Some tips on my ARF
Reply
Old 10-06-2012, 01:37 PM
PDF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Some tips on my ARF
Hello all,
This is my first ARF build and don't want to make any stupid mistakes. I'm working on a .46 Phoenix 300 extra. This should be a simple question and I think I have the right approach but want to be sure. I cut out the hole for the wind support tube that goes through the fuselage and when I slid the wing on I obviously saw that the wing didn't sit flush with the fuse. I'm assuming I'm going to cut out the monocote and slide it in further, am I correct? also If this is the case do I cut the monokote exactly to the fuse or do you leave a bit excess and iron the extra monokote inside the fuse? The manual doesn't give any info on this, It says (install wings).
Thanks again,
Pat
PDF is offline
Old 10-07-2012, 08:28 AM
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Some tips on my ARF
I tried once to cut it with a quarter inch to tuck inside but found it too tight when doing so. Now I cut the covering flush with the recess and sometimes find a need to enlarge the recess slightly in places.
Take a hard look at two other areas of most arfs... the firewall support and gear support. They sometimes/often need additional support.
AA5BY is offline
Old 10-07-2012, 03:37 PM
PDF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the tips.
Pat
PDF is offline
Old 10-07-2012, 04:50 PM
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Leave excess. You can always cut more off, but it doesn't work as well the other way.
Jetdesign is offline
Reply
Display Modes
