nexstar engine running backwards
IL
I started my nexstar today for the first time. It seemed to run fine but sometimes when I give it over half throttle It just dies. It starts right back up but sometimes when it starts up it runs backwards. Do all engines do this or and I doing something seriously wrong? is there any
way to prevent this?[sm=confused.gif]
My Feedback: (15)
OK
RE: nexstar engine running backwards
All of my MDS engines do it once in a while as do my OS engines. The OS's don't do it as often.
It happens more when you flip start them. A electric starter would cure the problem. I always flip start mine with a chicken stick, but I bump them clockwise against compression and they almost always start the right way now.
Jesse
Jesse
My Feedback: (9)
all 2 strokes will run backwards just as good as they do forwards. The case with our model engines is that they get their intake from the crank shaft at a specific point in cylinder travel, and when run backwards our engines try to push air out of the carb when you go above half throttle because of the timing of the intake hole in the crank. A dirtbike engine with reed valves howver will run backwards and wont have this problem. Usually when this happens to me on my os46fx i just play with throttle and get it to the point where its wanting to die and keep lower the throttle so it dosnt die, eventually you'll find you can get the engine to kick forwards the right way by doing that without it dieing. or just get an electric start and never have the problem, thats what i did. Just zing it and it starts right up!
sean
sean
If your motor is dying as you advance the throttle, it might be a little too lean. You could also try opening the throttle til it starts to die then open the needle valve a bit. If it picks up and runs better, it was lean. A too rich engine will blubber and spit some but will usually run. A lean one will quit. An electric starter won't make it run any better. Just makes it start the right direction. Also sometimes the throttle setting(open too far) will make them start backwards.
[8D]hi
generally this is due to a too rich setting of hight speed needle valve. close needle valve and open about 1 1/2 turns, start engine with will be running very rich and slowly lean for max rpm and then richen to lower rpm slightly. this will make th engine run on the slight rich side. also sometimes when this happens you can flip the prop backwards to start, then adjust needle valve for proper running.
then when you reach this point you can briefly pinch the fuel line to the carburetor and if properly set the rpm should increase slightly. just briefly pinch the line.
good luck and happy flying...hope this helps
joe
joe
