NEW HANGAR 9 CHRISTEN EAGLE
#101
NY
I may have a solution to your problem extending the exhaust tubes on your Pitts style muffler. I recently completed a Christian Eagle with a O.S. 1.20 4C engine. The engine is side mounted which allows the muffler to stay within the cowl. It is pointed down at an angle and toward the firewall but stops a couple of inches away from the firewall. I purchased some silicone tubing 3/8" ID X 5/8" OD and zip tied 8" to the end of the muffler. The tubing bends slightly as it exits the bottom of the cowl. Your installation might be neater with a Pitts style muffler. The tubing will probably come straight out. If the ID works on your muffler I can send you some. Just let me know how much you need. Otherwise, you can look for a different size at www.usplastic.com.
#102
Make sense? This way, I only have to cut enough of the cowl to allow for cooling airflow. I saw the DLE20 set-ups on this thread and yikes! That's just brutal. the only thing sticking out of my cowl will be the needle valve and the exaust stubs. Just my way, I guess. I expect my Eagle to weigh less than 9lbs. dry. She'll be light, nimble, and quick. By the way; great bunch of guys here. Thank you!
#105
Hey, guys. Just to let you know, this will be my last ARF. I'm having a hard time staying motivated with this thing. I'm not sure why. Although when I have it mocked up and sitting on the living room floor, it looks stunning! Vibrant colors and just the right size. And I'm really looking forward to flying the darn thing. I've also been looking for a good used truck as all I have for transportation is a motor scooter (long story). So lots to do before I can make it out to the field again. It has been quite a while since I've done any serious flying. I hope to have all my poop in a group by spring when the weather is ideal for flying as summer in the high desert is brutal! Anyhoo, I'll keep plugging away here and keep you guys posted. After the Eagle is test flown and declared airworthy, you'll find me in the kit builder's forum. That's where I really belong. Anyone know how I can change my username (born2build)? I can't seem to figure it out. Until next time, build something, will ya? You won't regret it. Start with something simple like a Goldberg Tiger or a Great Planes Super Sportster. Both are easy builds and great flyers. I've built models from peanuts to 1/5 scale so, I can probably help. And remember, the key to a good landing is a good approach.
#106
My Feedback: (17)
To change your user name, go to the RCU home page. In the upper right side you will see "my account" with a drop down menu arrow beside it. Don't bother with the drop down menu, just click on the words "my account". That will take you to the member account information page. There you will see all of your member account info, right beside your user name you will see "request change".
From there just put in a help ticket to request a user name change.
Don't give up on the Christen Eagle. If you can keep the weight down to 8 - 10 pounds you will love the way the plane fly's. Mine is my second favorite bi-plane behind my Waco. (a lot easier to assemble at the field too)
#107
New member coming back into the hobby after many years away. I have one of the Hangar 9 eagles with a dle 20 installed that I picked up and I also have one NIB that I plan to put together in the future. I am really wanting to use a gas 4 stroke on the new one. I have seen where ngh has come out with a 30cc gas four stroke anyone know anything about these and how it may work in the hangar 9 eagle? Thanks, Bill
#108
#109
I looked it up. That engine with ignition and muffler weighs over 3lbs! And I don't know if that includes the ignition battery, probably not. The Hanger 9 Christen Eagle II 90 ARF was never intended for use with such an engine, let alone a DLE 20. My Supertigre G90 ring weighs 1.7 pounds with the muffler, swings a 14x6 Xoar prop right at 10,000 rpm and produces nearly 10 pounds of static thrust, even more in the air! with a projected weight of less than 10 pounds, well.... let's just say my Eagle will fly in spectacular fashion, if I can ever finish the darn thing. Plus (oh yes, there's more) lower stall speeds AND lower landing speeds. But good luck with yours.
It is well known that gasoline makes less power than glow fuel but gives better fuel economy at much less expense. Glow fuel also makes engine cooling a little less critical but comes with the side benefit of the oily residue it leaves behind on the airframe So it seems that the G90 and the DLE20 should be pretty on par with each other from a power and performance standpoint with similar wing loadings, weights and landing speeds . So from what the published specs are showing if you are saying the DLE20 is grossly overpowering or excessively heavy for the airframe then the G90 will share the same characteristics.
#112
I do not understand when you say "let alone a DLE 20". The DLE 20 weighs 28.9 oz and the Supertigre G90 weighs 27.0 oz so for a total of a 1.9 oz difference and that weight difference is total weight including the ignition and muffler for the DLE.. Also the published specs on both engines rate them both at 2.5 hp @9000 for the DLE and 14,800 for the G90. Recommended props are from a 14x10- 18x6 for the DLE and 12x8-13x6 for the G90. My Eagle as set up is swinging a 16x8 xoar prop. I got the specs for both engines off of Towers web site.
#113
My Feedback: (43)
Well this will be my next biplane! I just have a question for all of you engine gurus out there.... I have a NIB Supertiger 2000 (not the 2300) with a pitts muffler and I would love to use this engine on something. Could the Eagle be the airframe that I have been searching for?
#114
My Feedback: (66)
Hello all, first off I havent read the whole thread yet. I will before I buy this plane if I do. I have a OS 160 twin and looking for a plane for that engine. I dont want to do the cub like all the rest. This engine is a bit heavy at around 38 ounces. Question is how would this engine perform in this plane. I can move stuff around to get the balance where I like thats easy.
#115
My Feedback: (17)
I've not used the 160 Gemini on the Christen Eagle but I have used it on a 15lb stearman and it flew it just fine. The engine will easily fit in the cowl. I would estimate the plane would come out somewhere around 10lbs. I think it would sound awesome and fly the plane with authority. If it were me, I'd go for it.
#117
Template question
Jerry Cleveland
#118
Can anyone tell me if I can just use what the manual gives me for mounting the DLE 20 on the Christen Eagle II? Also it come with a template for a Saito. Any help is appreciated.
Jerry
Jerry
#119
No, it does not come a template for the DLE 20. Plenty of guys have used this engine. Go back through this thread and they should be here, somewhere. Just as a point of reference, my Eagle is powered with a Supertigre G90 (2-stroke glow). I replaced virtually all of the included hardware. All-up weight, without fuel is 8lbs, 14 oz. Testing will commence as soon as the weather permits.
Jerry
Jerry
#122
Jerry
