If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What type of glue can I use to hold magnets in place?
    I want to use magnets to hold my canopy on. What type of glue will hold the magnets in place and not come loss when I remove to canopy. I have a would fuselage and canopy. The Magnets are 1/2" in diameter and 1/4" thick. I will use 2 dowels on the front of the canopy and 4 magents on the rear. 2 in the fuselage and 2 in the canopy itself
    Jim Stanton
    Millington, TN 38053
  2. #2
    Join Date
    May 2012
    , OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: What type of glue can I use to hold magnets in place?
    I would use 30 min. epoxy myself.
  3. #3
    Join Date
    Oct 2002
    Queensbury, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnetic glue of course !!
    Just kidding. I to would opt for a good epoxy.
  4. #4
    flyinwalenda's Avatar
    Join Date
    Oct 2009
    Northeast, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Take a demel or some heavy sandpaper, or file and scuff up the side of the magnet that will accept the epoxy and it will give the glue something to "bite" into. Scuff up the wood as well.
    Brian Ray
  5. #5
    Join Date
    Jan 2003
    Dallas, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I use a brass tube chucked into a drill to cut the hole for the magnet. This gives the magnet a tight fit into the wood. Then, just a couple of drops of thin CA from the back side is all it takes. Make sure and glue the magnets in so they do not oppose each other. Been doing it this way for years and have never had one come loose. The ones in this plane are 3/8" diameter.
    RS
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1818478   Click image for larger version.
  6. #6
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How do you get the "hole" removed? Ya know the inside of it. Don't you wind up with just a ring or groove around the outside?
    and airplanes were in
  7. #7
    Join Date
    Jan 2012
    Danville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jstanton
    I also would use epoxy or a medium CA, in both cases with the magnets inset into a hole.
    How big is this plane ?? 4 x 1/2" magnets are huge. I would think this is for a giant scale plane otherwise buy smaller rare earth magnets and save some weight.
  8. #8
    Join Date
    Oct 2006
    Leeds, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JB Weld.
  9. #9
    jstanton's Avatar
    Join Date
    Aug 2002
    Millington, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I went ahead and drilled two 1/2" holes into the canopy and used some 1/2" flat washers on the fuselage. I epoxied both the batteries and washers in place. This has made for a very tight fit and looks like it is going to work just fine. O by the way the plane is a 1/5 scale Fokker D-VII with a DEL-30 gas engine. That is why I choose to use 1/2" flat magnets. Here are a few pic's The canopy has the pilot in it.
ID:	1818548   Click image for larger version.
ID:	1818549   Click image for larger version.
    Jim Stanton
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
