Reload this Page >
Seagull Model Cessna 337 ARF
Old 03-10-2013, 09:25 AM
  #226
jet22b
jet22b's Avatar
Default RE: Seagull Model Cessna 337 ARF
Don;
The white cover is for the rudder and or elevator push rod, ( see photo below). The red cover I did not use!!
Hey guys I was hoping to come home yesterday and post a flight report on the maiden flight of my 337, but , the back engine had a mind of its own. For the life of me, it would not start. Did 10 glow plugs changes and she would not start!! Use 5 other glow driver and she still would not start. All 10 plugs was brand new and each one heat up when the driver was hook up. The front engine was running sweet, so I took the plug out of the front engine and put it in the back, again no start. The engine was getting tons of fuel, but she would not kick. Today I will take the engine off of the plane and put it into the test stand after I tear it down!! I will be mad if I put it in the stand and it start right up!![>:] Everyone at the field fell in love with it and they was sad not to see it fly.
Stay tune everyone!!!
Sonny
aka
jet22b
Old 03-10-2013, 09:34 AM
  #227
donddsms
Sonny, thanks for the fairing photo Sorry you couldn't get her started, I hope you figure out the problem and let us all know how you fix it.
I can imagine they loved her looks at the field, it's a beauty!
Don
Old 03-10-2013, 09:52 AM
  #228
eddieC
eddieC's Avatar
A shame it wouldn't start. I'd suspect debris in the carb, as it has a way of finding its way into the tank and plumbing during a build.
Good luck, a gorgeous plane!
Old 03-10-2013, 11:51 AM
  #229
jet22b
jet22b's Avatar
Hey Guys;
Well after tearing the rear engine down, I found what stop the engine from running yesterday. In the crab jet, I found a strand of my dog hair. It plug the jet so no fuel could make it through the crab!! On all my planes I install a in-line fuel filter between the tank and the crab. I also have a in-line fuel filter from the electric fuel pump to the tank fill line. So how this hair made it all the way to the crab jet. Put the engine back together and in the test stand and it is running smooth!!!
I hope next weekend there will be so good weather again so I can fly her.
Stay tune!!!
Sonny
aka
jet22b
Old 03-10-2013, 01:13 PM
  #230
eddieC
eddieC's Avatar
Pull that crab outta there while you're at it!
Old 03-10-2013, 01:42 PM
  #231
jet22b
jet22b's Avatar
ORIGINAL: eddieC
eddieC,
I took everything off of the crab and did a deep cleaning!!!
She is running like top now!!!!
Sonny
aka
jet22b
Old 03-10-2013, 05:00 PM
  #232
Herc Pilot
My Feedback: (15)
Herc Pilot's Avatar
ORIGINAL: donddsms
These are the last parts left in the box. I'm not sure if I am going use the white fairings, I can't decide if they improve the appearance or not. What do the rest of you think? Also, the three red fairings don't appear in the manual so I guess I have creative license to place them anywhere I want. They look like they could cover the exit ports for the rudder and elevator push rods, or maybe they are scoops to improve air flow to an engine. Or very tiny wheel pants. Has anyone found a use for these?
Don
Don,
We figured the red ones were meant to be pushrod exits for the two rudders and the elevator. We replaced them with better looking ones from our LHS. I really liked your idea of very tiny wheel pants though! Like you, we are still undecided about the white fairings. It would make more sense to me if they were some sort of extension of the stab, but they are further forward on the real plane. Must have something to do with breaking up the air to the tail. We'll probably add them in the end. As for your radio problems, that is very strange. Sounds like an issue with an extension to me, like maybe you had a good power connection but the signal wire wasn't making good contact causing them to max out. Especially since the nose gear continued to function.
Sonny,
Sorry you didn't get to fly but better to make sure everything is just right before that maiden flight.
Mark,
I received the extra elevator control horn Saturday. Thanks again! People in this hobby are the best!
Adam
aka Herc
Old 03-15-2013, 08:06 PM
  #233
jlswan
Hi guys,
Finally got my parts. Motors and cowls mounted. This is all you need for 4250 size electric...
10mm spacer
http://www.hobbyking.com/hobbyking/s...dProduct=24999
3x30mm Sockethead screw
http://www.hobbyking.com/hobbyking/s...dProduct=18270
Here are some pics
ID:	1862502   Click image for larger version
ID:	1862503   Click image for larger version
ID:	1862504   Click image for larger version
ID:	1862505   Click image for larger version
ID:	1862506   Click image for larger version
ID:	1862507   Click image for larger version
ID:	1862508   Click image for larger version
Old 03-15-2013, 08:13 PM
  #234
jet22b
jet22b's Avatar
jlswan;
Your 337 is looking great!!!! Please keep the un-date coming!!!
Also thanks for the info!!! Got to pick up one more!!!
Sonny
aka
jet22b
Old 03-18-2013, 10:39 AM
  #235
MMallory
I was told the aluminum stand-offs, for the electric conversion, may introduce vibration. My local hobby shop made custom boxes for me to mount the motors. The boxes are great and bolt to the stock locations. I should have considered what/where the cowl would be screwed into though. I would have asked for different depths for these boxes. As is the front is 70mm and the rear 57mm. I would have gone with 54mm for the rear and 64mm for the front.
I also decided to cut out the muffler box in the front & the tank box in the rear to mount the speed controllers. Hopefully there will be enough airflow using these locations. More to come...
ID:	1863717   Click image for larger version
Old 03-18-2013, 12:24 PM
  #236
jet22b
jet22b's Avatar
MMallory,
The boxes looks good!!! That is nice to know about the aluminum stand-offs and vibration. You may be okay with cooling the speed controller up front, but the back one may need more. You may want to look at putting the rear speed controller on top of the rear motor box so it will get air from the intake on top of the wing. If you do go that route open the air scope like we have done, so you can get as much air as you can going to the back cowling. Let us know if that work for you. I hope the weather be good for this weekend so I can maiden my bird!! If I do, I will post a flight report!!
Sonny
aka
jet22b
Old 03-18-2013, 12:58 PM
  #237
MMallory
Thanks! I thought about putting it there but it will block most of the airflow in that position. I was thinking since the floor of the model makes a tunnel from the front to the back; the airflow going through would be enough for the speed control. This would leave the airflow coming in from the top to cool the motor. I guess I'll test with my Makita blower to see if it will work in practice.
Old 03-18-2013, 01:33 PM
  #238
jet22b
jet22b's Avatar
ORIGINAL: MMallory
MMallory,
I am in my workshop and I look at that and you were right!! It will block a lot of the air flow!! Let me know how your test go.
Sonny
aka
jet22b
Old 03-19-2013, 10:11 AM
  #239
nioa
nioa's Avatar
Airflow to the rear ESC:
I am building a Cessna 337 that I got from General Hobby, and I wanted to share a comment.
One thing you may want to consider is placing a fan on the rear ESC. It is very easy to do. A small 5 volt fan (or a 12v fan with 2S or 3S lipo) is easliy powered a long time by a spare battery. The fan does not have to rip it up to be effective, as even the slightest amount of air flow is far better than stagnant air, and will significantly help to keep the temp of the ESC down. I have a 60 size Long-EZ that I have done this to (image 13) and it is very effective and keeps the plane's ESC cool. Great thing is you can get these fans for cheap (the fan shown in the image cost $2.49, and is a quality ball bearing new unit), or if you don't care you can buy fans for RCcar applications that will work just fine. Make sure they have a ball bearing for long life.
Nick
Old 03-21-2013, 10:31 AM
  #240
donddsms
Sonny or Joe, or anyone else who has flown yet, how does she balance? Does it fly ok at the manual balance point of 80 mm back from the leading edge?
Still too cold for me here in Cincinnati!
Don
Old 03-21-2013, 04:18 PM
  #241
jet22b
jet22b's Avatar
ORIGINAL: donddsms
Don
Don,
I have yet to maiden my 337, but I have it balance as per the manual. I am hoping the weather will be good for this weekend so I can maiden her. There is one person who has maiden his 337 and I think he was balance as per the manual and he said it flew fine and he love it. If I do get to maiden my baby this weekend, I will post my flight report.
Stay tune!!
Sonny
aka
jet22b
Old 03-23-2013, 05:48 AM
  #242
rcflunky
Don, I balanced mine at 80mm using a GP cg machine. I had to add about 5oz to the nose and after the maiden it felt way to nose heavy so I removed 2.5oz and it flew great after that. I'm not sure that the 80mm is correct but you won't know until you fly. Good luck on your maiden and Sonny we are all waiting to hear about your maiden hope you get to do it soon.
Joe
aka
rcflunky
Old 03-26-2013, 01:36 PM
  #243
RCspectator
Cal Orr has a Seagull Skymaster that he says is a real 337, he made a retract system with the sequencing gear doors.
His model is electric, 2-eflite 15 with 10x7 props and a 4 cell Lipo battery on each motor.
The airplare sounds GREAT flys Great and looks good with the gear up.
See pictures
ID:	1866878   Click image for larger version
ID:	1866879   Click image for larger version
ID:	1866880   Click image for larger version
ID:	1866881   Click image for larger version
ID:	1866882   Click image for larger version
Old 03-26-2013, 01:52 PM
  #244
jlswan
You are right, it sure looks good with the gear up.
I would love to see a closer look at the rear retracts!
Old 03-26-2013, 02:35 PM
  #245
jet22b
jet22b's Avatar
ORIGINAL: jlswan
Me Too!!! Please!!!!!
Sonny
aka
jet22b
Old 03-27-2013, 09:30 AM
  #246
RCspectator
The next time I see Cal, I will try to get more pictures of his Skymaster.
Old 03-27-2013, 10:17 AM
  #247
Free Bird
And info on how he installed them would be awesome!
FB
Old 03-27-2013, 10:34 AM
  #248
RCspectator
Seagull Cessna 337 Skymaster Retracts
Cal Orr sent me these pictures and said they were taken "during construction".
I hope they help
ID:	1867224   Click image for larger version
ID:	1867225   Click image for larger version
Old 03-27-2013, 10:48 AM
  #249
jet22b
jet22b's Avatar
RCspectator;
The pictures do help, but, can you ask Mr. Orr to send you pictures of the gears them-self and how they are mounted?? The plane do look nice with the gears up and the wheel wells will add in cooling the back engine for people who went with nitro!! Thanks again!!
Sonny
aka
jet22b
Old 03-27-2013, 09:32 PM
  #250
Kostas1
Kostas1's Avatar
The pictures with the Cessna in the air are excellent!
What is the All Up Weight of yours;
Have you measured it;
