GP Super Stearman
#1376
RE: GP Super Stearman
Shubova,
You may want to look at replacing the stock wheels with 4" du-bro's. I also modified the tailwheel so that is not attached to the rudder but has it's own servo, slaved to the rudder channel I also replaced the stock wheel with a 1 1/2 unit. I have not had a chance to check this modification out (too cold and windy) but it should help slow the tail wheel down.
#1377
My Feedback: (14)
you guys with a radial on your GP, have you got smoke system? I have Saito 170 with Keleo ring exhaust but in thinking of smoke system I dont thing it gets near hot enough for smoke system to work any good, anyone?
#1378
CA
I'm setting my CG and if I thinking back on everything that I have read. The 5 1/2" that they say to set the CG, a lot of the planes ended up tail heavy. I'm thinking of setting my CG at 5 3/8" or 5 1/4". What do you guys think about that idea? What is the weight of your planes when completed. Thanks for any help
#1379
I need Help!! Does anyone who used 4 servos have a aileron connecting rod not being used laying around. I have one unusable & thats all I need to finish. Thank You My e-mail address is [email protected]
#1380
My Feedback: (9)
CA
Doesn't GP (Tower Hobbies) sell them. If were I you I would call GP or Tower and tell them one is defective...they are pretty good at working with their customers.
If you get no responce from them. I may have mine somewhere...I'll look for them today.
If I can find them I'll e-mail you but you should try GP first.
Good Luck!
Shubova
[8D]
Good Luck!
Shubova
[8D]
#1381
AB, CANADA
ORIGINAL: Capt. Ron
I'm hoping to start my Stearman in a week or so, just finishing up a RC Guys Decathlon.
#1382
FL
My Great Planes PT-17 flies great balanced per the instruction manual, which IIRC puts it about where the rear cabanes attach to the underside of the upper wing. I don't know if the white Stearman's CG is listed in the same place or not.
Rick
Rick
#1383
Mine was really bouncy at landing time and needed elevator correction to stop it climbing when inverted so I moved the c/g 1/2" forward from the rear-most recommended point and it is now very nice.
Hope that helps. It is a very nice flying plane and looks great in the air.
#1384
Tower does not sell them but I did call gp & the man said he would send me one. I asked how long it would take & he didn't give me an answer. I'm hoping for the maiden flight in a week. If they don't come through, I'll post again. Thanks for lookimng.
#1385
CA
ORIGINAL: Lifer
I had read everyone had problems with those bouncy tires. I call GP and told them I was having problems and they sent me a pair of Robart tires. I did a bounce test and the Robarts were a lot better.
#1387
CA
ORIGINAL: Shubova
What size are those Robart tires and what is the Robart SKU number?
Shubova
[8D]
Shubova
[8D]
They come with smooth hub cap for p-40, AT-6 and similar . Spoked hub cap for P-51, corsair and similar.
When I received the new tires I did a bounce test by throwing them hard on the ground. The Robarts were a lot better. The GP tires bounced almost like a Super Ball.
I Had told GP that I had seen other guys that were able to get new tires from them because the GP tires were so bouncy. I told them that I had read it on RC Universe.
I hope this helps.
#1388
My Feedback: (9)
CA
Thanks for the info. Have you put them on the plane and tested them.
I had a pair of them and they are soft...too soft. They didn't support the weight of the plane. At first they seemed okay but after a few flights they would buckle and get distorted to a point were the tire was starting come off the hub. When I would taxi out on to the run way they would fold back and forth like I had flat tires.
I hope they work better for you.
I have met a few people that have told me that the stock tires on both the Super and the PT-17 (military) wear quickly and after I changed back to them the same thing happened to me.
I'm going to all GP to see if they have a solution.
Thanks again,
Shubova
[8D]
Thanks again,
Shubova
[8D]
#1393
My Feedback: (9)
CA
Capt. Ron,
Our club, Corona RC Club will be at the Riverside AirShow March 28th. We will have a static display and will be doing some flying too. All are welcome...if you are interested in coming out e-mail our VP, George at [email protected] or our PR guy, Danny at [email protected] and talk to them.
Thanks for the info on the tires...I'll check it out!
Happy Landings!
Shubova
[8D]
Happy Landings!
Shubova
[8D]
#1394
My Feedback: (178)
NC
I have a couple of questions before I build mine.....are the flying wires optional? Since they are elastic shoe strings I would guess that they are. Also, I read one review where the builder took the dihedriel out of the bottom wings to make it fly more scale....has anyone else done this? Thanks WC
#1397
The best way to fly ANYTHING scale is to use that device called a throttle.
If I have a spare engine sitting around with not many options for airframes that will take it inside a cowl I WILL use it. You do your thing, I'll do mine!
#1400
ORIGINAL: Super08
I used a Xoar 16x6 on mine with the same engine.
If the Xoar brand isn't available at my LHS, would a Top Flite or any of the others work the same (in a 16x6)?
