Tower Kaos 40 or Great Planes Big Stik 40?
Those are both good (GREAT!) sport planes, highly aerobatic in the right hands, but that's about where the similarity ends. The Kaos will be the faster flying of the 2 (noticeably faster) with greater stability for precision flying, and great wind penetration. The Stick will be the more laid back/comfortable flier, with lower take off and landing speeds. My thoughts anyway... -Al
I'd go with the Kaos a great flying and is well built. I've flown one for many years and plan on always having one around. It can be flown quite fast but can be slowed down for landing.
IL
I will add both are great airplanes.
You need to decide what type of flying you will use it for:
Speed get a pylon plane
Aerobatics get the Kaos
Sport (larger weather and conditions envelope) get the Stick
Scale get something scale
I agree that both are Great planes . Now what kind of flying do you DO NOW ? If you are advanced then the Kaos could be for you . If you have just started flying / soloed then you might need to look at the Stick. This is a great sport and shouldn't be rushed, take your time and "Smell the rose's " . ENJOY !!! RED
The reason I put the question out there was that I'm thinking of retiring (junking) an Avistar that I've bashed up enough. It's kind of a long story where I changed the original dynamics by converting it from a tricycle gear to a conventional tail dragger. Making it a phenomenal ground looper on takeoff. Low wind days it's not bad, but just a regular breeze can make it spin around. I could fix it one more time, but not sure if I want to invest the time or money to convert it back to stock. It is fixable.
I recently completed a Tower Uproar that I have flown and certainly enjoy. I'd consider my flying skill level as novice, but would like to expand to my skills. I'm pretty much just a sport flier. Not sure what I want to do and guess was thinking maybe between the two I could whip one of them together without too much trouble. WITHOUT MODIFYING it TOM!
