Seagull Super Tucano
Reply
Old 04-16-2013, 07:45 PM
  #76
Guijs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Seagull Super Tucano
Yes the wings are small considering the size of the airframe. You could try changing the position of the nosewheel just a bit to raise the nose a little.
When you set the flaps it will also help a lot if you are able to use 15 degree for takeoff.
Unfortunately i'll have to wait for 3 more weeks to maiden it....
Guijs is offline
Old 04-17-2013, 03:36 AM
  #77
rlbomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try that the next time I fly her. My pilot lost it's head in the last flight so I order two new pilots from Aces of Iron. Sorry you have to wait three more weeks to fly her.
rlbomber is offline
Old 04-28-2013, 11:38 AM
  #78
cloudancer03
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really want to convert to electric will it be hard.can you do anything to the canopy to get easy access for installing batteries.
cloudancer03 is offline
Old 04-30-2013, 11:04 AM
  #79
steph280
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the guy at our field flies one of these on a Motorfly motor with 6s-5000 pack. I think it's a perfect candidate for electric conversion, more so than the 120 size PC-9 I have.
The belly hatch cover between the wings allows easy access to the battery, which has to be at the wing section to balance the plane.
And he also left the rear receiver battery hatch cover off as air exit to cool the electronics.
Everything just seem perfect about this plane for electric conversion!
ID:	1877739   Click image for larger version
ID:	1877740   Click image for larger version
ID:	1877741   Click image for larger version
steph280 is offline
Old 04-30-2013, 11:37 AM
  #80
Guijs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
steph280, could you please ask the owner of this tucano which model/brand is the oleo legs he is using? I saw some models at Hobbyking but i'm not sure which one will fit.
Guijs is offline
Old 04-30-2013, 11:51 AM
  #81
Krasherjack
Krasherjack's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea Steph, I'm with Guijs
Krasherjack is offline
Old 04-30-2013, 12:27 PM
  #82
rlbomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like those retracts, what brand are they?
rlbomber is offline
Old 04-30-2013, 03:51 PM
  #83
ceecrb1
ceecrb1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 for wanting to know about those oleos!!
ceecrb1 is offline
Old 05-05-2013, 05:12 PM
  #84
Guijs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did the maiden flight today. It was only a five minute flight because the rain was coming fast. It started right after I landed.
The plane flew amazingly well! I just had to add 2 clicks at the upper elevator trim and it was flying perfectly. Takeoff was very easy and I didn't had to use rudder at all. I used a MAS 15x8 2 blade. I'll fly with this prop a few tanks during the break-in and then I will start to try a 15x12 APC and 14x9 MAS 3 blade. I also want to try a 13.5 x 13.5 carbon 3 blade from Engelmt. The plane weight 4.7 kg and I had a pulling force of 5.43 kg.
Landing was also VERY easy, I was surprised. I set flaps 15 and 45 degrees and didn't have to set elevator compensation. It landed slow and easy.
I will fly it again next weekend.
Guijs is offline
Old 05-06-2013, 08:26 AM
  #85
rlbomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Isn't it a beautiful plane to fly! It flies real nice with the 15x8 prop but recently I tried the 16x8 and flew well, the only problem there is the low ground clearance. I just purchased a 15x8 three blade prop to try out but need to wait, I forgot to buy the three blade cone to go with it.
Enjoy it, I sure do!
rlbomber is offline
Old 05-06-2013, 08:32 AM
  #86
Guijs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rlbomber, what is the make of this 15x8 3 blade?
I also have a MAS 15x10 2 blade, it should be faster than the 15x8.
Guijs is offline
Old 05-06-2013, 09:09 AM
  #87
rlbomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a MAS 15x8 prop.
Did you think the plane was fast with the 15x8?
rlbomber is offline
Old 05-06-2013, 02:10 PM
  #88
Guijs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, It's the fastest model I ever flown but I'm only used to glow high wing models. I expected it would be faster. It probably will after I tune the engine.
But the 15x10 MAS 2 blade probably will be much better. Try this:http://personal.osi.hu/fuzesisz/strc_eng/index.htm
It shows:
MAS 15x8
Required engine power = 2.005 HP
Estimated flying speed = 68.1 mph
MAS 15x10
Required engine power = 2.507 HP
Estimated flying speed = 85.2 mph
Guijs is offline
Old 05-06-2013, 04:21 PM
  #89
rlbomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting, I may have to try the 15x10 prop and see how she flys.
If you're interested, here's some of the other planes Ifly:
https://www.facebook.com/media/set/?...9491927&type=3
rlbomber is offline
Old 05-13-2013, 05:03 PM
  #90
Guijs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did 5 flights this weekend. It really flies very well, but not so fast. But I still have to tune the engine properly. I should test the 15x10 next time.
rlbomber, did you set your flaps? Mine is extremely easy to land. My engine went down due to empty tank and I was able to land it perfectly.
BTW, how long are your flight? I first set my radio alarm to 10 min and it went empty. Then I set to 8 min. And I am not using open throttle all the time.
Guijs is offline
Old 05-14-2013, 03:56 AM
  #91
rlbomber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guijs, yes she is very easy to land but does come in very fast without the flaps. I fly off of a dirt runway so I don't have any grass to slow her down. I've only been using about 25 - 30 percent flaps.
I actually had the throttle linkage come off on me during one of my flights and she was stuck at half throttle. Since I put the electronic cut off switch in I was able to line her up with the runway and kill the engine once lined up. She floated in beautifully with no bad tendencies.
The one bad thing if I were to complain is that the fuel tank is very small. If this was a nitro plane the flight time would be much less than it is now, probably only about 5 minutes.
rlbomber is offline
Old 03-30-2015, 02:40 AM
  #92
Aussieace246
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello all.
Ive just bought and started building this model. Being from Australia, all my fellow club members fly the PC9 model, so i wanted something different!!!
Im going full digital servos with DLE20 up the front.
After trying to research about the fuel tanks and stoppers etc etc... Ive decided to buy a Sullivan heavy duty fuel stopper. Im hoping this will fit the stock tank.
I see user ceecrb1 was using a Hayes tank, I did find some around the place but stores would have the tank and no hose or stoppers to suit petrol (i wanted to buy all components from one store). What have other users, used with the a petrol engine conversion? if the Sullivan stopper does not work, I don't know what I will do????!!! Also, what have u guys done with the breather line?? there isn't much room up in that nose!!!
Thanks guys, hope someone can help me out??
Cheers
Aussieace246 is offline
Old 03-31-2015, 01:07 AM
  #93
duanen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Aussieace246, I have this bird with the DLE 20 in her, I also fitted the engine with a pitts style muffler. Dubro do a gas stopper that fits the standard size fuel tank bungs, its is brown in colour. and should be available from most hobby stores This bird does not fly like a pc-9. it is way more slippier and is a rocket with the DLE 20. you will love it. the standard set up for the retract is a pain so I installed eflite large triset of retracts. you will end up having to put the batteries in over the fuel tank to make her balance so I used eneloops for both the flight(6v)and ign(4.8) pack. it is a tight fit but they do go . if you have ay questions send me a message
duanen is offline
Old 04-02-2015, 03:23 AM
  #94
Aussieace246
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply mate. I have just ordered all the necessary components to convert her to petrol 2 stroke! Im just not sure how to route or where to mount the vent line?
Im going to use a Tpiece on the carby feed line and run it to a fuel dot.
Also where did u mount the ignition module?
Cheers
Old 12-25-2015, 08:28 AM
  #95
miket116
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default help please
Quote:
hello
I have this bird with the DLE 20 also and i m going tu replace a super tigre G90 by dle 20. could you help me ?
1- original holder in white nylon means to narrow , less 5 to 8 mm wide , do you use them or how to replace by greater one . i m afraid because fiwe wall inside is impossible to reach or it must to open the plane noze close canopy ? isn'it ?
2- which propeller i fell thta 15x8 or 3 blade 14x9 or 163x8 woood ?
3- i read with attention your remark about balance and i have to check it after dle20 mount with 2 lipo 2s 1300 nanotech + servo for direction
4- i use retract "perkings" means a little bit not very strong , what s do you think ?
tks to help me by advance
Michel from France
miket116 is offline
Old 08-19-2016, 08:42 AM
  #96
Steam28
Steam28's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally maiden the Super Tucano with a DLE20 rear exhaust (without ordinance for the first flight). I was surprised how easy and slow this plane could fly. Although I used half flaps on landing, I could easily have landed with no flaps based on practice approach runs. Great plane.
Steam28 is offline
Reply
Display Modes
