Foamy homey?
Foamy homey?
I just acquired a foam plane ,an it doesn't have rudder ,it only has airelons ,I know that a plane can bank and turn on airelons when they are set to go
the opposite way from each other!
Question is,can I benefit from going ahead an adding the rudder ,or just leave it alone?
It is no problem adding the extra micro servo & push rod for it!...
It is not a v tail ,the rudder is fixed straight an it came out stock with out a rudder set up its been flown with out rudder ,an only banked turns using
ailerons & elevator!
I would prefer a rudder mode until I get use to flying it ,its a low wing WW2 plane electric that I bought used!
I'm putting in my own radio gear!
Well this is the first time that I seen a plane with out a rudder used other than a fixed rudder on a CL!
I been doing some work on it ,got the radio gear going an motor running ,I just have to purchase the micro servo's ,an
cut the rudder & add the hinges an horn!
I had just got done building an soldering a temporary battery pack for it until I get some lipo's!
I will get some pics up or atleast a vid ,I do have a Go-pro ,just haven't learned how to use it yet ,dang camera
quit!....
