If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 126 to 150 of 174
  1. #126
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ECOMRC TigerMoth 1/4 Scale
    All control surfaces hooked up and moving in correct direction. The rudder and elevator
    deflection is correct. The aileron deflection is .5" up and 1" down, caused by foward sweep of the control horn.
    This differential setup is opposite of what I have come to expect of aileron differential ie more up than down.
    Joe
  2. #127
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes you need to get the differential set for more up and less down.  I haven't got that far on my TM yet, getting lazy,  however it comes with the same hardware as my Stinson 108 and I didn't have any issues with the differential so I'm not sure what is up with the TM.
  3. #128
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I moved the aileron control rod to the rearmost lowest hole in the horn . Now get more up (1") and less down but still
    have more down than up. I am going to drill a hole on the horn lower and farther away from the hinge line.
    If I could remove the aileron horn I would mount it reverse of the way shown in step 6. More later.
    Joe
  4. #129
    Seamus OLeprosy's Avatar
    Join Date
    Aug 2009
    TrimCo Meath, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    http://shop.lindinger.at/product_inf...ducts_id=91996
    Its available here for those who dont want to pay YT prices. I'm saving up
  5. #130
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you have at least 1" of up I would just use servo end points and differential in the TX to limit the down, or you could change the position of the servo arm, but that's just me.
  6. #131
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I now have 1 3/4" aileron movement in both directions. I will use Xmitter settings to get correct movement.
    40mm is almost 1 9/16. Will set deflection for this and set down to 20 mm.. To achieve this I drew a series of lines
    on the aileron horns as follows 3/4"above and parallel to bottom of aileron, 5/8" as before
    and a verticle line 90 deg to aileron at the edge of the taper. I drilled a 7/32 hole in the box drawn on aileron horn.
    Joe
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1802016   Click image for larger version.
ID:	1802017   Click image for larger version.
  7. #132
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have run into another snag. I need a adapter nut 10/1.5 mm for my Laser 1.8. The one I have is about 3/16" too long for the prop MA18/8 and tru turn
    spinner combo. Tru Turn does not make one with a 1.5mm thread. I have not found a spinner nut with a10mm/1.5mm.
    Joe
  8. #133
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have you noticed that one of the "G" on the rudder is backwards.
    Setting up the fuel fill/drain system and mounting the cowl.
    Cutting holes for access to fill tank, needle valve, exhaust, glow plug,
    and cooling.
    Joe
  9. #134
    Join Date
    Dec 2010
    Birmingham, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Joe,
    I have checked my photos and mine is OK. Is it just yours!!!!!.
    Cant wait to see yours complete and see her flying.
    Cheers
    DB
  10. #135
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice? to know mine is unique!
    Put dummy in rear cockpit, made some instruments for both cockpits. Mounted receivers, switch and charge jack.
    Cowl mounted, most acess holes done.
ID:	1809779   Click image for larger version.
ID:	1809780   Click image for larger version.
  11. #136
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    All together and rigged. Starting to balance this using cg @5 3/4 inches from LE at top wing this is very tail heavy.
    My laser 1.8 four stroke weighs as much as a DLE35 with muffler and ignition module. Going to need lots of lead,
    3+ lbs.
  12. #137
    Join Date
    Dec 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds about right.
    Mine before was 14.5 Lbs ended up at 18Lbs once I sorted CofG, flys great at that weight so dont worry. I glassed mine up front in the cowl.
    All the best
    DB
  13. #138
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: flyalot
    3+ lbs.
    The Hangar 9 TM is the same size as the ECOMRC model so I would think that it would balance at the same CG. The listed CG of 6.5 - 7 inches is incorrect and should be more like 8 inches. Here is a post from RC Groups.
    Guys I have been watching this thread a little and have been concerned about you having to add weight to the nose. I went to a lot of trouble to keep everything up in the nose and the tail as light as possible to ensure you would not have to add nose weight, or in worse cases very little nose weight.
    I talked to Dick yesterday and he also had to add a substantial amount of weight. (Nice job on the ballast Dick).
    For reference 4 pre production and one production kit was built and flown before we shipped, none had nose weight. As you can imagine how I felt when the first few kits that have been built by consumers we having to add excessive amounts of lead, I was pretty disappointed to say the least.
    Well last night I pulled mine down of the wall ( the one I was flying at Joe Nall) and did a C of G check. Sure enough, the numbers in the manual are 1” too far forward. Mine is currently flying at exactly 8” measuring back from the LE of the dummy fuel tank, and I have flown it 3/8” further back than that. So the manual should read, C of G is 7 5/8” – 8 1/4'”.
    Guys I sincerely apologize for my error, and I hope this comes as good news as you should be able to remove some if not all the lead from the nose.
    Kind regards
    Peter Goldsmith
    And another comment:
    Not sure of the actual measurements, but my 1/4 scale Tiggie balances on the rear edge of the fuel tank. This is also pretty much where I've seen the CG of other Moths located.
    http://www.rcgroups.com/forums/showt...1585798&page=8
  14. #139
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    I have finally finished the Tiger Moth. It is balanced according to mfg instructions. Engine has been removed and stored until spring.
    When warm weather returns I will break in the engine install it and go flying.
    FYI the hanger 9 (arf) TIGER MOTH and the Flair (kit) Tiger Moth have about the same C/G range 194 -210 mm, 190 - 210 mm respectfully.
    The ECOMRC Tiger Moth C/G is 146mm? Signing off till next flying season, Joe
  15. #140
    Join Date
    Dec 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Joe,
    Really good news. I thought you always had good weather over there, its normally here in the UK with have it.
    Look forward to seeing it next season.
    Tar for now
    DB
  16. #141
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some pictures of my Tiger Moth and lead on the motor box, there is also some under the motor box and in the cowl. I am balancing it acording to a CG calculator at 1" farther aft than the instruction manual. My position is also about 1" forward of the CG for the 1/4 scale Hanger 9 Tiger Moth.
    Weather permitting it will have it's maiden flight in one or two days.
ID:	1823551   Click image for larger version.
ID:	1823552   Click image for larger version.
ID:	1823553   Click image for larger version.
  17. #142
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, fotos look good. Mine is dissambled and put away. I will break in the engine in the spring. Woke up to snow and 23 degree f.. I build
    and do maintnance in the winter months. I will be replacing bearings in a Saito 1.50 and finishing a 1/4 scale Sig J3 converted to a Super Cub. It is all framed up
    Struts to make, equipment to be installed, control surfaces to be hinged and all covered with solartex. I am also planking the hull of a model sailing ship (HMS Bounty)
    When you fly the Moth let me/us know how she handles. Mine is balanced according to instructions and feels nose heavy.
    Joe
  18. #143
    Join Date
    Dec 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Bob,
    Nice photos, like to plumbing.
    Looking forward to seeing the flight.
    Snow Joe!!!!!, we just got lots and lots and lots of water mate, you want some LOL.
    Cheers
    DB
  19. #144
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had my 3D test pilot maiden the Tiger Moth today. CG was at 6 3/4" back from the leading edge of the fuel tank. Takeoff was from grass and the nose was so heavy it was on the edge of nosing over during taxi. Inverted flight required full down elevator. At a high idle and full up elevator it would not stall, it just mushed along. It had to be pulled upabruptlyto stall it, it didn't drop a wing.
    My pilot said it flew well and didn't seem tail heavy. It took a little down trim to fly level at half throttle. Looking at the elevator on the ground the down trim was barelynoticeable.
    I am moving the CG farther back, I now have it at about 7 3/8", or 5/8" farther than it was, that's using the finger tip method.
    More photos and the maiden takeoff and landing.
    http://www.youtube.com/watch?v=JHq3Ap2y-rY
    http://www.youtube.com/watch?v=G3eMIy_nsdM
ID:	1823963   Click image for larger version.
ID:	1823964   Click image for larger version.
ID:	1823965   Click image for larger version.
  20. #145
    Join Date
    Oct 2004
    mumbai , INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    congrats 600 bob !! may be moving the cg 1/2 " aft may help the nose over !!
    loved the prop !! where did u manage to ge the same ?
  21. #146
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got the prop from Valley View RC.  It is a Xoar WWI prop so not correct for the plane but it was just to pretty to pass up.  However it didn't survive the nose over, I'll get a regular prop until the nose over is solved.
    With the CG at 6 3/4, when the plane is held level the CG is almost directly over the wheels, not much weight on the tailwheel when it is on the ground.
    Link to prop, their website is sloooow, always.
    http://www.valleyviewrc.com/estore/xoar-wwi-lance-dark-propeller-18x8.html
  22. #147
    Join Date
    May 2003
    Dixfield, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    600Bob, Thanks for the flight report. Looks like I will be re balancing my Moth. I will wait until you finish your testing and
    arrive at a final C/G location, then I will put mine back together and begin a weight reduction rebalancing program. I assume you
    bought your Moth from Troybuilt models, thats where I got mine, I suggest you let them know of this thread. Hopefully they will
    read it and pass the info/problems we encountered to the Mfg. and to others buying this model. I am enjoying this sharing of info
    more than than the actual assembly of the Moth! The snow is gone, the cold is here to stay, the snow will be back and will stay until late spring.
    Joe
  23. #148
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes I bought it from TBM.  I am using the new DLE 35RA engine.
    I didn't want to put a huge amount of weight in the cowl so I put about 18 oz.in the cowl and the rest around the motor box.  I removed 2 1/4 lbs. from the motor box to move the CG back about 5/8", that puts it at about 7 3/8".  The updated CG for the Hanger 9 TM is 7 5/8 through 8 1/4.  So all things being equal I should still be a bit nose heavy, I figure I am now at roughly 28% of MAC.
    I need to get a new prop and a bit of engine tuning then it will be ready to go again but the weather forecast is rain for days to come.
  24. #149
    Join Date
    Dec 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great job there Bob.
    What weight is she comming out at?
    Mine was 18Lbs, I packed the rear of my under caridge to push the wheels forward a little and in creased the wheel size sorted all my issues out.
    Cheers
    DB
  25. #150
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I weighed it before adding the last lead for the initial balance and it was 17 lbs. I didn't weigh it after I installed all of the lead but it would have come out around 19 lbs.  After removing some it should now be around 17+ lbs.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
