bought a new Ignition switch and installed in front cockpit.
I finally decided to add some ply to the side of the box and bolt to the floor like the rear. But had already installed the fuel tank platform so had to take a bit out.I installed 2mm T-nuts so could screw 2mm bolts and washers to lock the switch housing down so can take out if need be. Also have made a place to mount the LED off the opto kill switch so when turning the ignition on U can see it is live.
Back item is template to cut holes in floor of cockpit.
Old 11-26-2012, 04:03 PM
  #131
sapspit
Hi,
My friend did maiden his electric PT-19 on friday. I filmed his maiden. Still have to add windscreen etc. The plane was nose heavy, but flew fine.
Here is a link to the video:
http://www.youtube.com/watch?v=b-3XiJ1lono
Cheers,
Terje
Old 11-27-2012, 02:47 PM
  #132
panouas
Hi Terje,
thanks a lot for your video! This proves that this model is able to fly!
I'm almost ready with my makeover. I still have to do a bit of weathering and install the engine and electronics.
Two more weeks and my seagull pt-19 is ready for the first flight!
Regards,
Panos.
ID:	1824211   Click image for larger version
ID:	1824212   Click image for larger version
Old 11-27-2012, 04:11 PM
  #133
sapspit
Hi Panos,
Your recovered model looks great!
I will receive mine on Thursday. I will rebuild it to a Norwegian PT-26 used in Little Norway Canada during WW2. I will add a canopy + Norwegain decals etc.
I think the oleo struts (landing gear legs) looks a bit too long. I will consider changing them as well.
Brgds
Terje
Old 11-27-2012, 07:41 PM
  #134
BlackPhantomDragon
Hi Panos
Looks really good.
Will wait for the flight report
Regards Greg
Old 11-28-2012, 01:22 AM
  #135
panouas
Hi,
thank you all, yes the landing gear legs are very long (it looks like a German aircraft)!
If I like the flying characteristics of this model and decide to keep it I will also replace the long landing gear legs and the windscreens (they are to big) as well.
A pt-26 version is a good idea!
regards, panos
Old 12-28-2012, 02:48 PM
  #136
panouas
Hi,
finally yesterday I was able to fly my PT-19 for the first time!
This model flies very good, easy, smooth, scale! I will keep it!
Enough power with the 120 OS four stroke, most of flying is done with 3/4 or less of the power.
All up weight 5,2 kg.
Flaps are nice put not really necessary, this model can fly very slow for the landings with out using the flaps.
Some pictures...
ID:	1834260   Click image for larger version
ID:	1834261   Click image for larger version
ID:	1834262   Click image for larger version
ID:	1834263   Click image for larger version
Old 12-28-2012, 08:08 PM
  #137
Chad Veich
My Feedback: (60)
Very nice panouas and a beautiful flying field as well. Best of luck with your PT in the future.
Old 12-29-2012, 01:35 PM
  #138
landeck
panouas, that is one outstanding airplane! Congratulations on a job well done.
Bruce
Old 12-29-2012, 02:02 PM
  #139
AA5BY
I'll add my kudos for a job well done and much thanks for sharing with us... I enjoyed.
Old 12-30-2012, 03:04 AM
  #140
panouas
thank you all.
Old 01-15-2013, 12:11 PM
  #141
NoFlaps
My Feedback: (131)
Wow...That was impressive !
I finally got mine covered and decided not to be particularly scale- given I want to fly her and I realized it'll take more time than what I'm prepared to put into it. I decided to go with a favorite paint scheme of mine: From the 308th Fighter Squadron, 31st Fighter Group, 15th U.S. Army Air Force, in Mondolfo, Italy, November 1944- This is a scheme typically seen on P-51's but I thought this baby would look nice in this paint-job.
So Aside from the Silver Corerite fabric, the rest is paint with vinyl letters and "Major" Brand Stars & Bars.
I've opted for Dubro pin hinges, but the rest is pretty stock
ID:	1840767   Click image for larger version
ID:	1840768   Click image for larger version
Old 01-15-2013, 12:23 PM
  #142
NoFlaps
My Feedback: (131)
I have a whole schlew of pics from when I stripped her bare- but I'll focus on the covering/ completion. i can send anyone pics if one is so inclined:
Old 01-15-2013, 12:39 PM
  #143
NoFlaps
My Feedback: (131)
More pics:
ID:	1840791   Click image for larger version
Old 01-15-2013, 12:50 PM
  #144
NoFlaps
My Feedback: (131)
Last pic for the day: - It's finally starting to look more like a PT-19- although fictional markings- I really like the way she's coming together
I haven't decided on the engine since i don'r want to hack up the cowl.
I have a FPE21cc, a DLE20cc and am considering an NGH25cc...Unfortunately the FPE21 has a side carb, but since the rest of the plane isn't super scale- maybe I shouldn't care.
Old 01-15-2013, 02:46 PM
  #145
panouas
Looks very good!
Nice paint job and color scheme!
Old 01-17-2013, 04:34 AM
  #146
BlackPhantomDragon
Hey No Flaps the scheme looks great.
Would not know that it wasn't painted like that originally just looking at it,
Looking forward to seeing some more pics.
Mine is back on hold just at present, Just finished out fitting my new trailer and half way through a 46-55 Phoenix Sbach as I wanted another plane to just fly every weekend and practice a few maneuvers with.
I just need to fitt the cowl , pilots , windshields etc and balance. Then test run the motor, Then we will see if it was all worth it. so to speak. Looks like every one that have flown have been happy with them
regards Greg
Old 03-25-2013, 06:23 AM
  #147
NoFlaps
My Feedback: (131)
Here she is at the RC field this weekend...
Didn't get to fly her due to some aileron twitch that I couldn't get worked out.-Did a bunch of taxi tests and more engine run ups. With the DLE20, she wants to jump in the air...I had to keep the rev ups limited to short bursts. Will sort out issue with aileron over the week and depending on weather- maybe a maiden next week
ID:	1866380   Click image for larger version
ID:	1866381   Click image for larger version
ID:	1866382   Click image for larger version
Neuhausr (09-19-2020)
Old 03-25-2013, 06:36 AM
  #148
BlackPhantomDragon
Hey no flaps she really looks good. Very impressed.
How did you get the DLE 20 completely in the cowl. Can't see it poking out any where.
I had to cot the side out for the pitts.
Hope to have mine running this weekend when our field reopens after it flooded in January.
Love to see some shots of the cowl and motor install.
regards Greg
Old 03-25-2013, 10:21 AM
  #149
Spitfire7856
Hi
Thanks for the great pics and info. So you are comfortable that a DLE 20 would fit in the airplane! Can you tell me the width of the fuse at the firewall. Would really appreciate it.
Thanks and regards
Old 03-26-2013, 12:07 PM
  #150
NoFlaps
My Feedback: (131)
I'll get pics of it this weekend. Fits nicely though. I've been worried about the cooling but she didn't overheat durring the RCU tests and all went well.
The dle20 is more than enough fit this bird for sure.
