GP Waco .91-1.2 - need three measurements
Would like to get three dimensions from the .91-1.2 Waco ARF. With the plane sitting on landing gear on a flat surface....
1. Distance from where bottom wing meets the fuse to the surface.
2. Distance from bottom of rudder at the hinge joint to the surface.
3. Distance between where the bottom wing meets the fuse to the rudder hinge joint.
Thanks.
Thanks.
