ESCAPADE 60 INVERTED ENGINE
I was just wondering if anybody has mounted a four stroke in this plane inverted with the cowl on. I have a .91 fourstroke that i ame thinking of buying this plane for but i want to know if there is enough room to mount the motor inverted under the cowl. Any thoughts would be great.
RE: ESCAPADE 60 INVERTED ENGINE
Unless the fuel tank is a good 12" higher than the engine, the typical .3 - .7" difference in height we see makes absolutely NO difference to performance.
It only affects the engine PRIOR to starting, in that there is a slight chance fuel will siphon in, particularly if you leave the throttle open, or if the throttle is closed but the engine out of tune ( overly rich permitting fuel to siphon in ).
Just watch your tubing. Keep lengths as short as possible and even with the tank inlet if possible.
