Reload this Page >
Black Horse Gilmore Red Lion 46 ARF assembly thread-REVIEW
Old 12-10-2013, 10:56 PM
Kostas1
Kostas1's Avatar
Lightbulb Black Horse Gilmore Red Lion 46 ARF assembly thread-REVIEW
This thread is going to be my assembly thread of the Black Horse (BH) Gilmore Red Lion 46 ARTF!!! and also a review on it!
The power on the nose of the airplane will come from my all time favourite YS 63 FZ-S!!!
Stay tuned!
ID:	1946670   Click image for larger version
ID:	1946671   Click image for larger version
ID:	1946672   Click image for larger version
ID:	1946673   Click image for larger version
ID:	1946674   Click image for larger version
Old 12-11-2013, 02:52 AM
Kostas1
Kostas1's Avatar
Exclamation
https://www.youtube.com/watch?v=IBMGt5WW4qU
Old 12-16-2013, 02:58 AM
Kostas1
Kostas1's Avatar
Here are some pictures from the wing guys....The weight of it is outstanding...I guess only 150gr!!!
ID:	1947893   Click image for larger version
ID:	1947894   Click image for larger version
ID:	1947895   Click image for larger version
ID:	1947896   Click image for larger version
Old 12-16-2013, 02:59 AM
Kostas1
Kostas1's Avatar
What is also inside the big box?
Old 12-16-2013, 07:21 PM
Granpooba
From whom or where can this model be purchased ?
Old 12-16-2013, 09:27 PM
Kostas1
Kostas1's Avatar
I'm not really sure, because I bought it locally.
Maybe you should check www.americanpioneerhobbies.com or http://www.gravesrc.com
Old 01-22-2014, 10:37 PM
Kostas1
Kostas1's Avatar
Let's see how it goes guys....
Old 01-23-2014, 12:06 PM
opjose
opjose's Avatar
Please post a picture of the landing gear. I'm curious as to how it was done on this plane.
Old 01-23-2014, 02:41 PM
Kostas1
Kostas1's Avatar
Thumbs up
Here are some eye-tempting pics..... :P
ID:	1961378   Click image for larger version
ID:	1961379   Click image for larger version
ID:	1961380   Click image for larger version
ID:	1961381   Click image for larger version
ID:	1961382   Click image for larger version
ID:	1961383   Click image for larger version
ID:	1961384   Click image for larger version
ID:	1961386   Click image for larger version
ID:	1961387   Click image for larger version
ID:	1961388   Click image for larger version
Old 01-24-2014, 02:24 AM
Kostas1
Kostas1's Avatar
Question
I will....I've read that many people try to reinforce the area....We will see...
Do you also own the Gilmore?
Old 01-24-2014, 10:27 AM
opjose
opjose's Avatar
I have the larger 50cc version that I am putting together now.
Old 01-27-2014, 09:31 PM
Kostas1
Kostas1's Avatar
Yes the Giant version rocks!
Old 03-18-2014, 03:51 AM
Kostas1
Kostas1's Avatar
Lightbulb some update on the Gilmore!
As I always do,
with thin CA+ I go over every balsa join and add some extra drops to strengthen the area.
The area of the engine will be secured with fiberglass tape and thinned 30' epoxy.
ID:	1979312   Click image for larger version
ID:	1979313   Click image for larger version
ID:	1979314   Click image for larger version
ID:	1979315   Click image for larger version
ID:	1979316   Click image for larger version
ID:	1979317   Click image for larger version
Old 03-27-2014, 04:00 AM
AncientCityFlyer
AncientCityFlyer's Avatar
Congrats on your Gilmore Lion. I purchased one when they were first introduced ( 2007?) Put the suggested .46 glo engine in it. Not nearly enough power especially swinging a 12" prop. Only had about 1" of prop tip beyond the outer edge of the huge cowl. Also had a lot of trouble with the thin wire landing gear. Ended up replacing the entire landing gear with single piece aluminum gear. It still didn't fly well so I benched it until the beginning of this month. Replaced the .46 with an O.S. .55AX with 15x6 prop. Same mount location. Balanced perfectly. Haven't flow it yet, but will do so in the next few days. Will provide a flight report when done.
BTW, I was stationed at the Air Force base from 1969-1971. Lived in Glifada. Was a flight engineer on the base flight C-47s............Mike
Old 03-27-2014, 07:56 AM
Kostas1
Kostas1's Avatar
Mike thanks for your reply!
Glifada....Nice place to live near the sea!
I actually fly my airplanes on the old national airport, in Elliniko area.
You can check my channel on youtube under here: https://www.youtube.com/user/dreamwisperer
Really, a 15x6 propeller in the 55AX? Isn't that a little biggg ?
As posted earlier, I will try a used YS 63FZ-S on mine.
Please,
can you give me some more info or suggestions on the landing gear?
Indeed they seem to be the weak point of the whole airframe....
Best,
Kostas
Old 04-01-2014, 10:27 PM
Kostas1
Kostas1's Avatar
Just a really small up-date 'cause I'm still waiting for the tools to come.
I purchased some lightly used Hitec HS-77BB servos.
x2 of them are going to the wings and the other than may control the throttle!
Old 05-07-2014, 11:58 PM
Kostas1
Kostas1's Avatar
Here are the servos!
Old 09-16-2014, 08:53 PM
Kostas1
Kostas1's Avatar
Lightbulb ...starting again...
Hi there!
After a long long stop, I recently found some time to start again the assembly of my Gilmore!
First,
what I do on all my airplanes is to "waterproof" the engine area.
I use thinned (/w alcohol) 30' epoxy glue and thin pieces of fiberglass cloth.
ID:	2032891   Click image for larger version
ID:	2032892   Click image for larger version
Old 09-16-2014, 08:58 PM
Kostas1
Kostas1's Avatar
Question
Next goes the wing...
Tip: Use sandpaper to remove the tiny pieces of covering on the inside of the wing halves, so as to expose more wood area
and provide more area for the glue to spread.
ID:	2032894   Click image for larger version
ID:	2032895   Click image for larger version
Old 09-24-2014, 10:25 PM
Kostas1
Kostas1's Avatar
And then the rudder:
ID:	2034905   Click image for larger version
ID:	2034906   Click image for larger version
Old 10-05-2014, 10:09 PM
Kostas1
Kostas1's Avatar
Question
I found some free time to make a small home craddle from spare wood.
Enjoy...
ID:	2037615   Click image for larger version
ID:	2037616   Click image for larger version
Old 10-05-2014, 10:10 PM
Kostas1
Kostas1's Avatar
Lightbulb
https://www.youtube.com/watch?v=dKzyOW66geE
Old 10-08-2014, 10:26 PM
Kostas1
Kostas1's Avatar
Thumbs up
So here we are, with the rudder and stabilizer glued with GreatPlanes 30' epoxy!
ID:	2038629   Click image for larger version
ID:	2038630   Click image for larger version
Old 10-08-2014, 10:32 PM
Kostas1
Kostas1's Avatar
PROBLEM!!!
As you see in the attached picture, my Gilmore has this difficiency
on the tail area.
When you're ready to glue the stabilizer in place, you have to bring it back towards the tail so as to make the joint stronger.
But then at the front, the space on the fuselage that is designed to accomodate the stab is way too large for it, thus giving you a big gap.
ID:	2038632   Click image for larger version
Old 10-08-2014, 10:35 PM
Kostas1
Kostas1's Avatar
HINT:
When you are ready to glue the CA hinges in place, use THIN CA+ and also a proper tiny CA applicator to reach the area arround the hinge.
I always prefer to use GreatPlanes CA+ hinges and CA applicators. Look how good the fibres look!
ID:	2038634   Click image for larger version
