Revolver 70 fuel dot locations
Old 07-18-2015, 01:55 PM
PDF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Revolver 70 fuel dot locations
Hello all,
I would appreciate some advice on where to install the fuel dots and the Revolver. I don't want it on the cowl, and in front of the wing near the firewall area doesn't have much space and that's where I think it would have to go but I'd have to install some plywood since in front of the wing is mostly ultracote. I'd have to back that area with plywood to even consider installing it there plus I'd be concerned that when refueling the tube would be above the landing gear and wheel pants and I don't know if the fuel would damage it. Any suggestions on where you install them would be appreciated.
Thank you,
Pat
PDF is offline
Old 07-18-2015, 09:51 PM
Indiomike
Indiomike's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put mine about 1 1/2 inches aft of the cowl on left side fuselage. I had to glue in a piece of ply to attach the fuel dot. Pretty much like you described in your post. I've had no issues with gas affecting the landing gear or wheel pants.
Indiomike is offline
Old 07-19-2015, 01:31 AM
PDF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you very much for the reply, after thinking about it I really shouldn't have an issue with the fuel spillage.
Thanks again,
Pat
PDF is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
