Reload this Page >
Black Horse Gilmore Red Lion 46 ARF assembly thread-REVIEW
Old 10-08-2014, 10:36 PM
Kostas1
Kostas1's Avatar
Replacing the BH hinges with GP CA+.
Old 10-08-2014, 10:42 PM
Kostas1
Kostas1's Avatar
I use this Robart tool to drill a 3mm hole in the center of the surfaces and in the center of the CA hinge slot to help CA+ get on the inside.
Also,
draw a center line on every hinge to help you during the installation. Every hinge has to go by 1/2 and 1/2 between the control surfaces.
ID:	2038637   Click image for larger version
ID:	2038638   Click image for larger version
ID:	2038639   Click image for larger version
Old 10-08-2014, 10:44 PM
Kostas1
Kostas1's Avatar
Everything in place waiting for some thin CA+ to come!
ID:	2038641   Click image for larger version
ID:	2038642   Click image for larger version
ID:	2038643   Click image for larger version
ID:	2038644   Click image for larger version
Old 10-08-2014, 10:45 PM
Kostas1
Kostas1's Avatar
Ready to proceed in the next steps of the assembly!
Old 11-09-2014, 10:12 PM
Kostas1
Kostas1's Avatar
Wink
Update from the craddle, after the quick paint job!
ID:	2046238   Click image for larger version
ID:	2046239   Click image for larger version
Old 11-09-2014, 10:16 PM
  #31
Kostas1
Kostas1's Avatar
Hitec servos with universal connectors to fit my Futaba Rx and appropriate hardware!
ID:	2046241   Click image for larger version
ID:	2046242   Click image for larger version
Old 11-09-2014, 10:20 PM
  #32
Kostas1
Kostas1's Avatar
Test fit:
ID:	2046244   Click image for larger version
ID:	2046245   Click image for larger version
Old 11-09-2014, 10:52 PM
  #33
Kostas1
Kostas1's Avatar
Lightbulb
Here's how I usually connect the extensions on my RC servos, to avoid any unwanted disconnections due to vibration:
https://www.youtube.com/watch?v=RThcbTmVxr0
Old 11-10-2014, 09:10 AM
  #34
Capt Easy
Kostas -
I maidened a 46 size Black Horse Red Lion in Oct 2011converted to a Monster Power 60 electric on 5S lipo. It flew well but the landing gear was terrible and I had to completely tear it out and am rebuilding a stronger one piece aluminum main gear. I haven't done anything more with it but hope to have it flying again sometime before next Spring.
Good luck with your build and enjoy. It's a beautiful plane not without defects but I think it's a pretty good flyer.
Dick
Old 11-10-2014, 09:25 PM
  #35
Kostas1
Kostas1's Avatar
Originally Posted by Capt Easy
Kostas -
Dick
Dick,
thanks a lot for your kind and informative response.
Yes indeed, the landing gear wires and overall setup looks a bit flimsy, I wonder how I'll end up reinforcing it.
Have you done any thoughts or work on that direction?
Old 11-11-2014, 12:00 PM
  #36
Capt Easy
I'll take some photos of what I've done to mine later. I plan to bolt a one piece aluminum gear to a block of hard wood I built into the center section. Then attach the whell fairing and pants to that. That's my plan but not sure when I'll get back to it right now.
Dick
Old 11-19-2014, 10:46 PM
  #37
Kostas1
Kostas1's Avatar
So,
elevator and rudder horns installed.
Wing is ready, but i have to figure out how to reinforce the undercarriage!!!!
BTW, the black plastic inserts that BH supply with the Gilmore are very soft.
They are designed to accommodate a tiny nut and don't let it turn when you fasten the blue plastic control horn on the bolt.
BUT as I said the black plastic insert is soft and @#$#%#$% :P
ID:	2048675   Click image for larger version
ID:	2048676   Click image for larger version
Old 01-19-2015, 11:04 PM
  #38
Kostas1
Kostas1's Avatar
Exclamation
Continuing the assembly of the Gilmore:
First I trimmed the excess aluminium rod on the tail wheel
(the supplies one protrudes too much)
Old 01-19-2015, 11:07 PM
  #39
Kostas1
Kostas1's Avatar
Here's how the elevator halves are coupled together!
I find this method very effective and from what I've seen so far,
it's the simplest and easiest-dependable way of all!
ID:	2065547   Click image for larger version
ID:	2065548   Click image for larger version
Old 01-19-2015, 11:10 PM
  #40
Kostas1
Kostas1's Avatar
Here you can see how the fuselage looks like and the servo for the rudder!
As you may have seen,
I installed a very sturdy Futaba digital servo (S3152)
on the elevator....
I'm sure that with the YS in the nose, this puppy will be a bullet!
ID:	2065550   Click image for larger version
ID:	2065551   Click image for larger version
ID:	2065552   Click image for larger version
Old 01-19-2015, 11:16 PM
  #41
Kostas1
Kostas1's Avatar
We continue with the installation of the motor mount and engine...
I use a 40-70 GreatPlanes adjustable motor mount!
The bolts are DuBro socket head cap screws 6-32 by 1-3/4, 6-32 blind nuts and #6 washers.
ID:	2065554   Click image for larger version
ID:	2065555   Click image for larger version
ID:	2065556   Click image for larger version
ID:	2065557   Click image for larger version
ID:	2065558   Click image for larger version
Old 01-19-2015, 11:19 PM
  #42
Kostas1
Kostas1's Avatar
Hint:
I saw that the wood on the firewall is on the soft side!
So,
when you install your blind nuts I suggest you to be very gentle and not overtighten them.
And to be more secure I installed two safety nuts diagonally at the end of the SHCS's.
ID:	2065561   Click image for larger version
ID:	2065562   Click image for larger version
ID:	2065563   Click image for larger version
ID:	2065564   Click image for larger version
ID:	2065565   Click image for larger version
Old 01-19-2015, 11:23 PM
  #43
Kostas1
Kostas1's Avatar
Oh and the most important!!!
USE THREAD LOCK WHEN YOU INSTALL SHCS's,BLIND NUTS etc
I then test fitted the engine and marked the center of the holes to be drilled,
with a very handy GreatPlanes Dead Center Engine mount Hole Locator!
ID:	2065567   Click image for larger version
ID:	2065568   Click image for larger version
ID:	2065569   Click image for larger version
Old 01-19-2015, 11:27 PM
  #44
Kostas1
Kostas1's Avatar
Hint:
When I install an engine on its mount, I ALWAYS drill and TAP the holes....
This way someone wouldn't even use safety nuts, because the threads are really strong...
So try it!
In this case I use a #6 tap!
Old 01-19-2015, 11:29 PM
  #45
Kostas1
Kostas1's Avatar
SHCS installation!
ID:	2065572   Click image for larger version
ID:	2065573   Click image for larger version
ID:	2065574   Click image for larger version
ID:	2065575   Click image for larger version
Old 01-19-2015, 11:31 PM
  #46
Kostas1
Kostas1's Avatar
As you see I use #6 Safety nuts and #6 washers!
ID:	2065577   Click image for larger version
ID:	2065578   Click image for larger version
ID:	2065579   Click image for larger version
Old 01-19-2015, 11:33 PM
  #47
Kostas1
Kostas1's Avatar
Test fit of the cowl!
I am so excited that the YS FZ-63S fits nicely inside the cowl!
ID:	2065581   Click image for larger version
Old 01-19-2015, 11:37 PM
  #48
Kostas1
Kostas1's Avatar
And this is the installation of the throttle control linkage!
The flexible steel pushrod is of A+ marine grade.
The connectors are GreatPlanes quick-connect hardware!!!
ID:	2065583   Click image for larger version
Old 01-26-2015, 12:50 AM
  #49
Kostas1
Kostas1's Avatar
The assembly continues with the final "touches" to the wing...
I have to admit that the whole setup of the legs s@cks.
On my Gilmore the undercarriage had a slight bent towards each other.
Also,
the way it fastens on the wing isn't the most sturby you've ever seen.
I am pretty sure that in case of a hard landing the legs are going to have a problem staying in position.
Ah, the wheel pants...D@mn D@mn D@mn.....How many times I'm gonna write this.
The whole setup is totally wrong....Could have thought of something simple and good looking.
ID:	2067882   Click image for larger version
ID:	2067883   Click image for larger version
ID:	2067884   Click image for larger version
ID:	2067885   Click image for larger version
ID:	2067886   Click image for larger version
ID:	2067887   Click image for larger version
Old 01-26-2015, 12:53 AM
  #50
Kostas1
Kostas1's Avatar
Here I install the wheels and the cover of the back side of the wing (on the belly of the plane).
It is made out of light ABS plastic. Also I saw a small difference in the colour of the belly cover and the fabric of the fuse.
You just have to cut the area towards the wing bolts (trailing edge of the wing), apply a couple drops of CA+ and that's it!
ID:	2067889   Click image for larger version
ID:	2067890   Click image for larger version
ID:	2067891   Click image for larger version
ID:	2067892   Click image for larger version
ID:	2067893   Click image for larger version
ID:	2067894   Click image for larger version
ID:	2067895   Click image for larger version
