world model trainer
My Feedback: (10)
world model trainer
hi
ok this is my 3 world models trainer one i had for 6 years i retied it for it was oil soaked and the second one my son was training on and she when in now comes the new thrid one its been a long time between buying this type of trainer will they change it a little but i use the same things OS46 ax when we went to trim her out she was climbing like a rocket i did balance her a little nose heavy had to add a lot of down trim one guy said the stab look like it was pointing down in front so it would act like a elevator how would i check this or should i put some washers under the rear of the motor ,thanks rye
RE: world model trainer
with out seeing it or a pic i would put a couple washers on the top mount of the motor or you might even check the main wing sadle it could be off a little allso worth a check
