Unwanted lead in nose H9 1/3 Su-31
AP
Just finished building it, and went to balance model and discovered it will require almost 1 1/2 lbs of lead on the firewall to balance her. Gt-80 engine, all equipment installed per manual. What wrong here? Anybody else have this problem
My Feedback: (28)
Weight
Hi Japan3D,
I have a new Su-31 with GT-80. I used 20oz. lead to get mine to balance. Battery pack is all the way forward against firewall. It balances right on the correct spot. This thing flies great! Does everything I want it to do. Takeoff's are dead straight with little right rudder, landings are at a crawl. It flies like a trainer on steroids! You have done nothing wrong, just balance it correctly and you will love it.
Tom Perry
Schertz, TX, USA
Tom Perry
Schertz, TX, USA
AP
SU-31
Thanks TP777fo,
I guess the extra weight does not bother this combination. Will install the 18 oz tomorrow. Have to wait till next weekend to try it out. I now own all 3 1/3 scale ARFs from Hangar 9 The CAP 232 required weight in the tail about 7 oz, and the Extra 330l balanced perfectly with no weight, All 3 use the GT-80 for power. Where does yours balance? Forward or Aft of the center of the tube or right in the center?
Once again Thanks
Richard Bombash
Tokyo Japan
Once again Thanks
Richard Bombash
Tokyo Japan
AP
I fly at a US military base named Sagami Depot, in Sagamihara City. I'm the only one who flys there. The other guy left in june.
the su-31 is a good flyer,but i have found that the su flys better with the cg back 1.25" from the center of the tube. i have 30 flights on it as of 8-27-02. i am using the zdz 80 single, it is a good power combo, even for 3d. the zdz is just now coming to life after 5 gal of gas. i moved the cg back a little at a time, the last 20 flights have been at 1.25", it could go back more. don't be afraid of it, it is a big yellow trainer...
What length servo arms are you using on the ailerons. I have hitec digital 5625 and was going to use the stock al. arm 1" but they seem to short and the control rod won't line up with the hard block in the ailerons it hits at the very edge. Do i just instal it at the edge or angle the push rod so it hits more center on the block? I dont think either are a god idea. but i can not find longer arm for the hitec. Also what about the elevators it calls for 1' arms also do i use the standard hitec 1" or go longer
AP
Hi Karl,
Haven't flown mine yet, hopefully this weekend if the weather agrees. How much lead did you have to put on the nose to balance? How much have you've taken out to get the CG where its at now?
jpeters
I used the H9 arms that came with the hardware kit. Just run a little thin CA in the holes before tap them.
japan3d
jpeters
japan3d
My Feedback: (289)
Dubro makes a composite control arm for the Hitec servo's,they are made for giant scale aircraft. The package comes with several different size arms. The longest arm 1 1/4 " seem to work fine for aileron,elevator and rudder servo's. (the outside aileron servo needs the shorter 1" arm to avoid binding at full throw) The package of arms cost less than $10.00
NJ
Jpeters Hitec servo arms
I had a hard time finding alum. servo arms the first time, I found them at chief aircraft.com. They are also available from Creek Hobbies, in Mt. Laurel, New Jersey. Creek hobbies can also be found in almost all magazines, with large adds.
These are for 3D use 1/2 arms are 11/2 in. long hope this solves your problem.
I'm interested in this Plane but wanted to use a ZDZ-80 single it only weights 4.2 lbs.,have read so much about balance that I now have reservations and don't think I want to have to add 1, or 11/2 lbs. of lead in the nose. Could you have moved the motor farther forward by the use of engine stand-offs to change the CG
Mike
Mike
My Feedback: (7)
Re: SU-31
Originally posted by japan3d
Thanks TP777fo,
Once again Thanks
Richard Bombash
Tokyo Japan
Thanks TP777fo,
Once again Thanks
Richard Bombash
Tokyo Japan
5 of us purchased this plane and 4 out of 5 pilots recommend using the zdz single 80 . We went with 2" al. stand offs, pull pull forward of the wing tube, carbon fiber wing tube and tail gear. 6 volt 2700 pack for reciever and 1650 for ignition both nmih. batteries will be mounted on fire wall. If more weight is needed i am building out the fire wall the distance of the stand offs and then i will mount the batteries up there. With all that i dont think much if any weight will be needed.
My Feedback: (16)
GA
The only thing I can find is Camp Zama.
I can't find a map so I don't know where this is with respect to Narita Airport.
AP
Sagami Depot is about a 20 minute car ride from Camp Zama. Have you've heard of a road that is called Chicken Farm Road? Route 507. Its on the end of that route. Its a good 2 1/2 - 3 hour ride from Narita, and thats on a good day. Throw in a accident and double or triple that time.
http://map.yahoo.co.jp/pl?la=0&sc=5&...&MD.x=8&MD.y=9
sagami depot is right by the arrow in the middle left of this map
My Feedback: (45)
OR
Hitec servo arms
My favorite Hitec servo arms are from Air Wild: http://www.airwildhobbies.com/ . They're excellent quality and come in either "+" or non "+" sizes for perfect fit. If you're not aware, there are two different sizes of shafts on the Hitec digital servos. If you look at the top of the output shaft with the servo arm off, there will be a "+" on top of the shaft....or not. Make sure and get the correct ones for your servos.
bpryor
I just recieved my servo arms from airwild hitec digital with the +.
my question is they are extreemly tight is this normal. the package had the number that was for non + and they hand wrote the number 2 over the 01. called airwild they said the red is for the + and i got the red ones, However you need to force these on.
My Feedback: (45)
OR
Tight fit
Hi jpeters,
They should fit tightly. What you don't want is a loose fit. If you can get them on without using a hammer( ), they should be fine. It sounds like they are the right ones.
bpryor
You can force them on but you have to take them out of the plane so you can put a little a** behind it! definately no slope here!
japan3d, i did not use any lead . i moved the rudder servos to the just behind the wing tube and used pull pull. i put the batterys on engine box. it was 1/2" aft cg, i flew it that way 2 flights and did not like it . so i put the servos in the tail and tried it agin. then i moved the rx battery back to the wing tube. now i am at 1.25" behind center of tube. i will try the cg at 1.5" and let you know how it is. Karl
AP
balancing this big ones
When I went to balance it on the center of the wing tube I just ran string around the tube then ran a dowel thru these. On the other H9 1/3 scales they give a dimension for the CG at the wing tip. How do you balance yours? Do you have some sort of set up or know where on the wing tip the CG is for what you are using.
It seems to me that Horizon is very conservative on the CG for this plane.
Karl, what do you have for an engine? Do you fly at RAMS field? I am a good friend of Lloyd's and he has mentioned your name a few times.
Howard
Howard
