Hanger 9 Fokker DVII
Reply
Old 08-28-2019, 02:24 PM
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got all the goodies from Bunnings after work.4 x stainless steel hose clamps and a packet of stainless steel cable ties. I also got some silver high temp exhaust cloth. I'll wrap some around the pipe and secure with the SS cable ties so I am not getting metal to metal rubbing.
As you can see from the photo the exhaust pipes will secure to the standoffs.
Should work well.
cheers
PClick image for larger version
planenutzz is offline
Old 08-28-2019, 09:30 PM
hpergm
hpergm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by planenutzz View Post
mmm I'd be reinforcing what is left of that firewall, especially around the bottom of that "V". Vibration cause it to splt there.
Carbon fibre cloth epoxied in place and a strap accross the top to lock that in.
Thanks for the advice, I am already thinking how to mitigate failures in this area. You are right, some cloth might be in order here. Anyhow, any noseweight is good!
hpergm is offline
Old 08-29-2019, 12:36 PM
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good to read you will address that, I'd hate to see the model with major structural weakness and possible loss in flight die to the mount failing.
Back to mine. Muffler & exhaust system is now in place using the BBI muffler and supplied bendy pipes. Secured to the fuffler with stainless steel hose clamps and two wraps of high temp heat shielding at the bottom.
I secured the bottom of the pipes to the engine standoff using 2 stainless steel cable ties.
Quite happy with the outcome.
Next job is to adjust the throttle rod, set that throw, connect fuel line to carby, fit the 2 x battery packs then it will be ready for CG checks and an engine run.
Old 09-02-2019, 12:42 PM
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Happy to report all jobs now completed.CG with battery packs just behind the firewall is spot on the 7" from the LE as per the manual. Hopefully H9 have it correct for once.
Ran the engine and it runs well though the 20x8 may be too much prop for the G-38. Will see how it performs in the air.
The engine runs very queit with the BBI muffler and my isolation mount sysem works exceedingly well. There is hardly any vibration back through the airframe. So much for the naysayers [img][/img]
You tube link to the engine run. There are some other of my H9 1/3 Pawnee engine run and test flight as well. I managed to get bitten by the prop trying to start it, luck I had a thick welding glove on. Even then I have badly bruised right middle finer and its bruised and d amn sore. Electric starter only from now on.
Also learnt something about walbro type carbys and the diaphram. The nipple on the diaphram has to hook into the form of the neddle vale arm or you will get over fuel issues and dripping from the carb.
ID:	2265141   Click image for larger version
ID:	2265142   Click image for larger version
ID:	2265143   Click image for larger version
Old 09-08-2019, 02:12 PM
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Was hoping to do the heavy model certifaction and test flight on sunday but wind was far too strong to even think about it.
Old 09-29-2019, 04:05 AM
  #31
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has it flown yet ? :-)
I have just ordered one, and will be using a roto 35cc
SJN is offline
Old 10-30-2019, 06:05 PM
  #32
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
test flew the fokker last sunday, only some down trim required. CG was spot on.Flew about in a scale like manner, for rolls and loops get some height, point the nose downhill and execute.
Fairly simple. Landing was easy.
Old 10-30-2019, 08:49 PM
  #33
jwrich
My Feedback: (17)
jwrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lookin' good the 38 sounds great.
Happy Flyin'
Rich
jwrich is online now
Old 10-31-2019, 03:46 AM
  #34
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congrats on the maiden.
Bought the OS 40cc 4 stroke for mine........and the Blue Max fighter ace medal is a must when owning this plane
SJN is offline
Old 10-31-2019, 06:56 AM
  #35
jwrich
My Feedback: (17)
jwrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where did you buy the Blue Max?
Rich
Old 10-31-2019, 07:45 AM
  #36
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rich
Ebay, the replicas are everywhere.
Bought mine from ebay Germany, but im pretty sure they are all made in china :-)
SJN is offline
Old 10-31-2019, 08:54 AM
  #37
jwrich
My Feedback: (17)
jwrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Sonnich, I did not think of that.
Rich
Old 11-03-2019, 01:18 PM
  #38
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2 more flights on the Fokker Sunday. I have noticed the wheel hubs like to separate!
Old 11-20-2019, 05:26 PM
  #39
planenutzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Found out the wheels do not like any side loads on them as experienced during a couple of cross wind landings. Fixed up with 5min epoxy, not pretty but functional. Have ordered a new pair of wheels and will lay up some carbon fibre inside them.
ID:	2265736Click image for larger version
ID:	2265737Click image for larger version
ID:	2265738Click image for larger version
