50CC REVOLVER!!
#202
RE: 50CC REVOLVER!!
I also have an inline filter and a filter in the gas can, but you may find, as I have that some kind of lint builds up in the internal filter. It may be from the alcohol in the gas. Maybe something in the fuel crystalizes. Has appeared in differenct planes; and only in the internal filter.
Chief also offers the replacement parts for Pilot planes for the cost of postage, via the manufacturer. I broke the engine box off of my EF Yak and luckily a friend had one from the Yak he had crashed. Trying to get the alignment right using ply stock would have been a challenge. With Pilot's program, it would have been a relativley easy fix.
#204
RE: 50CC REVOLVER!!
Yes the screws secure the horns well. ALWAYS drill the holes, insert the screws, add 2 drops of thin CA, and let harden. Then reinsert your screws. Not only does is make the ply or hardwood insert harder it also hardens any balsa below and helps secure the insert also. I have yet to have one pull out. This is hardware from an Aeroworks 50cc Ultimate.
#205
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: edwal07
Thanks for the update. I too think the landing gear would look better painted. I have some white appliance epoxy that will do the trick. Can you post a photo of the gear. I think that may make it stand out even more.
Here ya go...
#207
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
Here ya go...
ORIGINAL: edwal07
Here ya go...
#209
RE: 50CC REVOLVER!!
Spridal;
Is that the DLE 55RA you have on the nose?? If so, will the stock muffler fit without mod to the engine box?? I am going with that set up on my R90!!
Thanks for the info!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#210
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: jet22b
Spridal;
Sonny
aka
jet22b
Spridal;
Sonny
aka
jet22b
That's a DLE 55RA up front. The muffler and stand-offs fit perfect with no mods. Once the cowl is installed, the exhaust protrudes slightly and is hardly seen. All in all a very good fit.
#211
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
Yes,
Yes,
#212
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
Ed,
What are you doing for the choke? Iplan on going with a manual choke. Ijust have to figure out how to route the rod.
Ed,
The DLA 56 pitts muffler fit OK however I had to cut some clearance on the side. Wish I had the 55RA and that would have solved that problem.
Will post a pic once I figure out how the manual linkage will work. I used a 4 point servo arm with 2 arms cut off to act like a bellcrank and the rod exited on the bottom of the cowl on the Ultimate, will have to see if that will work on this one.
#213
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: edwal07
I got the cowl on last night, no linkage yet but was looking at the choke to see where it could go. I will do some more tonight and that is one of the things I was planning on doing.
ORIGINAL: Spridal
Ed,
Ed,
I decided to use the method Ilearned from AeroWorks. Simply run the choke rod to the front of the cowl. Makes things simple and effective. See page 53 of the Aeroworks 50cc Edge Manual. I also setup my throttle the same way as suggested in thier manual.
http://www.aero-works.net/upload/man...ualrevised.pdf
#214
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: airborne2.4
Do you have any pictures with the DLE 55RA and cowl installed?
ORIGINAL: Spridal
Yes,
Yes,
#215
RE: 50CC REVOLVER!!
Spridal;
Thanks again for the info. Can not wait to see your pictures. Like I said before, I am going with the same setup. My R90 may not fly untill spring, because the weatherman is calling for snow here in the Great Northwest starting tomorrow![] Old man winter is on its way!!!
Thanks again!!!
Sonny
aka
jet22b
Thanks again!!!
Sonny
aka
jet22b
#216
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: jet22b
Spridal;
Thanks again!!!
Sonny
aka
jet22b
Spridal;
Thanks again!!!
Sonny
aka
jet22b
#218
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: Super08
It is the garbage that just dumped all over my truck yesterday. It was worse than this before it finally stopped. We got a good 6". Far too early for this stuff.
ORIGINAL: Spridal
What is this thing you call snow? LOL...
Weather in Palm Springs, California
Hourly · Monthly Averages · Radar & Maps
#221
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
You think you have it tough. Look what I have to deal with [img][/img]
<thead>
ORIGINAL: Super08
It is the garbage that just dumped all over my truck yesterday. It was worse than this before it finally stopped. We got a good 6''. Far too early for this stuff.
ORIGINAL: Spridal
http://<font color=''#0044cc''><b>We...ifornia</font>
<cite>bing.com/weather · http://<font color=''#5077bb''>Data ...Weather</font></cite>
Now | Tue | Wed | Thu | Fri | Sat |
79° Sunny (Clear) °F | °C | [img][/img] 80° / 57° | [img][/img] 83° / 59° | [img][/img] 85° / 62° | [img][/img] 85° / 62° | [img][/img] 85° / 60° |
Sonny
aka
jet22b
#223
My Feedback: (17)
RE: 50CC REVOLVER!!
ORIGINAL: Spridal
Yes,
Yes,
