Reptile S800 Sky Shadow - FPV Racing Wing
Halloa people
time for another episode in my 'Airplanes Sunday' series This time it's not just a line-of-sight airplane though.. For of a FPV racer fixed-wings style You might be awere of the 'new' FPV racing thing with planes, which is mostly done with flying wings I think.. And that is what this EPP wing is..
Link to this plane: Reptile S800 Sky Shadow PNF
Link to the KIT version: Reptile S800 KIT version
This might actually be a slightly longer series then your used to from me.. I'll first fly the wing mostly stock, and that's With the included stabeliser / gyro / PDB.. Afterwards though, I plan to replace that combo with a Naze32 or F3 board.. and maybe a PDB with OSD and.... and GPS
For now though.. let's have a look what this wing looks like:
https://www.youtube.com/watch?v=yQu3bxrZmD0
Specs:
Model: Reptile S800 Sky Shadow:
Material: EPP foam
Wingspan: 820mm
Length: 405mm
Root chord: 210mm
Tip chord: 160mm
Sweep: 220mm
CG: 125mm from the nose back
Motor: SunnySky 2205 2300Kv
ESC: Reptile 25A
Prop: 6045
Servo's: Emax ES08A 9g
FPV camera: 700tvl Cmos
VTX: 2.4Ghz 200mW 48ch
Specs:
Material: EPP foam
Wingspan: 820mm
Length: 405mm
Root chord: 210mm
Tip chord: 160mm
Sweep: 220mm
ESC: Reptile 25A
Prop: 6045
and.. a small little update in my build.. Primairly about my FPV setup & HD cam mount..
https://www.youtube.com/watch?v=9hqmIdzFnMo
The FPV camera I'll be using: Foxeer Monster HS1194
HD camera I'll use: SJcam SJ7 Star
Maiden flight time for the S800! I don't have an FPV cam in it yet, but that's okee.. I first test things line of site anyway.. I did record the flight with an onboard cam as well though
https://www.youtube.com/watch?v=AnMtFKk-S5U
sooo. another update to This project today I finally have an FPV cam in the plane, so now I can really fly it as intended
This is the cam I opted for: Foxeer MONSTER HS1194 1200tvl cam
and here is a review of the camera itself:
https://www.youtube.com/watch?v=fKa8eyvQ3iA
