Hangar 9 60 size corsair arf
Reply
Old 09-12-2011, 09:55 AM
  #2451
phatbob02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hits and Misses of H-9 Corsair
I've been thinking about the new H9 50 Corsair. I wonder how it would handle the Saito 100 I had in the 60 size?
Should I risk it?
phatbob02 is offline
Old 09-12-2011, 12:02 PM
  #2452
Pit-Viper 1
Pit-Viper 1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think there is alot of difference between the. 91 & 1.00. it may be slightly heavier. I wouldn't think there would be a problem with it if it fits.
Pit-Viper 1 is offline
Old 09-12-2011, 12:34 PM
  #2453
phatbob02
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm going to order the H9 50 size. If the 100 doesn't fit, I have a new 82 that should be nice.
Old 09-12-2011, 01:36 PM
  #2454
Pit-Viper 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The .82 would be a great fit. You'll love that corsair it comes with a very nice hatch that gives you easy access to everything. The one I flew had the fuel dot and air for retracts inside the hatch so you can keep the outside clean and not have to drill or cut it up.
Old 09-28-2011, 03:24 PM
  #2455
JVB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a Hangar 9 Corsair given to me. It had been through a few missions if you get my drift. I didn't really want it but said what the heck and put a DLE 20 engine in it. I can't keep the plane on the ground during takeoff. It starts flying when I give it some throttle. The balance is right on 5 inches. I'm thinking I may have a thrust problem. Where should the thrust line be on this plane. I had to change the mounting arrangement for the gas engine. Any other suggestions are welcome.
Thanks.
JVB is offline
Old 09-28-2011, 03:44 PM
  #2456
gibatta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try to balance at 4 1/2", & make sure you have right amount engine trust (linear with fuse), once in the air trim your plane for straight flyght
gibatta is offline
Old 09-28-2011, 04:38 PM
  #2457
Pit-Viper 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As long as you mounted the engine flush to the firewall the thrust line should be ok unless it was repaired and not don't properly. One way you can check to see if you have a thrust issue is first to be sure your balanced lateraly.! (wingtip to wingtip) then when you're flying get it flat and level at 1/2 throttle then punch it quickly. If it climbs you need to shim the motor down slightly and if it goes down then you need to shim it up. If it flew fine where the CG was at then I would leave it alone. I always balance mine slightly nose down with the CG right on 5". If everything is fine it may be a case of a little to much elev. on takeoff which isn't uncommon. Hope this helps..
Shane
Old 10-07-2011, 04:09 AM
  #2458
JVB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys. How about the vertical alignment of the engine? Is the prop shaft (engine centerline) supposed to be lined up with the horizontal cross hair lasered into the firewall? Mine is about 7mm below that line. I don't think that little bit would make much difference anyway, but you never know. I think I will move the cg forward to about 4 inches and see what that does.
JVB is offline
Old 10-07-2011, 05:16 AM
  #2459
Pit-Viper 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As long as the tanks centerline is lined up with the carb correctly it should be fine. If you can move the engine mount in the slots on the firewall i would just to make it right.
Old 03-11-2012, 01:54 PM
  #2460
shane55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have about 15 flights on my H9 corsair 60 and have been having a problem with noseovers and the resultant Fin damage. I see earlier in this thread that the problem can be solved by shimming the gear forward. I will try that. Today however the Ball on the U/C leg sheared off where it threads into the collet. Are these available as a spare? I'll probably need the collet as well as the theaded part of the ball stud is still in there.
shane55 is offline
Old 03-11-2012, 02:26 PM
  #2461
Dangaras
Dangaras's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take the part to your lhs if they have helis. These are standard parts for cars as well I think.
Dangaras is offline
Old 03-11-2012, 03:04 PM
  #2462
shane55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks but I dont have an LHS, I'll have to order online. I was hoping someone might have found a replacement before......
shane55 is offline
Old 03-11-2012, 07:00 PM
  #2463
Black Drape
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shane55
I have had the same problem with my Corsair. My lhs has both cars and helis, but none of the balls are the same size. I had to order new gear. They are only about $25 bucks a set, but it still is a pia.
Ron
Black Drape is offline
Old 03-12-2012, 03:05 AM
  #2464
shane55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The balls are actually a fairly standard size, 3/16 inch or 4.75mm diameter. The threaded shank is standard as well 4-40 or m3. The length would have to be spot on though so that the leg rotates the correct amount. I've been looking online and seen loads of parts that look right but  they dont have all the dimensions listed. Only hope is to try emailing the websites to see if they will actually take measurements for me. I know that the retracts are fairly cheap but do these ball studs fail regularly? If they do It makes sense to source a replacement
shane55 is offline
Old 03-12-2012, 04:40 AM
  #2465
Dangaras
Dangaras's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are a weak point and I also lost one. The guys at my LHS have a goid stock of parts, nuts, bots, screws, ball links, etc and got me a replacement in all of 30 seconds.
Dangaras is offline
Old 03-12-2012, 06:11 AM
  #2466
shane55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you remember the brand,part no.etc ?
shane55 is offline
Old 03-15-2012, 03:25 AM
  #2467
shane55
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I Think Ive Found a part that will work: https://www.quickuk.eu/products/420/...ng_hp-036.html
The distance from the mounting face surface to the ball centre is 9mm on the failed part, while on this part the distance is 8mm. The threaded part on this is 6mm long however while the failed partthread is 3.5mm long. 1.5mm could be filed from the end of the thread of this replacement. Then when the part is tightened in the collet, 1mm of the thread would be above the surface of the collet, making up the 1mm difference in the distance between the ball centres and mounting face. The ball is the required diameter 3/16"
shane55 is offline
Old 04-05-2012, 08:35 PM
  #2468
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I tried to sell it many times in a few Threads throwing hints, but there were no takers.
So, I feel like the last rose of the summer, because I'm really late in comming into this Thread.
I decided to keep my H9 Corsair. In fact I started the conversion to chande it into a F2G-2 or F2G-1.
Certainly I'll remove all the covering to glass and paint the model, but currently I'm working on the scale rudder.
I've drawn outline plans and have to decide on an engine choice.
Probably gas because I want to swing a large prop. I'm thinking the 26cc.
I'll probably have questions about much of this. I did look over about 30 pages of this Thread.
Here's my efforts so far. I still have other pieces to make for the rudder, but I started drawing the parts for the stab and elevator.
Charles
ID:	1747211   Click image for larger version
ID:	1747212   Click image for larger version
ID:	1747213   Click image for larger version
ID:	1747214   Click image for larger version
ID:	1747216   Click image for larger version
ID:	1747217   Click image for larger version
ID:	1747218   Click image for larger version
ID:	1747219   Click image for larger version
Avaiojet is offline
Old 04-11-2012, 02:42 PM
  #2469
Avaiojet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone interested in the H9 Corsair to the F2G Corsair #57, can see this Thread at this RCU link.
http://www.rcuniverse.com/forum/m_16...m.htm#11037152
Hope there's interest!!
Charles
Avaiojet is offline
Old 04-23-2012, 10:33 AM
  #2470
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got round to building mine, going for a scale project with custom paint job, TF cockpit, Lado retracts and Robart scale wheels.
ID:	1754009   Click image for larger version
w1nd6urfa is offline
Old 04-23-2012, 10:40 AM
  #2471
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question:
I got the [link=http://www.advantagehobby.com/195224/TOPTOPA1837/?quantity=1]TF Corsair decals[/link] which are the right size, and include a lot of "miscellaneous" markings which I am not sure where to place (see pics)
Any ideas?
ID:	1754011   Click image for larger version
ID:	1754012   Click image for larger version
ID:	1754013   Click image for larger version
ID:	1754014   Click image for larger version
Old 04-29-2012, 05:46 PM
  #2472
m3_express
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice. I was going to go with tri-color scheme as well but ended up trying something a little different... I'm using the same TF cowl and canopy.
hk
ID:	1756717   Click image for larger version
m3_express is offline
Old 04-30-2012, 05:53 AM
  #2473
w1nd6urfa
w1nd6urfa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice!
I like the 3-blade prop, what motor-prop combination are you using?
Old 04-30-2012, 09:11 PM
  #2474
m3_express
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I currently have one of those new turnigy SK3 320kv motors. The prop is a vario prop setup as a 15x14. I'm running it on a 6S setup.
hk
Old 05-01-2012, 03:37 AM
  #2475
Dangaras
Dangaras's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
15*14, wow. Thats some nice pull, she looks nice with the Royal Navy roundels.
Dangaras is offline
Reply
Display Modes
