Can't figure this out.
Reply
Old 06-14-2018, 08:47 AM
Norm Nestie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can't figure this out.
Been away from flying for a while and trying to get back into the groove. Decided I needed a plane that would hopefully help me get my confidence back so I ordered an Avistar elite. Would really like to make it a tail dragger as our field is not kind to nose wheel set ups. Need to put on a steerable tail wheel and would normally connect to the rudder but not so easy with this plane. Anyone converted this plane to a tail dragger that might share a suggestion or two. I'v considered a seperate push rod from the rudder servo to the tail wheel but wondered if there is another way Thanks, Norm
Norm Nestie is offline
Old 06-14-2018, 02:27 PM
Tom Nied
Tom Nied's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could run a separate rod, would be tricky getting it in there right. I think an easier solution would be run a rod from the rudder through the fuselage so that you could connect it to something like a Sullivan tail wheel bracket, also could be tricky. Pick your poison.
Tom Nied is offline
Old 06-14-2018, 02:33 PM
Norm Nestie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lightbulb
Thanks Tom, gives me an idea
Old 06-15-2018, 06:18 AM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I normally dislike the long torsion rod through the fuselage and find those problematic as being to spongy unless excessively large diameter rod is used.
Done many conversions and also dislike the the tailwheel on a removeable bottom plate wth an internal bellcrank technique. Those are more difficult to build and make adjustments difficult both in build stage as well as while at the field.
I much prefer for most airplanes the double pushrod technique. Only a little more work but far more positive ground steering. Remember to try to keep the rod as straight as possible and make a new fuse outlet hole wherever needed for the best straight runs (no bending) as well as ease of installation.
Also on your conversion remember to make sure after conversion that you achieve the same CG as what it flew best at before conversion. In other words don,t make the mistake of being temped to move the cg a bit if the airplane wants to nose over while taxing That is always related to main gear geometry and a function of where you choose to position the fore and aft location of the main gear.
In regards to that all important choice you must make with any tricycle to conventional gear conversion. If you position the main gear footprint too far aft toward the CG landing will be very easy but also tend to noseover during taxi. If you position the main gear footprint too far forward there will be no nose over tendencies but the airplane will tend to crow hop and become bouncy during landing.
John
JohnBuckner is offline
Old 06-23-2018, 02:04 PM
Norm Nestie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default All Good
Thanks, John. Norm
