RC Guys 33% Pitts S1 ARF
#251
My Feedback: (19)
Yeah, Pitts are different, but they're worth all the tweaking, and incredible flyers when that's done.
I'm gonna miss this hobby, no doubt in my mind. But I'll keep monitoring RCU and putting in my two cents worth, and in general being annoying wherever possible.
~ Jim ~
~ Jim ~
#252
My Feedback: (23)
Jim,
Sorry to hear that your leaving the hobby. I always found your aerodynamic explanations to be top notch and easy to understand for us dummies. [might be a good theme for your new book "aerodynamics for dummies]
Maybe you should just take some time off from the hobby, focus on other stuff and maybe then come back to it.
Anyway, hope all is well with you and your family and that you are all settled in in your new home….
paul
paul
#253
My Feedback: (19)
Thanks, Paul.
I'll still come in here and put my two cents worth in from time to time. But I'm moving on as far as the hands-on part of the hobby. Too many other hobbies demanding my time and my money. The truth is, what I spend on my planes would pay for all my other hobbies combined. That's pretty remarkable when you look at how expensive guns can be. But then, you don't usually take a two-thousand dollar gun out and crash it into the earth at 90 miles per hour.... The gun can last you your whole life, protected in a safe when you're not using it. Plus, I've already collected and customized the ones I want, so my reloading supplies (for my OTHER hobby - reloading!) end up being my typical hobby expense.
My "Other" hobby (another Other!) is also related, and that's fishing. You could buy my little boat outright for the cost of two planes. Anyway, you get the idea; what little fishing gear and reloading supplies I normally use won't amount to a fraction of what I spend on planes.
I promised my wife that I'd cut down on my most expensive hobbies, and we moved here to Washington so I could get out there and hunt and fish and hike and boat, so as much as I might have been avoiding it up until now, it's only logical that my RC planes are what's on the chopping block.
But it doesn't cost anything to drop into RCU and spend a little time, so I'll try and visit now and again.
~ Jim ~
~ Jim ~
#254
So, curious. Anyone else gotten into the air with the VVRC 40 twin in this plane? What kind of AUW are you getting? I have the VVRC in a 16 pound 92-inch Decathlon and it flies really nicely. Have to fly the plane rather than let an over-sized engine drag it around the sky.
But I am strongly considering this plane and would appreciate any feedback anyone can share. I know this is a bit of a zombie thread, but I thought I'd try.
#255
Hi folks,
I may have asked this before, but has anyone tried the Saito 57cc gas twin or its 300 twin nitro cousin in the RC Guys Pitts? I don't think it's too powerful, being 4-stroke and a twin, but it's pretty heavy at 73 oz. I have checked, and the cowl is large enough, even for this engine.
For other engines, can anyone give me an idea how much nose weight they have had to add (or not)?
Thanks much!
Thanks much!
#256
My Feedback: (19)
That's a bit heavy for it. The Valley View 40CC Twin with mufflers weighs around 50 ounces, I think, and that was about perfect for balance in mine. The Valley View ad says it weighs 44 ounces, but as I recall, I found it was heavier than that, so I'm estimating 50 ounces max (But, as I said, it was PERFECT for balance in my RC Guys Pitts). 73 ounces is a full 23 ounces more than that, and I think the plane could manage it, but I think that much weight would make the plane fly too heavy, and that's not even including the tail weight you'd likely have to add.
I hope this is of some help to you.
~ Jim ~
~ Jim ~
#257
~ Jim ~
~ Jim ~
#258
My Feedback: (19)
That's the spirit, Jim! And a shout-out to San Antonio!
I'm pretty sure that, with at least 23 ounces or more difference, there would have to be significant weight added to the tail even AFTER moving all of those. I probably should have made that more clear in my post. I think most of us would shift whatever we could first to see whether it would mitigate the problem. I've put battery packs far back in the tail before to avoid adding lead to a model.
~ Jim ~
~ Jim ~
#259
My Feedback: (21)
NY
Hi, Not sure if this thread is active much any more but I have a couple of questions onthe RC Guy’s Pitts…
Did you keepthe elevators connected with the wire and use one servo -- or –did you opt for separate servos with thetwo servos mounted in the rear under the Horizontal Stab ?
Did any ofyou “beef – up “ the area where the Landing Gear mounts?? I think I want to at least add a ply doublerinside ??
Thanks inadvance !
Tom
Thanks inadvance !
Tom
#263
well I have flown mine lots. I have a very heavy fpe 3.4 57cc gas motor split elevator servos and most heavy equipment in the rear. this is a great flier with heavy engines as its a biplane with lots of lift! I cant say enough good about this plane. It flys so nice! Its so easy to land come in high chop the throttle and come in steep. it slows down fast!!
#265
My Feedback: (21)
NY
So I am using a DLE55 so I will be splitting the elevatorsand using 2 servos mounted in the rear under the Stab. I was wondering IF anyone who has done this might have pictures and or dimensions as to where you located the ElevatorServos?? Thanks in Advance !
Tom
Tom
#270
My Feedback: (21)
NY
MOUNTING THE COWL ? Did any one cut into the cowl to clear the Cabines on top and or the Landing gear on the bottom ?? I have a DLE 55ra mounted on the plane, If I put the cowl on all the way up to the Gear and the Cabines.. It looks like I still lack about 3/16 for clearance... Do I cut the cowl or put a spacer behind the mounts ???
#271
have you tried to do a cg balance yet? You mite need to extend the engine far forward as you can to help with balance. Mine is extended forward I used 3/4 hard wood dowel for my extensions.
#274
My Feedback: (21)
NY
or170b, Hi this forum is pretty 'dead" I think But I have a lot more questions.. I tried to send you a private message but I don't know if it went ?? could you shoot me a message with your Email so I could just send you and email with my Questions??
Thanks !
Tom
Thanks !
Tom
#275
Just starting to build one of these....ordered direct from Dan at RCGUYS, got the Red/White/Blue one.
Will be using a DLE-55RA.....what size standoffs did ya'll use?
Looking at Elevator servos in the tail......kinda wanted to mount the Rudder servo in the back as well.. Maybe? Maybe not.
