Kangke Waco Biplane
Reply
Old 12-22-2012, 05:54 PM
  #651
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Kangke Waco Biplane
did everyone use 4 aileron servos or just 2, I was planning on using 4, I'm almost done except for the electronics and motor. I used black pin striping along the border of the red and silver, It really made it look nice. Another thing that puzeled me was they said don't remove and covering form the fin or stabilizer when epoxying them. Thats the first arf I'veput together that said that. I wonder why?
rstekeur is offline
Old 12-22-2012, 07:21 PM
  #652
apalsson
apalsson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rstekeur
I want to replace the aluminum tubes with brass or copper lines so I can solder the small barbs on the ends to keep the fuel lines from coming off, I didn't have any luck trying to solder the aluminum lines. I'm new with gas, but I've read the fuel lines expand with age and can come off the lines. Has anyone tried a 3 blade prop for clearance?
Mate, just flare the ends of these fuel tubes slightly with needlenose pliers or similar. No soldering needed
apalsson is offline
Old 12-22-2012, 07:29 PM
  #653
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You cannot solder aluminum, so brass is a must.
For my YS engines, after I bend the tubes to shape, remove it from the stopper so it does not get damaged. I solder two wraps of thin #24 gauge wire about 1/16" back from the edge with very small torch using standard electrical solder and paste flux, NOT the acid flux that comes with silver solder!
A little WD40 helps get the brass tubes though the stopper and after the lines are connected, I wrap the same wire around the fuel line twice then give it a few twists to hold the fuel line on.
Never had one blow off with the YS engines.
A large 100 watt soldering gun would probably work too.
Bill S.
Twin_Flyer is offline
Old 12-23-2012, 07:36 AM
  #654
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: apalsson
Quote:
ORIGINAL: rstekeur
Hey, thats a good idea. Thanks
rstekeur is offline
Old 12-25-2012, 03:24 PM
  #655
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What has everyone done that has used 8 servos done as far as plugging them into the RX? Is 8 to much for the rx or do you need a power bus for the current draw?
rstekeur is offline
Old 12-25-2012, 07:33 PM
  #656
apalsson
apalsson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rstekeur
Not for this plane. It's not that big and heavy that it justifies power distribution
apalsson is offline
Old 12-26-2012, 08:13 AM
  #657
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: apalsson
Quote:
ORIGINAL: rstekeur
Thanks apalsson, I'm tring to keep it as simple as I can. I've been looking at DLE 35ra's for the motor, and there on backorder everywhere. TowerHobby has a sale and the OS gt33 is close to the price. DO you think the os 33 is enough motor?
rstekeur is offline
Old 12-26-2012, 10:01 AM
  #658
apalsson
apalsson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm extremely happy with the MVVS 40cc in mine. Evolution are the same brand in the US, if you can get those. Another option might be ZDZ 40
apalsson is offline
Old 12-26-2012, 10:11 AM
  #659
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'ved looked for a zdz40 and haven't been able to find one listed
rstekeur is offline
Old 12-26-2012, 10:36 AM
  #660
apalsson
apalsson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What about Evolution 35cc or 40cc?
apalsson is offline
Old 12-27-2012, 07:32 AM
  #661
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the weight of the ZDZ40 is almost the same as the DLE55, HP is 5.5 for the dle and 4.8 for the zdz. Would a DLE55 be too much?
ZDZ40
Wt - 3.25 Lbs
Disp - 40 CC
Power - 4.8 hp
Prop - 20X8, 20X10
Static thrust - 22 lbs
DLE55
5.5 HP at 7,500 RPM
 Weight: Engine, 2.9lbs (1310g)
                  Muffler, 3.5oz (100g)
                  Ignition, 3.9oz (110g)
rstekeur is offline
Old 12-27-2012, 09:09 AM
  #662
apalsson
apalsson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, a 55cc would be an overkill for this plane
From memory, the prototype plane was flown on the ZDZ40 and the manual states it was at the top end of the power range
apalsson is offline
Old 12-27-2012, 09:32 AM
  #663
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe the best choice is to simply wait till the engine you want gets in stock somewhere?
Bill S.
Old 12-28-2012, 12:07 PM
  #664
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Twin_Flyer
Bill S.
That would be the best choice Bill, except I have some free time coming up in the next 2-3 weeks and It looks doubtfull on getting a dle30 or 35 in that time frame, and the choices in the 30-40cc size seem pretty limited. I have an OS gt33 on the way. I hope to get out flying in time. I'm going single battery with a battery eliminator filter from Troybuild so I hope to keep the weight down.
rstekeur is offline
Old 12-28-2012, 12:17 PM
  #665
railfly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you will have to cut a hole in the firewall so the carburator can fit behind the firewall so you have the proper clearance for the prop and cowl. I dont think you will for the dle 35. troy models handles the zdz engines and parts . A picture somewhere on this forum shows a dle 30 mounted and they did not cut into the firewall The dle35 is a rear exhaust but I done think it is any different as far as spacing the muffler fits under the carb and the standoff holes are wider for the muffler to clear. The ignition is rated for 7.5 volts which is nice can run a lifepo or lithium ion or run the ignition cutoff.
railfly is offline
Old 01-01-2013, 03:29 PM
  #666
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can anyone tell me how to set the incedence without a meter. I want to set it to +1 degree to make it easier to fly to start with.
rstekeur is offline
Old 01-02-2013, 04:49 AM
  #667
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Buy one!
Its worth it. I have several and use them all when setting up a plane before final gluing.
http://www3.towerhobbies.com/cgi-bin...?&I=LXET66&P=7
Bill S.
Old 01-02-2013, 06:18 AM
  #668
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bill, I guess I can use a level to get the top wing level with the bottom and then raise the front a 1/4"
rstekeur is offline
Old 01-02-2013, 06:31 AM
  #669
JL1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Set it on a level surface and measure the difference, from the surface, between the leading and trailing edges
JL1 is offline
Old 01-02-2013, 06:52 AM
  #670
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
But does 1/4" equal 1 degree?
I have used levels in the past as well just to check that things were at zero but I don't think there much good for any more then that.
belong to a club? if so, someone must have one you can borrow.
Harbor Freight also has a nice digital gauge one that can be used with RC with a little thought.
Bill S.
Old 01-02-2013, 07:42 AM
  #671
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That’s a good question, I slept through as much of geometry as I could. I know there must be a formula here somewhere. I remember many moons ago we used protractor gauges with rockets to get the altitude. I’ll ask at the field next time and see if anyone has a incedense gauge. I’m still waiting on the motor and servos to arrive from tower. Once I get that in hopefully I can balance it with the rx, regulator and battery placement.
rstekeur is offline
Old 01-25-2013, 08:56 AM
  #672
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All done with the Waco except for setting the Incidense which I'll do tonight so I might fly it sunday. I ended up with a OS gt33 for a motor. Didn't have to cut the firewall and it fit nice. I had to mount the cowl as far forward as I could. Where's a good place to start as far as the incidense. I want it to fly easy to start. Should I set it at 0 or +1
rstekeur is offline
Old 01-25-2013, 05:57 PM
  #673
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do you use for the datum line in setting the incedence, level the horizontal stab?
rstekeur is offline
Old 01-25-2013, 10:30 PM
  #674
apalsson
apalsson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rstekeur
Use the bottom wing and set the top wing 0 - +1.5 degree relative to the bottom wing for gentle flight. Be aware though the plane tends to balloon a bit if you set it full 1.5 deg positive.
I have mine set at 0 degrees and it is quite good
apalsson is offline
Old 01-29-2013, 08:05 AM
  #675
rstekeur
rstekeur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's all ready to go, if I can get a chance to tune the engine it might go flying sunday.
rstekeur is offline
Reply
Display Modes
